What is this
  • shorteddiode
    • 221
    What is this
    It is on a Sanyo power supply, It looks like it is glas. It does not have continuity, no resistance and no capacitance. What is it and how do I test it.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: What is this
    GA might be
    http://en.wikipedia.org/wiki/Gas-filled_tube
    --- begin sig file ---
    --- end sig file ---
    • shorteddiode
      • 221
      Re: What is this
      IS there a way to test it?
        Re: What is this
        It is TVS (Transient Voltage Suppression) Gas discharge device, which will conduct when breakdown voltage is reached, you can only check for shorts, you will see the inside will be blackened if it was exposed to real high voltage.
        • shorteddiode
          • 221
          Re: What is this
          It does not have continuty, does that mean it is good?
          Thanks budm
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            Re: What is this
            Should be
            -David VanHorn
            • shorteddiode
              • 221
              Re: What is this
              Thanks everyone
              • chth96
                How Can I test PWM DM0365R?
                by chth96
                Hello
                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                06-18-2025, 04:14 PM
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
              • chronic519
                Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                by chronic519
                Hello.
                GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                Found issue with a RAM block
                Replaced, green lines gone.
                Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                Used a good card to test and same results low errors 32+.
                I am just search for some form of command to do a full test on the GPU.
                I just ran the mats command with my good GPU and passed after roughly 40 min.
                The repaired one, ran...
                05-20-2025, 07:56 PM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • alltvrepairs
                Lg TCon test pins for screen test
                by alltvrepairs
                i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                Appreciate your help....
                06-13-2025, 06:33 AM
