Socket A Heat sink procedure
  • davmax
    • Dec 2005
    • 899
    Recently I had the opportunity to write the following to help a member.
    Heat sink procedure for Socket A (462) processors.
    Before you attempt this operation make sure you have a good thermal compound. Arctic Silver 5 should be available from local computer component suppliers. Read all of below first.
    1. Disconnect the CPU fan connector.
    2. A medium sized flat bladed screw driver is needed to insert into the clip nearest the motherboard edge. Insert on the inner side of the small lug provided in the centre of the clip and push down enough to release the tension and the move the screw driver so that the bottom of the clip moves outward and clears the plastic retaining lug. This should release the heatsink. BE CAREFUL NOT TO LET THE SCREW DRIVER SLIP DOWN AND DAMAGE THE MOTHERBOARD.
    3. Remove the heatsink and put to one side. Now carefully lift the chrome lever that secures the CPU in the socket to the vertical position. Careful ensure the CPU is seated correctly by pushing on all rubber pads of the CPU. If satisfactory push the securing lever back down to its original position.
    4. Take up the heat sink and clean off any compound on the lower surface. Do not scratch. Use a wood scrapper to take the bulk off and then use a lint free rag moistened with methylated spirits to completely clean the surface.
    5. Clean CPU metal area finishing with spirits as in step 4 above. Try to make sure that compound is not adjacent to or linking any of the small components you see on the CPU. Be very careful. Do not use acetone.
    6. Now carefully check that the heatsink will fit correctly without the spring clip engaged. It is a good idea to practice placing the heatsink vertically on to the processor in preparation for step 8.
    If all looks well withdraw the heatsink and place a small quantity of Arctic silver where you can most likely see the processor has made contact on the underside. Now rub the compound into the heatsink pores and the wipe off carefully.
    7. Place a small quantity of compound on the CPU metal surface and spread a thin even coat across the entire surface. Use a blade of some sort, even a razor blade.
    8. You are ready to re-assemble. Make sure that the smaller clip on the heatsink, the one you attach first, is pulled free on that side. Now the tricky bit is to lower the heatsink vertically so that you bring it down in the right place and hold it there whilst you engage the first clip. The idea is not to spread the compound too far and reduce the effective thermal connection. There must be no air pocket on the CPU body. With the first clip pushed securely under the plastic lug secure the final clip with the aid of the screw driver, pushing down and moving the clip inward and under the plastic lug. Make sure that each clip is well into the root of each plastic lug, if left on the outer edge the lugs do break off.
    9. Remember to re-plug the fan.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • MD Willington
    • Sep 2004
    • 702
    Re: Socket A Heat sink procedure
    http://www.amd.com/us-en/Processors/...5E6678,00.html
    Removal, cleaning, installing...
    Enjoy...
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • Newbie2
      • Sep 2005
      • 885
      Here's two videos, from AMD, one for the AMD Socket A heatsink installation and the other for removal of the heatsink.
      AMD Socket A Heatsink Installation
      AMD Socket A Heatsink Removal
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Wish the kid who's computer I have right now had looked at those videos... Found the heatsink BACKWARDS, probably because putting it on the right way would've required them to remove the PSU first...
        Then again, the motherboard was held into their case by ONE SCREW.
        By the way, the combination of backwards heatsink, heatsink clogged with dust, and fan dying, killed the Athlon 2800+ processor. Oopsie!
        Ludicrous gibs!
        • Newbie2
          • Sep 2005
          • 885
          OMG, the motherboard only held in by one screw, are you going to replace the heatsink, dead processor, and get some more screws for this kid?
          My gaming PC:
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Screws were added after the motherboard nearly fell out when plugging in the keyboard the first time.
            Waiting to hear back from them on what they want to do with their processor situation. It's either a Sempron for $74 or a replacement 2800+ for $140
            Ludicrous gibs!
            • Newbie2
              • Sep 2005
              • 885
              What is the model of that motherboard?
              Is that computer the one with that Xtreme 550W power supply?
              My gaming PC:
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Yep, same machine. It's an Asus A7N8X-X board. Will require a BIOS update to support the Sempron. He's got it all in a lexan case... looks pretty cheap.
                Ludicrous gibs!
                • Newbie2
                  • Sep 2005
                  • 885
                  Can you post some exterior pics of that kid's computer, I wanna see. By looking at his power supply, it's pretty dusty, so I'm guessing the rest of his computer is dusty.
                  My gaming PC:
                  • MD Willington
                    • Sep 2004
                    • 702
                    Get the PCChips XP-M 2800+ combo under the hardware-->motherboards-->motherboard/cpu/combo section at newegg, keep the processor and sell the mainboard on ebay etc... It's a cheap way to get a decent processor...
