newbee question testing capps
  • _bluedog_
    • Jun 2010
    ive got a asrock 939dual-vsta mobo that would post when it felt like it
    got fed up with it in the end and swapped it out with different 939 socket board (cant remember what).
    ive been playing with it today testing the capps with an ohms meter
    would i be correct in thinking the capps that sent the meter reading to the max and stayed there were good and the ones that maxed out and then dropped to the three quarter mark where bad
    ?bad? ones marked kze 16v 1200uf and ost 16v 470uf
    thanks for your attention
  • yyonline
    • Jul 2009
    • 692
    Re: newbee question testing capps
    KZE is reliable and unlikely to fail. OST can be unreliable. Not the worst out there, but they do go bad occasionally.
    You can't reliably test caps unless you first remove them from the board. The other components in the circuit can be affecting your reading. Furthermore, a standard multimeter isn't really useful for testing caps. You need something which can measure ESR, which is the critical attribute for computer grade capacitors.
    • _bluedog_
      • Jun 2010
      thanks for your reply just thought id have a play with multimeter i dont have an esr meter or access to one
      but thank for your attention
      • kaniki
        • 514
        if you want to try something that is more accurate at testing caps, but not as expensive as a ESR meter.. try a meter that does just uf capacitance. that is mainly what i use. I had a friend that told me what he did and how he used a regular multi-meter and when he tested a couple bad caps that i had here, all with blown or expanding tops, and all tested bad on the uf meter, he said that 3 or the 5 caps tested bad on the regular multi-meter when he tested them.. but to the uf meter all 5 tested bad.. it is not as accurate or as good as an esr meter, but the uf capacitance meters are the next best thing and do a much much better job then a regular multimeter, and is much more reliable doing in circuit testing too.
        • _bluedog_
          • Jun 2010
          thanks Kaniki i can afford one of those ill pick one up tomorrow and give that a try
          people are really helpful on this forum im glad i found it.
          • MXM
            • 430
            • Unknown
            i cant get an esr meter as of today, and i rely on testing as kaniki advised, so i suggest you to get urself a decent dmm while trying to get the esr meter, and yeah remember the caps must be desoldered for more reliable results as for the caps you asked i dont know how reliable they are but if they arent giving the value as it should then i guess is best to replace.
            peace.
            We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
              12-31-2023, 06:04 AM
            • chth96
              by chth96
              03-09-2024, 10:03 PM
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
            • goodpsusearch
              Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
              by goodpsusearch
              Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
              First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
              05-05-2024, 02:04 PM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
