Looking for best replacements for Capxons, but can't find data sheets
  • withalligators
    • Jun 2013
    • 267
    Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
    1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
    1 x Capxon 1000uf35v GL C721 105c (This looks identical to the C720)
    The in-stock options for these are Rubycon ZLH, YXF, YXG, YXJ, ZLQ, ZLS;
    Panny EB-A; Nichicon UPA, UVK, UVZ. They come in a wide range of ripple and impedance.
    1 x Capxon 1000uf25v KM P711 105c
    Available are Rubycon PX, YXJ, ZLS, JXF; Panny HD, FR-A; Nichicon UVY,
    UPY, UHE, UVZ, UPA, UVR
    1 x Capxon 2200uf10v GL C721 105c
    Rubycon ZLH, ZLJ, ZLS; Nichicon UVZ, UVY, UVR, UVK, UHE, UHW, UPA, UHV
    2 x Rubycon 35v1000uf YXG S0717 105c (These are probably fine, but I may as well replace, or at least have replacements on hand) Direct replacements are available, unless someone can suggest a better series.
    1 x Capxon 1000uf10v KM C717 105c
    Rubicon ZLH, ZL, YXH, YXF, YXJ, ZLS, AX, YXG; Panny NHG-A, FS-A, HD, M-
    A, FR-A; Nichicon UVR, UVY, UVK, URZ, UPM, UPA, UHD, UPS, URSUPJ, UHE
    Those are all the ones clustered together next to heatsinks on the "cold" side of the board. The rest are:
    3x Capxon 47uf50v KM P720 105c
    Rubicon YXF; Panny FR-A, NHG-A; Nichicon UVZ, UVR
    1x Capxon 68uf63v KM P714 105c
    Rubicon UPJ, UKL, UPM
    1x Capxon 100uf50v GL C546 105c
    Panny FR-A, FM-A; Nichicon UPJ, UKL, URS,
    1x Capxon 100uf10v KM P715 105c
    Panny GR-A, FR-A; Nichicon UVR
    1x Capxon 10uf50v KM P716 105c
    Rubycon YXF; Panny GA-A, KS, NHG-A, HD; Nichicon UPM, UKL
    Any suggestions much appreciated.
    Cheers!
    • 31289
    Re: Looking for best replacements for Capxons, but can't find data sheets
    https://cdn.badcaps-static.com/pdfs/...b98443c906.pdf
    https://cdn.badcaps-static.com/pdfs/...c0932e41ea.pdf
    • withalligators
      • Jun 2013
      • 267
      These were the datasheets I looked at, but there are some discrepancies that make me second guess whether these caps are on these sheets. The first is the size for the sole entry in the GL 1000uf35v; listed at 13mmx30mm. The one on the board I'm looking at is 12, maybe 12.5 with the wrapper, by 20mm. And that's the bulgy one.
      • diif
        • Feb 2014
        • 6978
        • England
        The earlier version has two sizes listed.
        • withalligators
          • Jun 2013
          • 267
          I definitely looked at all the GL sheets in that database, including that one. Maybe I'm missing something, or don't know how to read them, because I only see the same 13x30 size.
            master hoarder
            • May 2008
            • 12175
            Those CapXon GL might be a custom order, which is why you may not find them in the datasheets.
            In cases like that, look up a cap of the same voltage with the same case size and use the ripple and ESR specs (if any) of that. If same case size does not exist in the same voltage range, look up from nearby voltage range (i.e. if it's a 16V cap with 13x30 mm case size, then you can also see if anything in the same 13x30 mm case size exists the 10V and 25V range to get an idea of where the ESR and RC ratings might stand.)
            And if that's not possible, just "wing it" and use a "medium grade" low ESR PSU-suitable cap, like UCC KY/KZE series or Nichicon HE... or something close to that range. CapXon caps are quite the garbage, so anything will do better to replace them, even if not quite the "right" choice.
