Windows Operating System X64 ???
+ More Options
Posts
  • colormebad
    colormebad
    • Dec 2010
    • 114
    Does anyone know of an operating system besides windows 7' thats like xp pro with sp3 ' that will work on a 64bit system...I have the older xp pro sp1
    x64..But can upgrade it' so its no good...7 runs smooth ' but wish control panel/device manager and some other places still looked like xp pro...Lots of older people i fix some computers for gets realy confused on windows 7...
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Windows Operating System X64 ???
    Unless you have more than 3GB of RAM, 32Bit versions of windows will be perfectly fine.
    On CPUs supporting it, 64Bit is an option. It's not like.. necessary to run 64Bit software on them. All CPUs supporting 64Bit can run 32Bit software no problem.
    In other words: Unless you have more RAM than a 32Bit windows could address (3.25GB i think it was), there's no need to run a 64Bit version. A "boring old" 32Bit XP SP3 would be fine.
    • colormebad
      colormebad
      • Dec 2010
      • 114
      This new asus came with 16G's of ram
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        32 bit windows will work fine with 16g of ram, but it won't be able to see more then 3-4gb (usually 3.25 or 3.5)
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Actually in 32-bit Windows with 16GB of RAM you can set up a RAM Disk in the upper 12GB and put a Virtual Dive in it which will kick ass on any SSD ever made.
          Those that have tried it have gotten 'drive' transfer rates of as much as 32Gb/sec.
          - Not a bad place to put your page-file during game sessions either.
          Just don't run saves to the Virtual drive. Will go *poof* when you power down.
          That's what gamers should be doing vice blowing money on SSD drives that are going to be junk in couple years.
          Win 2003 Server is basically Windows XP-Server. Does x64 fine.
          As it's a Server OS support will be better and should be around longer too.
          Mann-Made Global Warming.
          - Dr Seuss
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Originally posted by PCBONEZ
            Actually in 32-bit Windows with 16GB of RAM you can set up a Virtual Drive in the upper 12GB which will kick ass on any SSD ever made.
            ditto. do that and you will have a rig
            plus, keep in mind the page file is literally virtual memory... so in a way, you are literally allowing full access to all the ram in a "backwards" way.
            sigpic
            (Insert witty quote here)
            • b700029
              Banned
              • Sep 2010
              • 640
              There's a patch that enables 32-bit XP to use up to 64GB of RAM, just like with Vista 32-bit and 7 32-bit.
              http://www.geoffchappell.com/notes/w...nse/memory.htm
              The functionality was always there, MS just decided to keep it a secret.
              ...and they really try to keep it a secret, judging from what happened here:
              http://www.msfn.org/board/topic/1335...windows-vista/
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                PAE is nothing new.
                Been around since day one of Windows 2000 and MS has never hidden it's existence at all.
                In fact they made a rather big deal about - 12 years ago when it was new.
                It will let you use more RAM but you take a performance hit on Memory speed.
                You can do -more- [multitasking] but you'll be doing it slower.
                It's only recommended for use on Servers with multiple users.
                - Dr Seuss
                • severach
                  • Aug 2007
                  • 1055
                  The performance hit was because the PAE page entries are twice as big as the non PAE entries. All memory managers now want the NX bit which is only accessible with PAE so they are all running with the large page entries no matter how much RAM you have.
                  Any performance hit should only appear when testing equal amounts of memory, something you might do while developing PAE years ago when 4GB of memory was a dream even for server admins. Falling DDR3 prices allows you to put in way too much memory which should more than offset the slight performance hit from PAE.
                  PAE does not do the page swapping done by non VM operating systems to expand memory beyond the normal bounds. Page swapping for all but specialized tasks like a disk cache wastes lots of CPU cycles copying memory around. PAE simply maps a real 64 bit memory block into a 32 bit VM. Every real memory block under PAE is accessed with a 64 bit address so it makes no difference whether the memory maps from above or below 4GB so long as there are no hardware or software limitations for 64 bit addressing.
