Motherboards that powers on when plugged in
+ More Options
Posts
  • aznmagic20
    • Aug 2010
    I work as a repair tech at a system manufacturing company and I have to repair a large number of system each day. What I noticed is that I get a large amount of systems that power on as soon its plugged in. The ones that don't post I wont waste much time with, but its the ones that post and burned tested without problems that has me perplexed.
    With problems like Bios settings, WOL and Last State, Power Supply, and CMOS battery aside (have access to fresh equipment as needed) even when the motherboard is taken out and placed with minimum setup (PS, MB, 1 working Mem, 1 working CPU, fresh battery) it would still turn on as soon as its plugged in.
    So I'm hoping somebody can give me their opinion. I'm not looking for an answer so much as if there can be any additional possible problems and solutions. Changing the MB is always an option its just that I want to keep it as a last resort.
    Thanks in advance
  • mockingbird
    • Dec 2008
    • 5484
    Re: Motherboards that powers on when plugged in
    Look for a setting in the bios called "Last State".
    • aznmagic20
      • Aug 2010
      Bios settings like Wake up on Lan is Disabled and "On A/C power Loss" is set to Off. I generally check the bios first for settings that can turn on the board so its generally not a Bios problem.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        funky power button?
        sigpic
        (Insert witty quote here)
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Read the posts by PCBONEZ on this thread (page 3)
          It could be several things, but likely suspects are the tiny caps on the mobo...
          https://www.badcaps.net/forum/showth...t=10336&page=3
          • Shinju
            Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
            by Shinju
            Hey All!
            Long time forum member here with a problematic laptop issue!
            I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
            The laptop would not power on with the new battery installed without the power supply being plugged in.
            When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
            TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
            10-20-2021, 04:58 PM
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • Hondaman
            USB problems?
            by Hondaman
            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
            08-12-2024, 03:26 PM
          • malogro
            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
            by malogro
            Hello all,
            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
            Intro:
            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
            04-14-2023, 04:44 PM
