Just broke a customer's laptop...
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Guess I was due to make a mistake. Was disassembling a customer's laptop and the antenna wires caught on the case as I lifted the hinges out of the lower shell. The shell picked up and swung off the desk, and I lost my grip on the screen, and dropped it. Fell on its back, but it was enough to put a nice diagonal crack across the screen.
    17" screen... $90 out of pocket. Guess I should make sure that I can fix what it originally came here for before I order the screen, but I'm almost certain the original problem was old dried up CPU paste that wasn't replaced by the last place that diagnosed it.
    Ugh. Just not my day today.
    Ludicrous gibs!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Just broke a customer's laptop...
    Yep, that's not working so good.
    Ludicrous gibs!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      too bad it is a large widescreen...otherwise I would have a panel to fit your needs... (from a dead HP nc6000). (OT- I wonder if that panel has value)
      don't feel too bad... all but 3 of my prior working laptops have died from smashed screens caused by falling on the back...out of those, only one was ever fixed. out of the 3 survivors, two were magnesium bodied Dell latitudes, and the third was lucky enough to have been bought after I stopped being quite as clumsy.
      sigpic
      (Insert witty quote here)
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Was just thinking about it, and I think I'm going to go ahead and order the screen so that it's on the way. Chances are, I'll be able to fix the laptop anyway.
        Ludicrous gibs!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          I'd be lying if I said I never hosed a customer board.... it's the nature of this imperfect world we live in.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • mockingbird
            • Dec 2008
            • 5484
            Once I was working on an Acer laptop with an "InsydeH2O" (Weird phoenix hybrid) bios. I routinely flash BIOS on computers to keep them up to date. This time, however, Acer's utility locked up the keyboard and mouse and failed to flash.
            Not a big deal I thought. Insyde BIOS have recovery through the use of CDs. Guess what? Laptop is completely dead! No power whatsoever. I don't know how Acer did this, but some chip on the motherboard will not allow current to pass through if there is a corrupted BIOS. No lights even with adapter plugged in.
            $100 later, everything was working. Still have that motherboard. Maybe I'll ship out the BIOS chip one day to get re-programmed.
            • b700029
              Banned
              • Sep 2010
              • 640
              That sounds more like the EC (embedded controller) flash got corrupted. The EC is what controls system power, the indicator lights, and the keyboard.
              • stevo1210
                • Oct 2006
                • 4156
                Guess it's part of fixing things for people to accidentally break one or two every now and again :P
                Now... this happened 3 days ago when a client came in to get the old cracked LCD replaced. She bought a white LCD + digitiser in so I could put it in... but it got caught on the screen cable as I pushed it in and this is what happened.
                $36 later (out of my own pocket) and this was the end result.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  It is like baseball... even those with the best batting averages do occasionally slip up and get a strike out... or in american football when the best QBs accidentally throw a pick-6 (interception plus defensive touchdown). Sometimes, you just screw up.
                  sigpic
                  • mockingbird
                    • Dec 2008
                    • 5484
                    What are solder barrels for? I was unsoldering a broken audio jack and the jack came out with this cylindrical copper-colored thing around the pins. The new jack I put in didn't work at all. I'm thinking those barrels actually did something.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Uh, weren't those the vias in the board?
                      A working TV? How boring!
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I've accidentally damaged stuff lots of times in the past. Once I was trying to test an nVidia GF 7950GT I had just re-capped for a customer. It was working until I bumped it, which fried the card.
                        • digge
                          • Apr 2006
                          • 296
                          I would have a look at the back of the display and look for manufacturer/model. Most of the time you can buy the same display for roughly half price compared to buying from the laptop manufacturer.
                          • Ami Sapphire
                            Extreme Lurker
                            • Sep 2010
                            • 180
                            I was fixing a Dell XPS M1530 laptop which had a cracked right hinge, a ruined WIFI antenna, a locked BIOS, a dying hard drive, a recessed left touchpad button, and a filthy keyboard with one missing key. Yeah, what I heard from the customer was that someone sat on the computer. (And somehow did not damage the screen!)
                            I fixed most of those problems then. Then I decided to clean the keyboard. While doing so, I cracked two keys' hinges, and the result was that they were unusable. That was only $7.50 total to replace them, including the missing key. Nothing compared to the rest of the thread. I, however, almost overheated the laptop in more that one occasion while working on it.
                            Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
                            I have two v2s and one v1.
                            I am still looking at these boards nearly every day.
                            What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              I've never ordered a screen from the laptop manufacturer... Always grab one off eBay from some importer in NYC.
                              Ludicrous gibs!
                              • smason
                                • 1652
                                Thru-hole plating?
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  yes.
                                  rip the entire hole liner out like that and you can kiss that part of the PCB goodbye...
                                  what happens is after drilling and before etching, they plate the vias and through holes with copper... then they etch the board... that "barrel" was essentially a trace.
                                  the reason for this is that is a few things:
                                  1. stronger though-hole joint (copper to copper is stronger than copper to solder)
                                  2. solder has a relatively high resistance compared to copper and other trace materials.. increasing the surface are of the copper reduces this effect.
                                  3. getting solder to reliably wick to such thin traces on the inner and top layers of the board is difficult, especially when boards are mass produced in a wave solder process... the plating ensure all layers have a good connection to the component lead.
                                  sigpic
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    Thanks for the info...
                                    In retrospect, what I should have done, with my limited equipment, is take the cover off the jack and solder some wire to the jack contacts or even run the wire from the jack leads underneat to a female jack routed outside the case...
                                    Oh well. Hindsight is 20/20.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      friends sons ipod touch 4th generation.
                                      Was going by youtube video, heat, cut the glue, take off. easy (well mostly easy, even with a phone pry tool). Taking off the metal plate that sits ontop of the motherboard, when for some reason, THIS ipod touch 4th generation has glue keeping them together, not something shows in the video. pulled the board up, snapped the ribbon cable hooking to the buttons on the side. Ok mybe I could replace THAT. Didn't realize in the cursings of mine that the power connector from the battery (actually it looks like a ferrite filter that sits next to the battery) has beenz pulled off too. you live you learn. and lean apple devices might neat, but a pain to take apart, as with a lot of phones/pdas
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        My 4th gen Ipod randomly stopped working one day, the chips inside somehow fried themselves. But when I took it apart, the lcd screen went 'click', and it had a nice big crack in it. Oh well, the thing is dead anyways. xD
                                        I lol'ed a lot, when I saw how tiny the battery is. Apple says it will make the Ipod play for 24 hours straight, but that is a big lie, it would never go more than 3 hours before dieing.
                                        I am never buying an Ipod again xD I just feel dissapointed, also that the thing costed like $200 bucks, and lasted almost 3 years of not much use.
                                        Made in China.
                                        :P
                                        -Ben
                                        Muh-soggy-knee
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