                  PAE worked until Microsoft made it not work and guaranteed that it couldn't be made work with just a few patches. I suspect Microsoft is restrictive on PAE because it works far too well on a VM operating system. PAE had to be strangled to get Windows x64 to be adopted quickly. If not then x64 would be delayed forever until a killer app like World of Warcraft pulled the trigger and dropped x86 support. Imagine the hue and cry as gamers are forced to switch to this "new fangled x64 Windows that doesn't work worth a crap! Why can't Blizztard stick with what works?" The switch would never happen because page swapping in 3.5GB would be much less difficult than it was in 640K. Page swap libraries would pop up and Microsoft would have another dozen 3rd party runtimes to prop up until the end of time. Opening PAE to servers allowed large memory where it was desperately needed. The tiny audience guaranteed that PAE would be a stop gap solution that would largely apply to Microsoft Server apps then quickly vanish. It also allowed initial testing and development in a strict environment. Limiting PAE for desktops put the ball in Microsoft's court to bring in x64. No wasted time developing and maintaining page swap libraries. No waiting to see which developer is the first to decide that page swapping just won't work any more which may be never with 3.5GB to work with. Microsoft forces the switch and takes all the heat. Any problems are their own to fix and noone can complain. By pretending 4GB is the limit and forcing all users to 64 bit, the day developers (, developers, developers) will decide that 64 bit is widespread enough to target exclusively will come much sooner.
                  It was only necessary to limit PAE in Windows XP. Now that x64 is quickly taking over without minimal Microsoft doesn't care that Vista and Win7 can be patched into making PAE work. There are very few reasons to bother.
                  sig files are for morons
                  • jschiefer
                    • Nov 2009
                    • 19
                    You can change Windows 7 to use the old theme. When you have control panel up just choose small icons and it will be pretty close to XP.
                    • toastygoodness
                      • Jul 2005
                      • 813
                      and classic... i always run win7 on classic. it's the closest to win2000 lol.
                      • japlytic
                        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                        by japlytic
                        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                        Tried (only with keyboard/mouse connected):
                        • BIOS + database update
                        • Using latest Windows 11 image built with official image creation tool
                        • Previous setup version for Windows 11 installer
                        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                        06-19-2025, 04:59 PM
                      • AppleLover123
                        Acer Aspire A515-52G-53PU crashing during windows installation
                        by AppleLover123
                        Hello Guys,
                        got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
                        I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
                        The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
                        when i install windows 10 it goes trough until the restart and at "getting devices ready" it...
                        03-08-2025, 05:05 AM
                      • DrewPhillips
                        Upgrading XP to Windows 10 in 2025 - HP Pavilion HP-A550Y
                        by DrewPhillips
                        I am contemplating upgrading an old HP Pavilion HP-A550Y from Windows XP to WIndows 10. This machine has a 3 GHz Pentium 4 "Prescott" processor. I have some additional RAM to add. Have plenty of HDD space. I have several questions on how to best proceed at this late (for Windows 10, anyway) date.
                        Where is a good place to get a copy of Windows 10 and the activation key? Would I use 32 bit or would I use 64 bit version? Is it possible to do a fresh installation of Windows 10 these days and not an upgrade? If upgrading, is it possible to go from XP to 10 directly and without...
                        02-07-2025, 01:35 PM
                      • khelane
                        Satellite PRO A50-A Not turning on after turning off Windows
                        by khelane
                        Hello
                        A device with specifications
                        Toshiba Satellite PRO A50-A is here to replace the hard drive.
                        The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                        The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                        04-20-2023, 06:28 AM
                      • Online_internet
                        Windows re-activation problem
                        by Online_internet
                        I have a problem with windows activation. The laptop has the original version of windows 8 included by the manufacturer. The laptop worked on the original activated key for several years. Recently I wanted to try to see if I could still upgrade to windows 10 (it was a mistake). Of course, the time to upgrade to windows 10 has long since ended and my key was rejected. I came to terms with this and wanted to reinstall windows 8, I downloaded the system from the windows website, after starting the procedure it showed a window to enter the key, I entered and to my surprise now also...
                        04-30-2024, 09:49 AM
