Raid
  • bigbeark
    • Jan 2010
    • 661
    Raid
    I have an Abit KT7A-RAID that I use with a 29160 SCSI card.
    I have never even tried using the Highpoint RAID feature of this board (I know its IDE only). Would a 4-disk array of small IDE drives outperform ths SCSI? Anyone know if Ubuntu supports the Highpoint?
    I can also get SCSI raid cards cheaply enough, which I could use on any board.
    I have such a card but am uncertain as to how it is to be cabled. If I just use the RAID card and attach a SCSI drive to it, nothing happens. I assume the SCSI adapter card must be connected to the SCSI RAID card and the RAID card connected to the Drives. Is that how it works?
    Again, would I expect superior read speeds? If this were a desktop, not a server. would I notice any difference at all?
    I see all kinds of people going on about RAID but wondered if it was just one of those "bragging rights" situations when used in a stand-alone machine.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Raid
    the Highpoint HPT370 is a software RAID.
    not sure about linux, but it works well with XP and the like (at least for a software RAID..)
    if you can get a couple reasonably fast (= fairly new) IDE drives for it, it should outperform the SCSI setup easily..
    as for wiring the SCSI card up.. it's not just plug & play unfortunately... drive IDs have to be set right, terminators have to be put into place, ... all that kinda stuff..
    i'm not familiar with that adaptec (?) 29160 card though.. so i cant really help here.
    all i ever had was the ancient adaptec AHA-2940UW with a bunch of 2GB and 4GB drives.. and that setup was actually a bit slower than a single (equally old) 6GB IDE drive..
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      Re: Raid
      all depends on how you set it up.
      scsi is usually faster per-drive, but you don't need the 29160 card to get raid, just a raid card
      if your drives are SCA (single, long 80 contact connector) it usually sets the drives automatically if you're using a drive cage
      but if you're using regular high density 68-wire cable, you do have to set the jumpers manually on the drive
      also make sure you terminate it properly. ether have a terminator on the end of the cable, or put a drive on the end of the cable and set it as the terminator with jumpers
      if you have trouble getting all the drives working, try connecting just one at a time, make sure you set the jumpers right. some drives have a small jumper array on the board, seperate from the back jumper connectors
      the jumpers are set in binary
      there is a jumper for 1, 2, 4, 8
      so, if you want your ID to be 3, put the jumper on 1 and 2
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Re: Raid
        4 IDE drives on a 2 port IDE controller?
        No way, the slave drive can't communicate when the master is communicating and vice versa
        Performance will suck vs the SCSI setup
        Plus it will use allot more CPU time, which for such an old system makes allot of difference
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          Re: Raid
          You will need dmraid on ubuntu, it's not installed by default. But goodluck trying to get it to work with the highpoint. You would be better off getting the source drivers from highpoint and compile it. But the last time I tried for my 1740 card, it broke the kernel pretty bad and scrambled my drives. A good zero-ing out the drives fixed them.
          SCSI drives will out perform PATA drives if the drive speeds are more then 7200RPM and in a lun or raid.
          Is the SCSI card a PCI or PCI-X or PCI-E?
          If it's PCI, forget it; it's not worth the raid, since the PCI Bus is a bottleneck. You would need a good northbridge, decent drivers and good circiut design in order to achieve 80% of theoretical 125MB/s, and it's a shared bus, so more cards or other integrated devices *ie IDE/NIC will take quite bit of bandwidth.
          PCI-X 64bit is a better choice, it has more bandwidth which means bigger data transactions but PCI-E and SATA are overtaking SCSI platforms, due to being cheaper and easier to manage.
          IDE raid is no good unless you have dedicated ide channels to each drive as in Primary and Secondary on the board follow by PCI IDE plug-in using the Primary and secondary channels of that, then set one drive for each ide cable to master. Again if it's PCI, it's sharing the bus, so performance is negligible at best.
          If you want to do this for shits and giggles then go ahead. I would recommend linux raid *mdadm,* since that what highpoint does anyways. It replaces the module for their chipset and then interface with mdadm, the only upside is their easy web based configuration page for their controllers.
          Even if you don't, mdadm is just as good as hardware raid, that is if you have a decent processor and good PCI-X or PCI-E storage controller to handle it.
          mdadm is good for basic configuration like span, 0, 1, 0+1, 4,5,6. But you can make it do complicated raid setups like 50 or 51.
          I'm gonna brag now...
          I have 6x 1TB Samsung drives in mdadm raid 5 using intel *deep down it really is a LSI design using a intel firmware* pci-e two port mini-sas 8087 to 4x sata fan out cables. I played with it before settling on raid 5. I had it in mdadm raid 0 and max out the ports on the card being 300MB/s each port, I achieved 585MB/s read and write doing a dd test. In Raid 5 it hangs around 290MB/s.
          None the less it was still impressive. I just wonder what I could do with the 4 port version.
          HTH
          ~MP
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Raid
            Just some thoughts.
            PCI-X cards that work on 5v will work in standard PCI slots as long as there is clearance for the extended length of the card in front of the slot. [Is best to put some electric tape on the exposed slot fingers.] - It will still operate in 32-bit/33MHz mode so that part is not the advantage. The advantage is PCI-X RAID cards are usually FAR better cards w/hardware RAID [and they are getting cheap].
