In the market for a new HDD
    My old Hitachi Deskstar started clicking on boot, and Windows is now refusing to mount the boot disk; sometimes I get a "DISK READ ERROR" from the bios. No biggie, I had nothing important on the disk, just a standard Windows XP install with all the drivers I need for my motherboard (should be fun to find those again, as it's a custom build.)
    This drive was purchased as a B-class (return/refurb?) from Maplin Electronics and mfg date is May 2010.
    I do not want to buy another Hitachi product (are they even made any more??) as lasting less than 3 years in an ordinary desktop computer is rather poor. I'm aware this is a common issue, I suppose it was only time until it affected me...
    So, bearing in mind cost... I'm looking for a drive under £40 (about $65), ideally with a warranty at least 2 years, and around 500GB capacity... I would cope with 250GB or 320GB if the drive brought other bonuses. 7200RPM or 5400RPM is fine. I play the occasional game on this computer and use it to watch videos -- performance isn't critical for me, but lifespan is.
    I've already got two 120GB SSDs but they're being saved up for another build. It would be a waste of their power to use it on this build.
    Any suggestions?
  • mariushm
    • May 2011
    • 3799
    Re: In the market for a new HDD
    At that price, you're looking at WD Scorpio , WD Green, etc :
    http://www.amazon.co.uk/Scorpio-Blue...9232621&sr=1-2
    http://www.amazon.co.uk/Western-Digi...9232621&sr=1-3
    http://www.amazon.co.uk/Scorpio-Blue...9232621&sr=1-1 (320gigs, cheap, but in 2-3 weeks)
    http://www.amazon.co.uk/Scorpio-Blue...9232621&sr=1-4 (500 gigs but 44 pounds)
    http://www.ebuyer.com/272943-seagate...ive-st250dm000 (43 pounds, 250 gigs)
    If you don't care about the form factor, ebuyer has some samsung 2.5" drives at 30 pounds.
    I don't know how good they are, and they're probably selling cheap because samsung got out of the spinning hard drives business so they're old stock.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      This one is £40-43 but is £5 postage
      Big plus might be 36m warranty
      http://www.scan.co.uk/products/500gb...cache-85ms-ncq
      and this one - is sata3
      http://www.scan.co.uk/products/500gb...rpm-32mb-cache
        master hoarder
        • May 2008
        • 12175
        I don't think it's just Hitachi that fails. 3 weeks ago at work, we had both a 1 GB WD Green and a 500 GB Seagate fail. Both had very few hours and power cycles on them. They were both part of backup stations - i.e. not moved around a lot and not treated roughly.
        It just seems that cheap drives 500 GB and over are not very reliable (unless you go with the expensive models).
          So, I don't really use 500GB (I had about 150GB when it crashed), but maybe downgrading to 250GB or 320GB would give me greater reliability?
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            IMHO, yes. The smaller drives are a more tested design... but many would disagree.
            sigpic
            (Insert witty quote here)
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Personally I think "older/smaller drives last longer" is a pile of crap.
              Personally I would not buy anything other than WD.
              This one's decent, 500GB, 7200RPM.
              http://www.newegg.com/Product/Produc...82E16822136769
              Don't get a WD Caviar Green or Seagate Barracude Green, they are not good for a normal desktop. Better for enclosures, etc.
              Oh, and just in case you want to save some money,
              https://www.badcaps.net/forum/showthread.php?t=25561
                One other question. My motherboard natively supports only SATA II 3Gb/s. Can I use a SATA III 6 Gb/s drive, with it running at the slower speed?
                  master hoarder
                  • May 2008
                  • 12175
                  The dead WD and Seagate I mentioned above were actually in enclosures. But they failed nonetheless
                  Actually, the WD still works after I did a low level format, albeit with some bad sectors.
                  • TELVM
                    • Oct 2012
                    • 547
                    • Spain
                    ... Can I use a SATA III 6 Gb/s drive, with it running at the slower speed?
                    Yep, no problem.
                    And I wouldn't lose any sleep on the 'slower speed'.
                    • mariushm
                      • May 2011
                      • 3799
                      Sata III drives are backwards compatible with SATA II so they'll run just fine.
                      In practice, there's minimal performance benefits to using SATA III from a spinning hard drive's point of view.
                      Hard drive won't transfer data much faster than equivalent SATA II drive, but the sata III controller inside chipsets or on board may be using less cpu at high throughput.
                      imho the only benefit to going with small drives is that depending on the version, they may use only one platter and one head, therefore there's less vibration and less noise, and potentially less heat.
                      However, I personally wouldn't buy such low hard drives, the resell value is minimal. It's much easier to sell a 1-2 TB drive than a 250-320 GB one.
                      Or, who knows when you later stumble on an old system, or maybe someone donates one to you, and you retrieve the drive from that one to use it on this system, and you might then find convenient to put this 1-2 TB drive in another system.
                      But I can understand, if it's for a system that doesn't need so much disk space, if you don't plan to sell it at a later time...
