Stuxnet - malware for nuclear power plants
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Stuxnet - malware for nuclear power plants
    Doesn't surprise me a bit.
    Doubtful ANY country has any reactor primary or secondary plant *controls* that use Windows or any other publicly accessible OS.
    The OS would be proprietary to the equipment and Classified.
    [Would be more like a firmware than an OS.]
    Something like SCADA might be used for power use data logging [the grid] or to run the HVAC in the office areas, but that's about it in the US.
    I suppose these villains could turn on the heat in the summer and piss-off the office pukes.
    THE HORROR!
    Mann-Made Global Warming.
    - Dr Seuss
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      iran's bushehr electricity production hits two month delay
      atomic chief salehi says delay is the result of severe hot weather not the computer worm that hit staff computers earlier this week.
      • ddscentral
        • Mar 2008
        • 151
        • Lithuania, EU
        Some reading on ZDNet.
        http://www.zdnet.com/blog/security/i...09?tag=nl.e539
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          It is difficult to understand the real world actions without knowing what is connected on the inputs and outputs [of the PLCs]
          like anything man. its the universal automation solution
          this is the future of war
          its only a test drive
          its funny on the boats some of the new ones have touch screen control of all sorts of shit running on some non enterprise pc and many times its not working
            • 31301
            boats should not use touchscreens - nothing critical should.
            i work on touchscreen stuff sometimes and unless it's acoustic they can go way out of calibration if they get contaminated.
            i'm not sure you can use acoustic screens in boats or anything else with low levels of resonance either.
            • BigTroll
              • Sep 2010
              • 1317
              • LAMBDA SOND
              #26
              I like Rancho Seco, ive visited it, its very pretty and i love Babcox and Wilcox reactors.
              My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Decommissioned in '89.
                NIMBY is why we are so dependent on oil.
                - Dr Seuss
                • larrymoencurly
                  • Oct 2004
                  • 960
                  How good is Palo Verde in Arizona? A few years ago, they were on the NRC watch list.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Depends on what you mean by: "How good".
                    They would have had to tried REALLY HARD to find a more stupid place to put a plant.
                    As far as the Watch List, they were back off it over a year ago.
                    "NRC Watch List."
                    All that really means is they get inspected more often and more stringently but that in itself is a really big deal.
                    Civilan plants come under the NRC. Navy plants come under NR [Naval Reactors] which mirrors and is authorized by the NRC but more hard assed.
                    [Civilian plants don't bounce around on the ocean and aren't designed to be bombed and take missile hits without breaking and the staff isn't trained how to render the plant and ship useless [and yet not hazardous] in the event of imminent capture.]
                    If the NRC 'watch list' inspection cycle is similar to NRs equivalent status then that means 3x to 4x more inspections which works out to about quarterly.
                    These inspections are not like walk throughs.
                    They bring a team of inspectors and they take a week or two.
                    They look at every physical part of the plant and dig through every freakin' record and log since the last inspection [including training records.] plus some select older records.
                    Every plant employee has to take a exam [is not a quiz, more like a 2-3 hour knowledge test on your specific job] and a good share have to go through oral boards/interviews.
                    If someone ahead of you said something stupid in their interview then everyone after gets drilled on that in addition the other questions the inspectors had in-line. If more than two people screw the same thing up with a similar wrong answer they may add more interviews and more inspections to put whatever the issue is under a microscope.
                    It's not a fun time...
                    Getting on the 'watch list' is basically scoring low [but not failing] in some area or another.
                    A fail [which means a fail in any one area including training] means the plant gets shutdown and you get permanent on-site watch-dog inspectors until every thing is corrected AND you pass a later inspection which is more stringent than the one you originally failed.
                    I've never been at a plant that failed but I've heard the horror stories.
                    There is always -someone- on that list.
                    If there wasn't then a significant number of the NRC's staff would not have a job.
                    Most of the NRC's employees are site inspectors or auditors or managers there of.
                    If there aren't enough plants in the list to justify their employment the NRC will raise the inspection requirements to get someone else on the list.
                    [What can I say, it's the Government...]
                    - Dr Seuss
                    • NxB
                      • Feb 2009
                      • 1595
                      #30
                      Why would a nuke plant use crappy siemens PLCs. This doesn't mess with ab/rockwell stuff, does it?
                        • 31301
                        you'd think the russians would have there own russian or ex-soviet region origin controllers anyway.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          http://www.siemens.com/about/en/worl...ia_1154669.htm
                          - Dr Seuss
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            #33
                            In what is described as a joint Israeli-U.S. effort to undermine Iran's nuclear ambitions, the New York Times says tests of the destructive Stuxnet worm occurred at the Israeli nuclear complex in Dimona.
                            http://www.haaretz.com/news/diplomac...plant-1.337276
                            The Times said the worm was the most sophisticated cyber-weapon ever deployed and appeared to have been the biggest factor in setting back Iran's nuclear march. Its sources said it caused the centrifuges to spin wildly out of control and that a fifth of them had been wiped out.
                            lol its kinda mad you could do that with a virus. effectiveness with zero casualty.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              #34
                              Dontcha just love sabotage.
                              A working TV? How boring!
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #35
                                Here is the full read on this;
                                http://www.nytimes.com/2011/01/16/wo...ewanted=1&_r=1
                                Quite interesting and if true for sure the most epic cyber warfare that has ever taken place!
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  #36
                                  It was impressive, but ultimately insufficient. They should do a Osirik on Iran.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                    03-31-2024, 02:12 PM
                                    09-06-2024, 05:59 AM