            Standard PCI cards also work in 5v PCI-X slots. The Bus it's in will kick back to 32-bit/33MHz -but- mobos with PCI-X slots typically have multiple PCI Busses. The card might not be running any faster than on a conventional mobo but [if you are paying attention to the boards tech-specs for the slots] it can be on it's very own dedicated Bus and not sharing it's bandwidth with other cards or chips.
            PCI-X RAID cards are far cheaper than comparable PCI-E RAID cards.
            In some cases 100's of dollars cheaper.
            [That means spending more for a PCI-X mobo and less on the card the can still end up -way- less expensive over all.]
            I don't do SCSI so I don't know model numbers for those.
            - To go into a std PCI slot the 3Ware IDE/SATA cards to look at are the 7000 thru 9500 series.
            Those all work in 5v slots. [And at least some -also- work in 3.3v slots.]
            The 9550 and above are 3.3v only.
            If you are thrifty and patient [and a shopahaulic] you can set yourself up with a mobo+cpu+8Port card [all PXI-X] for under $100.
            It's easier if your chassis can support an E-ATX mobo but their are dozens of ATX options with PCI-X if you look around.
            I've even found uATX boards with PCI-X slots that use Pentium-M CPUs for low power consumption. Sounds wimpy but it's PLENTY enough CPU for home or small office file server/NAS.
            Mann-Made Global Warming.
            - Dr Seuss
            • Wizard
              • Mar 2008
              • 2296
              Re: Raid
              PCBONEZ is correct. I woke up and got smarter, played the game and figured out what can do with less for getting older "high end" stuff.
              Cheers, Wizard
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                Re: Raid
                another note
                all PCI-X operates at 66mhz, 100mhz, and 133mhz. some cards do not like speeds they were not designed for, some do
                scsi is ok with a good enough hardware-based raid pci-x or pci-express card
                most hardware pci-express cards are x8
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Re: Raid
                  they even make hardware raid cards for regular pci... I found a 3ware 2 port ATA133 one for pci for $12 on ebay,,,
                  sigpic
                  (Insert witty quote here)
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Raid
                    Originally posted by Uranium-235
                    another note
                    Stop reading Wikipedia, it's wrong...
                    PCI-X operates at 33mhz as well.
                    - It's required by all three PCI-X specifications.
                    This isn't complete or 100% accurate either but it's more accurate than Wikipedia.
                    https://cdn.badcaps-static.com/pdfs/...df6261ed03.pdf
                    There were early PCI-X boards and cards that did not do 100 or 133 MHz.
                    Even after that some mobos are limited to 66 or 100 MHz due bus load limits on the particular board.
                    [I have one board with two slots on one of the PCI-X buses. It is 133MHz max if you have one slot filled but limited to 100 MHz if you fill both slots.]
                    - Dr Seuss
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      Re: Raid
                      not ONE time did I read from wikipedia writing that article
                      I had a LSI scsi controller I tried to put in a Poweredge 1800 and the bios told me the card could not operate at 100. thats where I got this information
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: Raid
                        Probably an old card from before PCI-X got to 100MHz.
                        There should have been a BIOS setting or jumper to slow down the bus on the mobo to make the card work.
                        - Either that or one or the other was not compliant with the standards.
                        Poweredge are a bit on the proprietary side.
                        I wouldn't be surprised at all if they don't comply with industry standards.
                        Newer [compliant] boards typically kick the bus speed down to the slowest installed card automatically.
                        SCSI card should have worked in slot 1 on that board.
                        It's was 64-bit, 66-MHz, 3.3v slot. [Only looks like a 32-bit 5v slot. - Key is on the other end though.]
                        - Dr Seuss
                        • TBoneit
                          • Jun 2010
                          • 70
                          Re: Raid
                          I will put it this way I'm using a IBM workstation with a 10,000 RPM SCSI drive, The drive is faster than a regular IDE drive.
                          OTOH it takes longer for the startup since the SCSI card has to initialize, Locate the drive ID and then start the boot process. It is faster when running however and many of these SCSI drives last much longer then IDE or SATA drives.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: Raid
                            Any 10,000 RPM drive will be faster than a slower drive.
                            Doesn't matter what kind.
                            The bottleneck on hard drives is the head-disk transfer rate which doesn't change much at all between SCSI, SATA, or IDE.
                            ... But it does change much with RPM.
                            - Dr Seuss
                            • eccerr0r
                              It's 2025: do you know where your 5¼" floppy drives are?
                              by eccerr0r
                              Oh wow.
                              As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                              Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                              Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                              Weird. Seems the PC drive is having trouble clamping...
                              07-07-2025, 12:49 AM
                            • abajor
                              Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                              by abajor
                              I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                              I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                              The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                              Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                              04-23-2024, 11:43 PM
                            • canadaboy25
                              Drive SMART status not showing up through RAID controller?
                              by canadaboy25
                              Hey guys,
                              I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                              Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                              I rebooted...
                              09-24-2021, 01:56 PM
                              HP Z440 Workstation E5-1620V4 Specification for Upgrade or Repair
                              This specification for the HP Z440 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 Workstation boardview and Z440 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                              09-12-2024, 03:44 PM
                              DELL Precision T5810 Precision E5-1620V3 Specification for Upgrade or Repair
                              This specification for the DELL Precision T5810 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T5810 boardview and Precision T5810 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