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      Sempron was already ordered. If I personally had the extra money, I'd buy that 2800+ combo, because I"m only running a 2200+ in my machine here. But alas, the 100 bones is too much to spare at the moment. Though that would give me a board to run this duron on, too...
                      Ludicrous gibs!
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Alright, so it's offtopic, but here are the pics-
                        If it were mine, I'd have to keep it spotless all the time, inside and out...
                        Ludicrous gibs!
                        • Chris1992
                          • Apr 2005
                          • 561
                          YUCK! I'd just not build in an acrylic case if I were incapable of keeping it clean.
                          The great capacitor showdown!
                          • davmax
                            • Dec 2005
                            • 899
                            Back on topic. Thanks to those who provided great links to video of CPU heatsink procedures. They really make clear the mechanical operations and hazards.Naturally they do not mention Artic Silver or how to apply it. So all in all this thread has a very nice set of guidelines.
                            Thanks all
                            Nvidia 8500GT 256Mb
                            33 way card reader
                            Windows XP Pro SP3
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              Thanks all
                              That's because applying artic silver to your AMD CPU voids the warranty on the CPU, no exceptions. If you send a proc in to AMD to be replaced, and they find Artic Silver or any other thermal compound (other than the AMD pads), the proc gets sent straight back to you.
                              Ludicrous gibs!
                              • Chris1992
                                • Apr 2005
                                • 561
                                wtf?!?! That voids the warranty? THAT is just STUPID. What about if you clean the AS5 off with rubbing alcohol
                                • dood
                                  Deputy dood
                                  • Mar 2004
                                  • 2462
                                  It voids the warranty because AMD was getting too many chips back with eletrically conductive Artic Silver smeared all over the top of the chip...
                                  Unless you're doing overclocking, the standard AMD thermal pad should do just fine. And if you're overclocking, you're voiding the warranty anyway.
                                  Ludicrous gibs!
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    From AMD's website-
                                    This limited warranty does not cover damages due to external causes, including improper use, problems with electrical power, accident, neglect, alteration, repair, improper installation, or improper testing.
                                    This Limited Warranty shall be null and void if the AMD microprocessor which is the subject of this Limited Warranty is used with any heatsink/fan other than the one provided herewith.
                                    So it doesn't actually say anything about Arctic Silver, but you can't use any other heatsink... sorry, got them mixed up.
                                    Ludicrous gibs!
                                    • MD Willington
                                      • Sep 2004
                                      • 702
                                      No it isn't, AS can get into the the bridges where they have been cut with the laser and screw up the configuration, also the AS can cause the core to be ripped off due to adhesion.
                                      Lidded processors are exempt since the TIM goes on the lid, not the core. The stock AMD heat sink is issued with shinetsu PCM, not too shabby either.
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        you are talking about AS5? i was reading about that recently, when you pull the cpu out of the socket as well as the hsf. never happened to me though. definitely it is more viscous than AS3. personally i dont like that. one of the benefits to using AS3 is that it applies easy and cleans off easy unlike the chewing gum gunk. AS5 is a bit annoying to apply.
                                        i wanna get hold of some ceramique or arctic alumina to see what that is like. perhaps they will release ambrosia ht on the market? i have seen articlean in the shops, i dont know if that is useful or not. personally i use alcohol and if there is some crap on the heatsink i use label-off followed by alcohol. i dont use that on the core though, i scrape it off and use alcohol only. if i do a board replacement for a client i will always clean and put AS, it is just one way to offer a premium service.
                                        having experience of a competitor tim recently, i forget which product this came with but i used it in an emergency to validate a setup and ended up getting my hands looking silver when i was cleaning it off, it was incredibly annoying to remove with alcohol so i stay with AS for the moment.
                                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                          Securing a good thermal interface between...
                                          10-07-2024, 04:35 AM
                                        • harp
                                          Metod for removing glued heatsink from fragile component
                                          by harp
                                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                          06-23-2025, 02:01 PM
                                        • Ven
                                          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                                          by Ven
                                          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                                          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                                          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                                          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                                          07-08-2024, 09:32 AM
                                        • MORETTIGIAN
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          Procedure performed:
                                          - Removed backplate
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          09-18-2025, 12:14 PM
                                        • Delicieuxz
                                          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                                          by Delicieuxz
                                          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                                          Here's an audio clip of the sound coming from my speakers:
                                          https://vocaroo.com/16HaryHwTx78
                                          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                                          11-15-2023, 09:50 PM
