PSU for a PIII Server, Sparkle or Dell psu?
  • Calchaqui
    • Oct 2005
    • 112
    Hi, I'm gonna build a PIII to work all day evry day, I got this 2 psu to buy
    - Sparkle 235W with Killer Noise (from a IBM machine) , used , for u$9
    - PS-DELL-300-NAR Dell Pentium 4 , 300W , new , for u$11
    Are Dell Psu good?
    Well, thank u all of u
    I LOVE WWW.BADCAPS.NET
  • Chris1992
    • Apr 2005
    • 561
    Re: PSU for a PIII Server, Sparkle or Dell psu?
    get the Sparkle. Dell PSU are proprietary.
    Compra la alimentacion Sparkle. Las alimentaciones de Dell son propietarios.
    The great capacitor showdown!
    • Calchaqui
      • Oct 2005
      • 112
      Thanks for that spanish! . What exactly means Dell PSU are proprietary ? .
      I mean, Dell makes its own psu's , but , are they good?
      • Calchaqui
        • Oct 2005
        • 112
        The guy who is selling them says "they are good psu's,really heavy psu'"
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          They don't have the same pinout on the ATX connector. Best case is the Dell supply just wouldn't work. Worst case... it would fry your board. Go with the Sparkle.
          Ludicrous gibs!
          • Calchaqui
            • Oct 2005
            • 112
            Weird!, This guys sold like 20 as "standart ATX psu's" .
            Well, so , the Sparkle 235W is good? what's that Noise Killer thing!?
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              proprietary means something not common specification. basically will only work with that company's hardware.
              sparkle is a good psu but since you are buying second hand, check inside to see if the caps are looking ok, check the fan is working ok, if not replace, clean the dust inside.
              what is it gonna be serving? if it is company stuff i would say new psu only.
              how many hdds will you have?
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                noise killer means fan is either slow or psu changes fan speed with temperature. i usually find powerful fan for server psu
                • Chris1992
                  • Apr 2005
                  • 561
                  Sparkle's noise killer PSUs have temperature control fan.
                  • Calchaqui
                    • Oct 2005
                    • 112
                    Yeah , it is for a Company, for a light server (pIII) single cpu , 512mb , 40gb ....
                    Well , i dont know , better buy a new shitty 50000000000000W PSU with 2 fans and 199W true power.
                    • Chris1992
                      • Apr 2005
                      • 561
                      NO, don't buy the shit high-watt PSU. Buy a good one and it will give you years of reliable service. I recommend to buy a new Fortron / Sparkle PSU if available.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        some dell psu's are ok.
                        gotta watch the pinout though.
                        if i get one of the nonstandard pinouts i pull out the old molex tool and change it or a replacement to suit.
                        those old fortron/sparkle are good once you get rid of the fuhjjyyu caps.
                        got a bunch of stuff from huffy when they closed their springboro warehouse and otherwise junk pc's had some fortron units in them which i pulled for rehab/resale.
                        funny to be digging through junk to get a decent psu.
                        since you said p3 watch those dell units as many dont have -5 and older boards with isa need it.
                        • Calchaqui
                          • Oct 2005
                          • 112
                          yes, they are the best , but money $$$ , I just have up to u$22
                          • MD Willington
                            • Sep 2004
                            • 702
                            Agreed, not all DELL PSU's are gimped to DELL specs...There are solutions out there to get around the proprietary supplies though...
                            http://www.endpcnoise.com/cgi-bin/e/dellconverter.html
                            PC Power Cooling, DELL upgrade power supplies...
                            http://www.pcpowercooling.com/home/
                            Ya'll think us folk from the country's real funny-like, dontcha?
                            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              i have worked with those kinda companies before but no more. if you need the work then ok. just make sure they have good data backup solution so you dont put yourself in a bad position in the future (even some program mirroring the server data directories daily to another computer if there is no budget and you are comfortable to install the server again quickly after hdd fail etc). and yeah servers should be on a UPS if they can afford.
                              • PeteS in CA
                                • Aug 2005
                                • 3576
                                • USA, Unsure of Planet
                                Proprietary may mean special pin-out. Or it may mean a slightly different current rating for one or more of the outputs. Or it may mean more or fewer or different length HDD cables. Or the +5V Stby O/P current rating may be non-standard. As far as I know, Dell doesn't make P/Ss. I think their main vendors are Delta and Lite On. If you find out which and the vendor's model #, you may be able to contact their tech support people and find out what makes the model non-standard.
                                As a side note, beware of "ATX" P/Ss made for Apple. Not only do they not have a -5V O/P, but Apple used that pin for an extra +3.3V wire.
                                PeteS in CA
                                • incapacitance
                                  • Jan 2006
                                  • 29
                                  Speaking of the -5V rail... is the ISA bus the only thing that uses it? My KT7-RAID board has an ISA slot, but I just have a modem in there which doesn't use the -5V rail. I'm wondering if there's anything else that might use it.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Some old soundcards use -5v...
                                    There was even a mobo manufacturer that built a recent board on which -5v was required for the onboard sound; even though it's not in the ATX spec anymore...
                                    I think the serial bus on many computers uses -5v even though it should be -12v according to the specs...
                                    • incapacitance
                                      • Jan 2006
                                      • 29
                                      Thanks!
                                      • Calchaqui
                                        • Oct 2005
                                        • 112
                                        I've just ordered a SPI-300HP Sparkle 300W , the problem is that 5VSB is rated at 0,1 A MAX and motherboards (socket 370) needs 0,3 A
                                        Will be some problem with the stand by function ?
