What can you tell me about Epcos caps?
  • ethaniel
    Capacitor n00b
    • Apr 2010
    • 27
    I'm just tired of finding generic caps where I live, but I've found a place that sells Epcos caps. They are like Siemens, right? Good, bad? Have someone used them on a motherboard? Any other specifics? Thanks in advance.
    AMD Phenom II X2 555 3.0Ghz @ 3.5Ghz - ECS A780GM-A v1.0 - 4 GB OCZ Gold DDR2 800 - 2 GB Kingston DDR2 800 Value - ATI Radeon HD4650 512MB - Windows 7 x64 - A bunch of hard drives
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: What can you tell me about Epcos caps?
    EPCOS was acquired by and is a subsidiary of TDK.
    I'm not aware of them offering any low ESR motherboard grade caps.
    Lacking any history I wouldn't use their electrolytics.
    If they make solid polymer caps then those might be worth a try.
    Mann-Made Global Warming.
    - Dr Seuss
    • Scenic
      o.O
      • Sep 2007
      • 2642
      uhm.. i found Siemens/EPCOS caps on a lot of older (early 00's) Fujitsu-Siemens made Mainboards. (for example the D1184)
      all of them had jamicon-like vents and most had the cheapo circular rubber bungs, but some had a Sanyo-like bung..
      they were still OK when i pulled them (no instabilities at least) from my own D1184 but you never know..
      all of them (EPCOS or Siemens) were called "LL" as the series (?)..
      apart from the changing rubber bungs, all of them looked exactly the same.. (same vent, same label)
      ^- those came out of my FSC D1184 i recapped 2 days ago and were used in the CPU VRM area.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        That's old caps.
        I don't think he's buying old used caps.
        Presently EPCOS was acquired by and is a subsidiary of TDK.
        - Dr Seuss
        • ethaniel
          Capacitor n00b
          • Apr 2010
          • 27
          Thanks a lot for the info. As PCBONEZ said, Epcos caps don't seem to have a "good" ESR. I have found the datasheet for those B41856 on the pics, and have a "ESRmax" of 0.24. I believe Rubycon MCZ have something like 0.016, right? Quite a difference. I'll just keep looking. There must be quality caps somewhere down here...
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            just replaced some epcos in a rca lcd tv.
            08 datecode and blown up like the all too common fz.
            customer heard these let go.
            • ethaniel
              Capacitor n00b
              • Apr 2010
              • 27
              Good news: I have found a place that can get Panasonic FM, FC, FK, NHG and Nichicon PS from the UK via import. The price is... well, considerable, but this is the good stuff. I don't have anything to cap right now, so I'll have to wait until something blows up.
              • OniJon
                Computer Expert
                • 82
                • Finland
                Sorry about resurrection, but found these inside my TV: Chang and the unfamous Epcos. Should I change EPCOS ones too or only the Changs?
                • loknar28
                  • 3
                  I just ordered 5 samples from Epcos and the accompanying test paperwork states that the actual caps I received reported an ESR @120Hz of only 0.041. Not great but not anywhere close to 0.24. Please don't flame me too badly, since I'm somewhat of a noob when it comes to cap frequencies. Until now, I typically have only bothered looking at capacitance and voltage for the electrolytic variety. What specifically makes a good MB cap, is ESR the main consideration? Is a measurement at 120hz relevant for MBs? Seems fairly low for this purpose.
                  Thanks,
                  • mariushm
                    • May 2011
                    • 3799
                    The VRM powering the cpu and other dc-dc regulators on motherboards work at high frequencies, often above 50-70kHz.
                    ESR will be a totally different value than the value measured at 120Hz, so will the capacitance (usually capacitors not designed to be low esr will decrease in capacitance a lot)
                    • Ageve
                      • Dec 2017
                      • 4
                      • Sverige
                      I know it's an old thread, but these are Epcos LL, on a Fujitsu Siemens D1215 motherboard (Socket 370).
                      Specs:
                      820 uF, 16V, 105 degrees.
                      The capacitance was way off on all of them, ranging from ~600 to over 2000uF (one of the leaky ones).
                      https://www.digchip.com/datasheets/p...B41859-pdf.php
                      According to the datasheet, they are "very low ESR".
                      • PeteS in CA
                        • Aug 2005
                        • 3579
                        • USA, Unsure of Planet
                        Two different vent styles?
                        PeteS in CA
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          wtf!
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Ageve
                            • Dec 2017
                            • 4
                            • Sverige
                            That's strange. I didn't notice it when taking the picture. Only the ones with an >-< pattern have leaked.
                            Could they be fake?
                            All the markings are the same, and the smaller caps have different vents as well. The board had no signs of previous repairs.
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                              ^ Maybe.
                              I've seen EPCOS high-voltage electrolytic caps used in some appliances and electronics, but never in low-voltage applications, especially one in high-frequency switching and/or low-ESR applications. Yes, it could be that those are fake. Or it could also be that EPCOS is re-badging low-voltage capacitors from a different company for their smaller caps, as they might not be making any themselves.
                              To be on the safe side, probably best to replace all EPCOS.
                              Would be even better if you have a cap ESR meter and can check these to see what they read. Maybe even autopsy a few of the caps with different vents to see if they look different inside?
                              And if you feel optimistic, maybe contact EPCOS and see what they have to say? If any of these are fakes, I imaging EPCOS would be interested to know more. If not, then they might just try to shove you away or ignore you.
                              • PeteS in CA
                                • Aug 2005
                                • 3579
                                EPCOS B41859 (Siemens style series name) series is supposedly "Very Low Impedance" and "Very Low ESR", supposedly suited for power supply use. Why anyone would counterfeit an semi-obscure brand eludes me, so I suspect EPCOS is buying from multiple sources and having them sleeved with EPCOS shrink sleeving.
                                So I'd replace them with Nichicon PW or HE series, or NCC/UCC LXZ or KY series.
                                PeteS in CA
                                • rewease
                                  Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                  by rewease
                                  There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                  Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                  Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                  09-17-2023, 12:53 AM
                                  by momaka
                                  03-12-2025, 03:42 PM
                                • eryjus
                                  by eryjus
                                  05-10-2023, 11:21 AM
                                • Paxman_Swede
                                  by Paxman_Swede
                                  Hello!
                                  01-14-2025, 09:51 AM
                                • captain150
                                  by captain150
                                  03-16-2025, 07:34 PM
