Mobo hangs, what else to look at?
  • berniedd
    • Mar 2007
    • 119
    Help me out, guys. Desktop computer with ECS mobo model GF7050VT-M5 with 3 GHz Pentium procie was brought to me. No signs of life. All parts on the mobo look good, and there are no bloated capacitors there. But I see a bloated capacitor in the power supply, so I change it with a fresh PSU. I changed the CMOS battery, and also reset the CMOS, and now the thing boots. I hear the short "OK" beep from the internal speaker. However, the process hangs after it shows the USB Controllers have been initialized and that RAM is good. I don't get the message "Failed to load the Operating System, Press any key to try again" or words to that effect if I have disconnected the hard drive (which I always used to get in all other systems I've looked at with no or corrupted hard drive). I can't get past this point, and the keyboard is frozen so I can't enter the BIOS. I tried a PS/2 and a USB keyboard, didn't help a thing.
    I've also taken voltage readings off the PSU supply lines and everything's within spec.
    Any suggestions?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Mobo hangs, what else to look at?
    Google images show me that there are a lot of electrolytic capacitors on this motherboard. Can you post what brand and series they are? Capacitors do not have to be bloated to be bad. I just revived an old P4 ECS motherboard last month by replacing some "perfectly fine-looking" G-Luxon caps around the CPU.
    • Gariarto
      • Jul 2012
      • 151
      Check for any bent and shorted pins in connector sockets such as USB etc. Inside and out.
      Re-seat plugged in components
      Try it with different input devices.
      Check for faulty RAM. Try it with known good RAM.
      If you can, try getting into the BIOS settings and see what things are set to. Load setup defaults and try again. Also, if you can, try with a bootable CD and see if it runs it. That would suggest a hard drive problem. Try accessing the HD in another PC to verify its OK.
      I once wasted half an hour trying to find out why a customer's PC wouldn't power on until I found the little 'push to make' switch had fallen out of the back of the button in the plastic case-front ! (I found THAT by shorting the 'start pins' on the motherboard and it fired up)
      Good luck !
      • Hexel
        Asus K513E mobo X513EA R5.4 hangs during OS load, item partno needed
        by Hexel
        Hello!
        I need help identifying part name of IC in QFN16 packadge under SSD, near audio jack and 1206 capacitors (marked on photo). Unfortunatelly there is no refdes of that part so that is only info I can provide. I took boardview here on forum for revosion 2.0, but it doesn`t have this part at all, not just moved. Maybe someone have relevant schematic or BV.
        Notebook was poured with coffee and someone already tried to fix it but as usual made jusy worse. I`ve restored all mobo defects and now it powers up, starts OS booting but hangs on OS logo. I believe missing part may...
        10-04-2023, 04:26 AM
      • Cerberuska
        Mobo MSI B550-A PRO password popup
        by Cerberuska
        Hello guys,
        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
        BIOS I updated to last one.
        any suggestions?
        And same thing for two different 5600G, and yes, MoBo supposed to support it.
        Thank you...
        11-10-2024, 01:23 PM
      • mrsith
        Dell G3 17 3779 - no display after mobo replacement
        by mrsith
        Hi guys,
        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
        04-30-2023, 05:11 AM
      • Ibod
        Corsair cx600 psu & ASRock B450Pro4 mobo wont start
        by Ibod
        HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
        With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
        Not sure where to go from here ?
        Is the PSU at fault or is the mobo causing the problem
        Look forward to any help :-)
        If I plug the 24...
        02-08-2023, 11:00 AM
      • Felipe_Serra_83
        Dell Inspiron 14-5448 - fan turns off and mobo keeps running
        by Felipe_Serra_83
        Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
        So I got this Dell Inspiron to play with.
        No charger, so I connected to my bench PSU.
        The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
        ------What it did (and didn't do)------
        1) I turned it on and it powered on. Powered down in 2 seconds by itself.
        2) Removed RAM, changed slot. Same...
        04-04-2024, 12:39 PM
