Big list of boards I have repaired.........
  • TomK
    • Apr 2004
    ABIT KT7 RAID
    ABIT KT7A RAID
    BIOSTAR M7VQK
    ECS K7SEM
    ECS D6VAA
    AMPTRON K7-810LMR
    MSI 6390L <---my greatest feat...replaced most of the caps and reattached one whole side of the winbond surface mounted chip with just a regular soldering iron.
    Probably others, but that's all i can think of ATM.
    Sorry I don't have a list of the exact caps and locations on each board. I just found this website a few days ago. What I do have is a lot of the bad caps I have replaced. Why I saved them, I have no idea.
    Here they are:
    Ost 6.3v 3300uF
    Choyo 10v 2200uF
    G Luxon 6.3v 2200uF
    G Luxon 6.3v 1500uF
    G Luxon 6.3v 470uF
    G Luxon 6.3v 1000uF
    Lelon 6.3v 1000uF
    Man, if I had a nickle for every cap I've replace, I'd have a couple bucks.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I wish I had kept a list of all the boards I've recapped....... It'd be a hell of a list! I keep the bad caps in large coffee cans, and when they're full, I pitch them in the dumpster... I tossed 4 full cans last Friday, which makes over 20 cans by now....
    Welcome to the forums!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i recently dumped several 5 gal.buckets of dead caps because they were stinking up the shop.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        That's why I use the coffee cans with sealable lids... Contains the stink! The aroma is vile when I pop the lid off... BLEHH
        Team : 49813
        Join in!!
        Team Stats
        • TomK
          • Apr 2004
          Thanks for the welcome.
          • mico
            • Jul 2006
            Re: Big list of boards I have repaired.........
            Shouldn't you be getting hazardous waste services to pick em up?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              does it matter if they go to landfill on the boards of cheap disposable chinese crap walmart special electronics or loose?
              • tiresias
                • Feb 2006
                • 489
                Well, it's not really a problem with caps like TMS or Chhsi, since most of the electrolyte isn't inside the can anymore anyway.
                • gonzo0815
                  • Feb 2006
                  • 1600
                  I don`t know if they make trouble in landfills too, but in waste incinerating plants they do mutch harm to the water /steam/heat transfering pipes. They containe some fluoride, wich will be transformed to fluoric acid, wich will corrode even the best stainles stell and those heattesistant ceramics too.
                  This is wat i have learned by a vissite on such a wast power plant.
                  • arneson
                    • Sep 2005
                    • 1267
                    They cause Global Warming.
                    Jim
                    • tiresias
                      • Feb 2006
                      • 489
                      Fluoride salts? Seriously? That would make the electrolyte rather toxic too, well, depending on how much is actually in there.
                      Certainly if hydrofluoric acid is generated to any degree it will dissolve almost anything, including glass... Certainly polymers are usually used to contain it, or indeed fluorine itself if you're really daring.
                      • stretch0069
                        Screwed Up Super Moderator
                        • Oct 2003
                        • 2662
                        • oooo ess aaaaaaaaa
                        There has to be something we can do with the bad caps........
                        ......i'll have to think on this a bit.
                        SHIT! i forgot...welcome aboard Tom.
                        grab a drink, have a seat, and join in the fun. I think we've hit just about every topic at one time or another.
                        "Its all about the boom....."
                        Guns kill people like spoons made Rosie O'Donnell fat.
                        We now return you to your regularly scheduled drinking.
                        "Fear accompanies the possibility of death.....calm shepherds its certainty"
                        AWD is just training wheels for RWD.
                        • Shroomie
                          • Apr 2006
                          • 356
                          Ammunition! I think that was suggested in the firearms thread and I can't get over the idea. Seriously, the bulged tops would be aerodynamic, and there's not much that destroys dignity more than getting shot with a perfectly bulged Fuhjyyu, with its signature tiny leak in the crosshairs... or worse yet, smelly expired-Teapo buckshot.
                          You know there's something wrong when you open up a PSU and are glad to find Teapos.
                          Why I don't buy cheap cases!
                          • PeteS in CA
                            • Aug 2005
                            • 3583
                            • USA, Unsure of Planet
                            From Nichicon's website:
                            2. Application Guidelines for Aluminum Electrolytic Capacitors
                            7. Disposal
                            ( 1 ) Take either of the following methods in disposing of capacitors.
                            a. Make a hole in the capacitor body or crush capacitors and incinerate them.
                            b. If incineration is not applicable, hand them over to a waste disposal agent and have them buried in a landfill.
                            PeteS in CA
                            • stretch0069
                              • Oct 2003
                              • 2662
                              Originally posted by Shroomie
                              Ammunition! .......... or worse yet, smelly expired-Teapo buckshot.
                              THATS what I'm talkin' 'bout!!!!
                              I've been looking for a reason to buy a shotgun reloading press.
                              hmmmm....then again.....aren't most of the caps about 12.5mm???? Isn't that close to half an inch???? i just so happen to have a pistol that shoot that "caliber". (see my avatar)
                              oooooooo......TC...I need to get my ass over to your place so we can have some fun.
                              • tbalint3
                                Abit ST6-Raid repair
                                by tbalint3
                                Hello All,
                                I am trying to repair an old Abit ST6-R motherboard.
                                The symptoms are the following:
                                I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                                It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                                If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                                09-01-2024, 10:03 AM
                              • canadaboy25
                                Drive SMART status not showing up through RAID controller?
                                by canadaboy25
                                Hey guys,
                                I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                I rebooted...
                                09-24-2021, 01:56 PM
                              • PeTTs0n
                                Abit BX133-RAID odd issue, bad caps?
                                by PeTTs0n
                                I just bought a bundle with a Abit BX133-RAID, a 866MHz P3 (SL4CB) and a 256MB PC133 SDRAM stick, that the seller claims were working fine together.
                                After building a rig out of it, with a known working PSU (Seasonic S12II 520W, for its good 3.3V and 5V rails), I get a good startup screen, but as soon as I try to enter the BIOS, it locks up with a blue bar across the bottom of the screen.
                                I have seen one thread from 2010 about this issue specifically on Vogons, and the consensus there was that bad caps may very well have something to do with it, and although I can't see any...
                                09-04-2020, 02:44 PM
                              • canadaboy25
                                ABIT KT7 RAID only POSTs every other time
                                by canadaboy25
                                Hey guys, I have an ABIT KT7 RAID motherboard that will only POST every other time I try it.
                                When first powering it up, all the fans and drives spin up but I get no display and no beep. If I then turn the switch off on the power supply while it is running and wait for everything to stop and try again, it boots up just fine and works great until I shut it off.
                                It doesn't matter if it has sat for a while or if I was just using it, it always takes exactly 2 tries to get it to POST.
                                Rebooting from windows also doesn't work as it just hangs in the exact...
                                08-08-2020, 07:38 PM
                              • Foetuss
                                Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                by Foetuss
                                Hi all
                                Hope this is in the correct place.
                                I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                Could use some double checking to see if I'm not doing something stupid .
                                Pictures of the boards are attached.
                                What I will be replacing with what : (planned)
                                Soltek Golden ::
                                4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                01-18-2025, 11:44 AM