                      I currently have three WD and a Seagate drive, I like both companies. Had Maxtor in the past... never had Hitachi or Samsung so I can't say how they work.
                      Hitachi got sold, WD took over the 2.5" drives and SSD section of theirs, and Toshiba got the 3.5" division:
                      http://www.anandtech.com/show/5635/w...hitachi-buyout
                      From reviews, Samsung hard drives seemed to be great, but now they sold the hard drive division to Seagate to focus on ssd drives:
                      http://www.macworld.com/article/1164..._business.html
                      So whatever Hitachi and Samsung you see would be old stocks. Not that the cheap WD wouldn't be old stock, they may very well be, but at least you won't have warranty issues.
                      • DerStrom8
                        Techie
                        • Dec 2012
                        • 76
                        I'll be selling the HDD from the computer I just bought as soon as I can get the two that will be coming to me soon. 500GB, but it's not a SSD. You good with that?
                        Other problem is shipping. I'm in the US, shipping to the UK could pose to be a problem....
                        What do you think? Worth trying to work out, or would you rather look for other leads?
                        Good luck!
                        Regards,
                        Matt
                          Personally, I'd rather buy a drive I've got a warranty on, just for my personal assurance.
                          Also, I do not plan to re-sell the computer at any time. It still uses a 9800 GT and an AMD FX64 X2, which is a nice fast processor, but no competition for today's processors. It's been put together from spare parts; mostly from my brother who upgrades every few months (that's where I got the 120GB SSDs from too.)
                          • Gariarto
                            • Jul 2012
                            • 151
                            These days I will only buy WD. Black series for me and blue series in customer machines unless otherwise requested. I rarely have problems. Used to be a seagate fan up to 2 yrs ago and their firmware fiasco ended that relationship.
                              Well, I am amazed.
                              I contacted my techie friend who does a lot of computer repairs and he lent out me his copy of a program called "HDD Regenerator".
                              Ran it. Found one bad sector; 5 seconds later it repaired it.
                              Windows now boots.
                              • DerStrom8
                                Techie
                                • Dec 2012
                                • 76
                                Well, I am amazed.
                                Windows now boots.
                                I wish there was a "thank you" or "+1" button on this site
                                That will come in VERY handy. Thanks for sharing!
                                • Gariarto
                                  • Jul 2012
                                  • 151
                                  I've had mixed success with HDRegenerator. It seems to be fine while there's only a few bad sectors on an otherwise OK platter, but when its an old drive and HDR is finding hundreds of bad sectors there's been little success. I guess when the coating on a platter has had it, then that's all there is to it.
                                  Glad you got a result Tom but I wouldn't trust that same drive much longer. Transfer your stuff while it lives !
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    I usually use HD Tune and do a full surface scan on the drive and note the number of bad sectors in S.M.A.R.T. Then I do a zero fill / low level format using HDD Guru's Low-Level Format tool. After that, another HD Tune scan and check if any new bad sectors appeared.
                                    If you do this several times and bad/pending sector count doesn't increase, then the drive has probably stabilized. Just monitor S.M.A.R.T. daily after that for a month or so. If no change, chances are it may not give problems again.
                                    Some drives will stabilize after finding a bunch of bad sectors and then never give problems again. Almost all of my used drives have at least a few bad sectors.
                                    The worst I have is a 2.5" Seagate HDD from a Xbox 360 - it has 1767 bad sectors and almost as many pending. Been stable for a year now though after I did a scan on it and let it map out all of its bad sectors.
                                    • welp
                                      PS5 Disk Tray issues.
                                      by welp
                                      I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                                      Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                                      Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                                      So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                                      With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                                      12-19-2024, 02:04 PM
                                    • DynaxSC
                                      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                      by DynaxSC
                                      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                      The behaviour is also really very strange, i.e.:
                                      • The disk shows always up in BIOS - so it is recognized, so far so good
                                      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                      02-23-2025, 01:33 PM
                                    • Stanley1843
                                      Windows 11 disk no boot
                                      by Stanley1843
                                      I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                                      I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                                      DISM /Online /Cleanup-image /Restorehealth
                                      The DISM.... command shows me the error 87.
                                      sfc /scannow
                                      chkdsk
                                      bootrec /FixBoot
                                      bootrec /ScanOs
                                      bootrec /RebuildBcd
                                      For some reason it writes(Total identified installations 0) like there no...
                                      10-18-2025, 04:41 AM
                                    • Jaime Morillo
                                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                      by Jaime Morillo
                                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                      The TV was stuck on the logo and I couldn't access the update menu.
                                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                      The image result was good, but the image is inverted.
                                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                      08-18-2025, 11:38 AM
                                    • madura2010
                                      DAY11AM6E0 hard disk drive and optical disk drive not detected
                                      by madura2010
                                      Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                      i checked the connectivity of ribbon=good communication with hard and motherboard
                                      changed hard disk and checked=3f0 error persist
                                      sata power=+5v available
                                      Then checked data capacitors=all good
                                      Then checked data lines path connectivity to pch=all good
                                      reflashed...
                                      03-12-2023, 09:09 AM
