Unknown System Failure
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Unknown System Failure
    ~ Guessing ~
    Maybe AFU HDD was sending noise [ripple/EMI] back into the power rails and that toasted the RAM and Video card.
    Or, maybe some MOSFET or similar on the vid card let go hard and set a voltage spike into the rails.
    Or possibly both...
    Kind of strange everything shit itself at once.
    Mann-Made Global Warming.
    - Dr Seuss
      • 30952
      unless the earth has way above or below line voltage for a second and because the psu case is connected to the chassis and the chassis to the boards - the other voltages looked way out for a second!
      • seanc
        • Nov 2008
        • 1319
        Solid amber power light is usually synonymous with 'fubar'
        Maybe worth popping open the PSU just to check it's all OK in there... I know it's working now, but it still could be having issues.
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          I did inspect the PSU as well as every cap on the mobo. Everything looked as it should. The worst thing I found was some cooked thermal paste around the cpu. The cpu works so I guess it isn't toast as of yet. I will be looking for another 2.4 P4 cpu to replace it with. This thing has the 533mhz FSB. I think it will also support up to a 2.6 P4 non HT cpu. A better solution for its cpu cooling needs to be found too. I also stuck another HD in this thing and reinstalled Xp thinking that I had put my newer 80 gig WD in it. AS it turns out it was and older 30 gig WD. Now I get to do it all over again. I guess I do this while I drink some hurricane beers here this friday night.
          "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
          Mark Twain
          "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
          John Paul Jones
          There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
          Rod Serling
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            they make a 2.8 ghz p4 with 533... my dell i am selling has one.
            sigpic
            (Insert witty quote here)
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Well I think this mobo tops out at 2.6mhz. It may not even see a 2.8 or it may just run it as a 2.6mhz.
              Mark Twain
              John Paul Jones
              Rod Serling
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                dimes to doughnuts it will do a 2.8
                sigpic
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Well I can get a P4 2.6,533,512 for $9 with free UPS ground shipping...LOL Same price for the 2.8. If I ever have money I just might get both.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    #29
                    bad 478 chips are rare.i wouldnt loose sleep over it!
                    and you just gotta love multiple failures like you just had!
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      I'm telling you Kc it did send me mental! Now from what I have learned so far is that the fastest 533FSB Non HT cpu that came in this 4550 was a P4 3.06mhz, 533FSB chip. My unit has the Norwood core P4 2.4, 533FSB chip. If it is infact a plug and play upgrade and I can find one of these chips real cheap I'll try it. Hope you are feeling well today... Oh the old PIII ended up in the parts bin. I remember it being and ok computer but never as nice as the exact same 1gig cpu running on and Abit VL-6. The Dell PIII can't even keep up with this sick 2.4 P4.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        The Dimension 4550 has an Intel 845PE chipset - supports hyperthreading.
                        It is limited to CPUs with a max of 512k cache.
                        There should be a setting in the BIOS to turn hyperthreading off if you don't want it.
                        This list is for an Intel board but it supports the same CPUs your does.
                        http://www.intel.com/support/motherb.../CS-020051.htm
                        You might find a 2.8Ghz costs a lot less than a 3.06 Ghz because the 3.06 is the max CPU for a lot of boards. - That's how it used to be anyway, but I haven't looked at [shopped for] those in a long time.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          More info found...
                          - The chipset supports hyperthreading.
                          - You are limited to 400 or 533 FSB.
                          - You are limited to P4 CPU's with 512k cache because of the chipset.
                          Of those CPUs with 400/533 FSB and 512k cache the only ones with hyperthreading are the 3.06GHz/533FSB with one of the following sspecs:
                          SL6S5, SL6SM, SL6QC, SL6PG, SL6JJ, SL6K7
                          CPU data here:
                          http://ark.intel.com/Product.aspx?id=27499
                          Dell even says it works right here:
                          http://support.dell.com/support/edoc...0/syssetup.htm
                          - Dr Seuss
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            Now all I need do is find one of these rare chips that you listed and then enable hyperthreading in my bios. The new cpu should then be listed twice! This Pimp is so happy now he is going to have a beer sometime today to go with this great news! This is after I pick up my friend when they let him out of the hospital today. This is also after I go to the boneyard to grab to brand new rotors off a 99 suzuki sedan. Why put all brand new brakes on a car only to junk it? At $12.50 each I can't pass them up! I'm not hijacking this thread. Its still about a 4550 Dell system failure and a CPU upgrade. Have not been taking many of these of late. They are too strong.
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Like this:
                              http://desc.shop.ebay.com/i.html?_nk...LH_TitleDesc=1
                              That's one where you'll have to keep checking for a good deal.
                              It's the max [best possible] for a LOT of systems and that drives the price up.
                              - Dr Seuss
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Make sure it says all of 3.06GHz 512k 533FSB and lists one of the correct sspec numbers.
                                If it doesn't look right then ask the seller because there are lots of typos and mistakes in CPU ads.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  And don't buy one from an idiot like this that puts a CPU pins-down on a carpet to take a pic of it.
                                  http://cgi.ebay.com/Intel-P4-3-06GHz...item19bef6f1a5
                                  - Dr Seuss
                                  • Junk Parts
                                    Court Jester
                                    • Jun 2006
                                    • 8953
                                    Well first I'm going to get my brother to check with the two junk PC parts stores he deals with to see if they have one on the cheap.
                                    Mark Twain
                                    John Paul Jones
                                    Rod Serling
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      what is wrong? static?
                                      sigpic
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #39
                                        RD; Yes
                                        • Junk Parts
                                          Court Jester
                                          • Jun 2006
                                          • 8953
                                          wa wa wa...I want my 3.06 hyper threading thing right now! Found one on a blind call. The lady wanted $50 for it. Thats way too much in my book. Saw one on Fleabay for $25 "Buy It Now" Somehow I know I'll mess up on the specs and buy the wrong one. Then again I will be safe as long as a get one of the models that PCBONEZ posted.
                                          Mark Twain
                                          John Paul Jones
                                          Rod Serling
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • Stachujones
                                            Dell XPS 13 9370 unknown USB devices in device manager
                                            by Stachujones
                                            Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
                                            Device manager says "unknown device, failed to request device descriptor"
                                            Can somebody point me in right direction what to check?
                                            I updated bios to the newest version and thunderbolt controller firmware still no luck
                                            04-05-2025, 07:35 AM
                                          • ctroxtell
                                            Carrier HK50AA063 display controller common failure help
                                            by ctroxtell
                                            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                            02-05-2025, 05:31 PM
                                          • howardc64
                                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                            by howardc64
                                            Problem
                                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                            Model & Board Pics
                                            Conflicting Spec
                                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                            https://www.shopjimmy.com/vizio-gj-2k1...
                                            10-10-2024, 01:16 PM
                                          • survivalbloke
                                            Lenovo Yoga C940-14 - will not power up each morning until resetting BIOS
                                            by survivalbloke
                                            I've got this laptop here which is presenting very odd behavior. It works perfectly fine except every morning, it won't power up. Power button does nothing. Reset button on bottom also doesn't seem to have any effect, but if I disconnect the battery, hold the power button for a few seconds to drain capacitance, when I connect the battery back, I can power on. It will go through RAM training as normal, and eventually boot into Windows. The laptop will work fine all day long, but the next morning - the problem is there again.
                                            Any thoughts?
                                            06-23-2024, 09:51 AM
