New PSU wont plug in.
  • arneson
    • Sep 2005
    • 1267
    I'm not a noob but I sound like it. Must have been asleep at the wheel a couple of years.
    Since when did the power connectors go from 20 to 24 pin?
    It's not a big deal, I found the plug adapter, in fact they go both ways.
    In my case the old board has 20 but the new power supply has 24, and some other plugs, for I don't know what.
    Guess it's been awhile since I built a system.
    Jim
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: New PSU wont plug in.
    you can use a 20-pin PSU connector on a 24-pin mainboard plug.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Big Pope
      Approved Vendor
      • Dec 2005
      • 426
      For more suggestion, it is better to do this matter if +12v rail have 18A or above.
      My SAMXON Capacitors Database HERE!!
      X-CON is a new brand for SAMXON's Polymer Capacitors.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        some of the new PSUs have a 24pin plug which has a 4pin piece that detaches so the rest of the plug can be used on old boards. the fortron bluestorm for instance.
        with those big ass 24 to 20 pin adapters it just looks ugly and makes it almost impossible to tidy the cables nicely.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          and not to mention the extra resistance the adaptor introduces.adds many points of failure too.
          often there is room to just let the extra 4 pins hang over the side of a 20 pin too.
          • arneson
            • Sep 2005
            • 1267
            I kind of looked at the just plug it in and see the vertical mount FET heatsinks are too close and it's not a snap together.
            I will see how well made the adapter looks and may try to depin and repin but that looks like a thankless job.
            I could use the always helpful Dremel tool to make it fit. I see its the starboard side four, orange black yellow red that have to go away.
            Jim
            • pentium
              • Mar 2006
              • 2778
              I have almost the same board as you. the only change is an extra FET and an at-style connector just above the other connector (you can see where it would be soldered)
              Find Nedry!
              Check the Vending machines!!
              <----Computer says I need more beer.
              • arneson
                • Sep 2005
                • 1267
                Yup I see that J6 row not used.
                Looks like three pads are ground and two are 3v and one blank.
                Thanx to all of the tips I think I'll dremel off the four carefully, then plug and pray.
                This board is all Ost and nothing looks bad, I was using it to set up the back plane and the ports access. I may decide on another board to put in.
                The Ablecom PSU says 550w and I'll only use half that.
                Jim
                • arneson
                  • Sep 2005
                  • 1267
                  Made a clean split off the extra four pins, no adapter needed now.
                  The system powers up and runs fine but it's a really loud Ablecom power supply.
                  The rear fan on this 2U panel is moving lots of air and I'll know if it stops turning, but it's part of an entertainment system. There are four fans total, the three others are very quiet.
                  I put a Soyo board in it after removing the wendel caps.
                  These two were bulging and I was surprised that they are both 1500uf, 6.3v, when the size is so different.
                  Jim
                  • AJ847.63e
                    BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                    by AJ847.63e
                    Hi All.
                    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                    09-18-2023, 06:42 PM
                  • sew333
                    Can i plug pc on this apartment with older fuse box?
                    by sew333
                    Hello. I will be buying new apartment to live. But fuse box is older. Not the newest.
                    And my question. It will be fine to plug pc in this new apartment with that fuse box,i think it is aluminium,right?
                    PC WILL BE: Rtx 4090,14900K,1600W PSU
                    It looks like this ( screen from internet ). Looks like this,not sure i dont take a pic from there. Can i plug pc with that one?
                    screen of this:
                    room:
                    Someone said this to me.
                    1
                    "I would get advice from a local electrician...
                    03-29-2024, 05:37 PM
                  • Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                    by Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                    03-15-2024, 09:37 AM
                  • Grouickman
                    Hofmann geodyna 6300 Wheel balancer
                    by Grouickman
                    Hi there,
                    First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                    Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                    I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                    I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                    03-31-2025, 05:29 AM
                  • Per Hansson
                    Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
                    by Per Hansson
                    I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
                    The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
                    The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
                    As I find linear high voltage regulator designs interesting I drew up the attached schematic...
                    12-23-2023, 06:20 AM