            Looking at the datasheet specs for the 13x30 mm CapXon GL, it appears even Rubycon YXJ would do the job... and Rubycon YXJ is super-basic entry-level low ESR... so just about anything will work here:
            It's the same cap.
            Ruby YXJ and YXG will work nicely. YXF has lower ripple, so not quite up to spec... but probably won't matter too much. Any of the Rubycon ZL_ series will do.
            Panny EB-A, Nichicon VK & VZ are GP, so don't use, unless you really really have nothing else available.
            Nichicon PA is a good enough match too (slightly lower RC and ESR... which is OK - you don't have to be spot-on with these at all.)
            CapXon KM is general purpose crap, so use whatever you really want from the above listed... though IMO, Ruby YXJ, along with Nichicon PA and HE would be good fits. Panny FR and Ruby ZLS might be a bit "too good", possibly causing the PSU to whine under light loading (not detrimental, but may be annoyingly audible sometimes)
            In regards to the Nichicon "PY" series - are you sure that's not "PV" (pee-vee) series? PY is obsolete from what I know and probably not going to find it anywhere (except obscure sellers with very old NOS). Anyways, if you do, PY crosses to PW series.
            Nichi PA and HE would be my first choice for matching specs... but if you just want to save a few cents here and there, any of the listed Ruby ZL_ series will do, along with Nichi HW and HV.
            Again, Nichi VZ, VY, VR, and VK are general purpose, so I usually ignore them in my searches. They are OK for audio circuits or low-heat, low-stress linear regulator circuits.
            I'd leave these. Ruby YXG's are pretty good. Unless you can see the board has discolored / darkened around them from heat, there shouldn't be a need to replace them.
            See my other reply for the other CapXon KM above.
            The rest are:
            Cheers!
            Rubycon YXJ/YXF would be my first choice for these, followed by Nichicon PJ and PM. I've seen some older small Nichi PM caps have issues with bung seals, so I'm still a bit weary of them, even though I do have newer ones and do still use them in repairs.
            BTW, Nichicon KL (UKL) is audio-grade, IIRC. So you can ignore those too.
            Pretty much when doing PSU recapping, ignore the 85C caps, unless you can't find anything else in stock.
            Now if I had to choose between a GP 85C Japanese brand and a "2nd tier" 105C non-Japanese brand, I'd probably go with the former, even if it doesn't quite "meet specs".
            • withalligators
              • Jun 2013
              • 267
              Momaka, thank you so much for this very detailed reply. I really, really appreciate it.
              Cheers!
              • David Stroe
                AOC CQ27G2U/BK - in need of data sheets
                by David Stroe
                I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
                I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
                Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
                Main Board: 715G9500-M0C-B00-005K
                T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
                If someone could please provide any of these data sheets, it would be awesome....
                05-31-2025, 11:12 AM
              • Raulnn
                clean hisense inner sheets
                by Raulnn
                Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
                01-22-2023, 05:19 PM
              • ajdrenter
                Picking caps for Antec SU-380
                by ajdrenter
                In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                https://www.badcaps.net/forum/showthread.php?t=14159
                It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                05-13-2023, 10:40 AM
              • withalligators
                Yet another Samsung 305T post - black screen w/backlight, occasionally works
                by withalligators
                Hey folks,
                I picked this neat monitor up from a recycling center years ago, and it worked fine for a long time. I know they are prone to T-con issues with the Altera chip, but I've yet to experience any symptoms of that going. I always perform scaling on the GPU though. It had occasionally thrown a black screen at me, that was usually reset by powering it off, and reseating the DVI-D cable in the sole input. I gave it to my brother who said the problem got worse, and it would be very difficult to get it to display a picture, it took lots of fiddling. As far as I understand him, it always...
                03-25-2022, 11:24 AM
                KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                by momaka
                For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                http://www.rmac.kingwin.com/products.../abt_650MM.asp
                I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                What mostly drew me into buying it is its 2x PCI-E power connectors...
                03-29-2022, 11:34 PM
