P5P800...dead
  • stevo1210
    • Oct 2006
    • 4156
    P5P800...dead
    My friend handed me his computer today for fixing. The problem was that it would turn on, but no beeps or display whatsoever. The computer worked fine in his shop throughout the last two years or so. Then when he transported it home for the kids to use and tried to boot it up, it didn't display anything on the screen. I've stripped the board out of the case and bench boarded it with only a CPU (S775, Pentium 4 640, 3.2GHz) and a stick of RAM (Veritech 512MB DDR400)... Still no-go.
    Even with my own RAM and AGP graphics card, it still doesn't want to boot. I am currently using a 300W Delta electronics PSU to power the parts on my work bench, but still no-go.
    The PSU in the computer's case is a Deer branded unit. ewwww. I don't know if it fried the board or not, but I doubt it cause the south-bridge isn't burning hot as with many other boards killed with crappy PSUs.
    What's wrong here guys?
  • c_hegge
    • Sep 2009
    • 5219
    Re: P5P800...dead
    It sounds like it's dead. After all, it is asus
    • stevo1210
      • Oct 2006
      • 4156
      Re: P5P800...dead
      my asus boards dont die lol. my gigabyte ones did however.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: P5P800...dead
        check for bulging ost
        • stevo1210
          • Oct 2006
          • 4156
          Re: P5P800...dead
          all caps are panasonic FJ and KZG, no bulging found at all.
          • seanc
            • Nov 2008
            • 1319
            Re: P5P800...dead
            Check under northbridge heatsink for trauma.
            • yyonline
              • Jul 2009
              • 692
              Re: P5P800...dead
              Try booting it with no memory installed. Does it beep then? (Make sure a PC speaker is hooked up, if one is not soldered on the board.) If it doesn't beep with no memory installed, the bios isn't working. Try reseating the bios chip if it's socketed.
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Re: P5P800...dead
                Did you reseat the processor?
                Ludicrous gibs!
                • yyonline
                  • Jul 2009
                  • 692
                  Re: P5P800...dead
                  And did you plug in the 4-pin CPU power connector? I've forgotten to plug that thing in more times than I can count, and I never bother to check that as it seems too simple to be the problem.
                  • goodpsusearch
                    • Oct 2009
                    • 2848
                    • Greece
                    Re: P5P800...dead
                    Asus boards have voice messages instead of beeps. Remember to have the speakers on and connected to the soundcard.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Re: P5P800...dead
                      KZG are notorious for failing without bloating. You could try replacing all the KZG caps. Personally, I've found that asus are the ones that just die on me while the gigabyte boards last forever.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Re: P5P800...dead
                        i gave up in the end and built a new system for my friend. i found the cause in the end... it was the cheapo DEER PSU that killed it... bad caps on the 5V standby line.
                        new system is an amd 965 phenom x4 with an asus m4a88td-evo-usb3 motherboard... along with a new thermaltake litepower 430w psu.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6301
                          Re: P5P800...dead
                          Most Asus motherboards don't. While my Soyo SY-K7VTA-B has voice.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17135
                            Re: P5P800...dead
                            yes they do... the a7v8x i used to have did it.
                            sigpic
                            (Insert witty quote here)
                            • seanc
                              • Nov 2008
                              • 1319
                              Re: P5P800...dead
                              I have P5L-MX, P5NE-SLI, P5PE-VM and another 945 based ASUS.
                              None of them have 'voices'.
                              Some boards may have them, but there are lots that don't.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Re: P5P800...dead
                                KZG often fail with no bloating....
                                They also often 'present' by the machine working perfectly fine one day then refusing to boot at all the next time it's started.
                                - Which is exactly your symptoms.
                                That mobo may not actually be dead if it has KZG.
                                Mann-Made Global Warming.
                                - Dr Seuss
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  Re: P5P800...dead
                                  Well either if board is dead or not, I'm not planning to use it since it's quite old and if it was the caps, i can't see a point in spending money on a sinking ship.
                                  Plus I haven't got the time these days to recap boards since I'm overly busy with university work and other work on top of that.
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6301
                                    Re: P5P800...dead
                                    Asus A7V8X-X and A7N8X-X don't. But they still have good OC stuff.
                                    Arc A770 16 GB
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Re: P5P800...dead
                                      the p5c800e deluxe has a voice-man that board was a piece of shit!
                                      • Orpheous
                                        • Oct 2010
                                        • 43
                                        Re: P5P800...dead
                                        I have 2 P4P800-E's kicking around here somewhere with voice. I think I disabled it on one though because the board wouldn't detect the aftermarket cpu cooler. The Mrs used to freak out every time she heard "CPU fan failed", so for sanity's sake (hers and mine) I turned it off in bios.
