Replacing low value electrolytics with ceramic?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So I disappeared from working on electronics for quite some time. I'm unboxing my ancient projects and want to resume some of them. Unfortunately, my knowledge is a little rusty.
    I've always liked to do full recaps on power supplies. My cap supply isn't perfect and I do not have any more 0.47uF 50V caps. I do have some ceramic caps with that value. Can they replace the lytic without issues? If I remember correctly, their max voltage drops rapidly after getting hot. Is that correct? If this isn't a good idea, I doubt the cap will cause any problems. It's by the main controller/exhaust so I doubt it will get hot or fail but I like to be thorough.
    • 31265
    Re: Replacing low value electrolytics with ceramic?
    most ceramics are 60% tolerance.
    i use polyester or polypropylene for 1uf and under.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Ceramic capacitors capacitance are also voltage dependent.
      So the general answer to this question would be no, you can't.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        If you can get same value/voltage CGO ceramics, you won't have to worry about the temperature or voltage coefficients. If X7R, then the combined tolerance will be, IIRC, +/-20%. Z5U and Y5V are crap, IMO.
        That said, the impedance characteristic will be very different from lytics.
        PeteS in CA
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Thanks for the replies. I couldn't find anything suitable in my parts bin. I think I will just leave the cap where it is. All the other higher value caps will be replaced which should be good enough.
          • PeteS in CA
            • Aug 2005
            • 3583
            Ack! COG, not "CGO".
            PeteS in CA
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8704
              but it is NP0?
              • PeteS in CA
                • Aug 2005
                • 3583
                "COG" and "NPO" are the same thing, probably nomenclature going back more decades than I do (I think I saw the terms used in late 1950s vintage TV technician magazines).
                PeteS in CA
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8704
                  oh I was jusr being silly with O's and 0's, you know my username...
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    I needed to order parts for something else so I just ordered some 0.47uF 50V nichicon UPW
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      OOOOOOooooooooK
                      PeteS in CA
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8704
                        000000k it is
                        • TheLaw
                          • Jan 2011
                          • 477
                          If you want to visualize how capacitance drops with applied DC bias voltage, you can check out Kemet's KSIM web app:
                          https://ksim3.kemet.com/capacitor-simulation
                          The limitation is fundamentally package size, and more directly, the physical amount of dielectric material contained. Since Class II ceramics are ferroelectric, they "saturate" similar to how an inductor's core might. More material means it saturates less under the same DC bias conditions.
                          Beware of "too good to be true" capacitance values in tiny packages. Sure you can get a 1.0uF/25V 0603 capacitor, but you better not use it above 5V, if you really need a 1.0uF capacitor.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Thanks for the link, that's a pretty useful tool
