Holy crap Firefox blows IE9 out of the water!
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    I been thinking about ways to speed up my laptop's browser. I was using IE9, and all the damn flash advertising was slowing things down to a crawl, thrashing my hard drive with constant read/writes fragmenting files all over the place. Nothing like having flash ads start spewing loud ass voices/music ads when your right in the middle of something.
    So I downloaded the latest revision of Firefox, and loaded in the add-on Adblock Plus and installed Easylist or whatever. I'm not for sure exactly how it does it, but it nukes just about all the ads on pages I frequent. Browsing has been significantly speeded up, an my hard drive no longer sounds as though its being thrashed.
    I think my next goal will be to set up a ram drive and set Firefox to where it uses it instead of my hard drive.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Holy crap Firefox blows IE9 out of the water!
    Yes indeed Adblock Plus is amazing!
    Interestingly enough, I find IE9 to start up and load web pages faster than FF. But FF has a better interface, more addons, etc... so Firefox is the way to go.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Now try Opera and prepare to be amazed.
      A working TV? How boring!
      • NxB
        • Feb 2009
        • 1595
        or chromium
        • RJARRRPCGP
          • Jul 2004
          • 6304
          More likely Internet Explorer's caching. Internet Explorer generates a lot of files for web page and image file caching.
          And Microsoft made it difficult to properly clear the file-based cache.
          To really clear it, you must boot a portable Windows from a DVD or a CD, if using a mini XP. Hiren's boot CD with mini XP works like a charm, at least for XP.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • mariushm
            • May 2011
            • 3799
            I'm not using Adblock because it has the potential to mess up forms and good scripts on websites I use and I'm too lazy to individually whitelist websites.
            So i've taken the middle ground and installed just Flashblock which replaces Flash objects before they're even downloaded with just an icon - when you click it the Flash loads as it should have loaded by default.
            And whitelisting is very simple, just right click and select "All flash from this domain / website" which doesn't enable all flash on a website
            • RJARRRPCGP
              • Jul 2004
              • 6304
              I had good luck with AdBlock Plus!
              And NoScript is the king daddy! No Javascript-based programs that create treacherous computing!
              I'm starting to not like the Javascript-based image downloaders!
              Before NoScript, some images load like I got a gazillion-years-old DSL service!
              I usually estimated only around 200 kbps image file downloads!
              And if that's the case, then I think image file sizes bigger than about 256 KB should be banned.
              Arc A770 16 GB
              • lti
                • May 2011
                • 2557
                I have been using Firefox 3.6 with AdBlock Plus and NoScript. I haven't had AdBlock Plus mess anything up. NoScript is a pain to use and doesn't block everything (as I found out when a radio station's Web site decided to install adware on my computer). I also have a custom Hosts file, which slows page loading, does not prevent sites in the file from adding tracking cookies to the computer, and caused Microsoft Security Essentials to throw a fit and remove sites that are known to infect a computer instantly after accessing the page.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  There appears to be some options in NoScript not enabled by default to block more stuff and it's never a good idea to browse with an administrator account.
                  Too many stuff that can pull a stunt to gain privileges to take over Windows settings.
                  3.6 is EOL, IIRC.
                  Arc A770 16 GB
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    My new MacBook Air can't use IE9 anyway so it doesn't matter :P
                    But can't you just use CCleaner to clear the crap from Internet Explorer 9?
                    • Evil Lurker
                      Warranty Voider
                      • Feb 2011
                      • 454
                      You can, but again it thrashes your hard drive. IE9 happily uses the first free space it can find, CCleaner will wipe all the files, but it leaves "gaps" on your drive after its done. Other windows programs will want to come in and use those 'gaps" in between and during browsing sessions and next thing you know your hard drive is fragmented all to hell.
                      Its not so bad by itself but when you have a website with two, three, or more animated flash ads that change every ten seconds and each one gets cached a heavy browsing session can just bomb your drive with a couple hundred megs or more of crap.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        True. That's pretty stupid of IE.
                        • toastygoodness
                          • Jul 2005
                          • 813
                          well, it was a design choice. if anything, i blame flash for poopy garbage collecting and itself being the largest proc/mem hog.
                          but yeah, opera/chromium are boss, especially on linux.
                          i wouldn't say firefox BLOWS ie9 out of the water though, ie9 still manages to start faster on my computer and act more responsive, but i have a very, very bare install of win7 (actually it's win2008r2 converted to workstation mode). but i mostly use opera so, meh.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            I totally agree that IE9 is more responsive. Firefox feels faster though because while IE shows you a blank white screen while a web page is loading Firefox doesn't shows the current page until the new one is more loaded...
                              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                              by sam_sam_sam
                              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                              04-09-2023, 08:04 PM
                            • Hondaman
                              Firefox is now SATANIC
                              by Hondaman
                              Now that I have your attention:
                              In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                              I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                              I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                              03-05-2025, 04:41 PM
                            • Ugur87
                              MacBook Air M4 A3240 Brand New Water Damage no Image
                              by Ugur87
                              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                              08-28-2025, 01:09 PM
                            • edugimeno
                              Stagg sms12p audio amp has water damage
                              by edugimeno
                              Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                              I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                              There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                              There is only one signal wire connecting the first boards...
                              05-24-2025, 06:00 AM
                            • RetroComputingGrotto
                              Water Damaged Toshiba 48L1435DB
                              by RetroComputingGrotto
                              I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                              The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                              10-07-2024, 08:23 AM
