Cannot identify specifications of bad capacitors
  • climber109
    • 3
    Recently, five capacitors on my desktop's motherboard failed. For the past week or so, the computer had been randomly shutting down. I suspected a heat issue, so I checked the CPU temperature and found that the temperature went up to about 120 degrees Celsius when I stressed the CPU before turning itself off, well above the 65 degree maximum that AMD specifies. I thought reapplying thermal compound on the CPU might help, so I started to take off the CPU heatsink. As I loosened the last screw holding the heatsink to the motherboard, I heard a strange hissing sound. When I got the heatsink off of the CPU, I noticed that there was some earwax-orange colored crusty gunk (I'm not sure what the formal name is) all over the bottom of the heatsink. I looked on the motherboard to see what was under the heatsink at that point and I found five bulging capacitors with more of the crusty gunk on them. I think the heatsink may have been pressing down on the capacitors to prevent them from expanding, and the hissing was them finally expanding when the pressure from the heatsink was removed.
    I plan on replacing these failed capacitors myself, but I cannot identify the specifications of them from the markings on the cases. The failed capacitors have the markings "5B 680 4J" and no brand listed. I know little about capacitors, so I googled capacitor markings. Based on what I read, the 680 either means 68 farads (which from my understanding of capacitors seems way too high), or 68 picofarads (which seems way too low). I have no idea what the 5B and 4J mean.
    I have uploaded a picture of the failed capacitors. I have removed the orange gunk from them, but you can still see that they are bulging. Please help me identify the voltage, capacitance, and any other important information. Any other help or suggestions would also be appreciated.
    Thanks,
    Ben.
  • delaware74b
    • Apr 2009
    • 628
    Re: Cannot identify specifications of bad capacitors
    They look like 680 uF 4 Volt capacitors. The orange substance you removed was the electrolytic compound. As far as the operating temperature going above 120degrees C, I think that was a false reading caused by system instability from the bad caps.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • 31020
      680uf 4v
      • kaniki
        • 514
        what i find kinda disturbing is that you said that the heatsink was pushing down on those caps. before you put it back together, i would look at getting a new heatsink that does not touch the caps before you do more damage. The same thing is going to happen again if you put that heatsink back on again after replacing the caps if it is doing what you said it was.
          • 31020
          can we see the heatsink in a foto?
          it's not a damned zalman flower with 120mm fan is it?
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            This also might explain why your CPU temperatures were that high. As the caps started expanding, perhaps they pushed up on the heatsink just enough to detach it from the CPU core. If your CPU heatsink is indeed sitting flush on those caps, definitely listen to kaniki and get a different heatsink (unless of course you get new polymer caps that are lower than the originals).
            The "680" mark on the caps indicates that they are 680uF (micro-farads), while "4j" is likely the voltage code. Not sure what voltage it would indicate, though (I think it varies between manufacturers).
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i have been using sanyo sepc 560@4v polys to replace those.tc sells them in small qty in his store.
              • climber109
                • 3
                I uploaded a picture of the heatsink. It is a generic extruded aluminum block that came with the computer. I also uploaded a picture of the heatsink with the bad capacitors underneath. After looking at the motherboard again, only one capacitor is actually flush with the heatsink, and I think that is only because it is bulging.
                I cannot seem to find any replacements that are short enough to fit under the heatsink. The current bad capacitors are 8mm high, and the shortest replacements I can find are 12mm, which would not fit. I think I will just fold the leads and mount the new ones on their sides.
                I am looking at these as replacements. Would they be compatible?
                kc8adu, are you sure the Sanyo capacitors you mentioned would be compatible?
                • yyonline
                  • Jul 2009
                  • 692
                  Those are 8mm diameter x 12mm height. 12mm is too tall.
                  What is the diameter of the bad caps? From your photo, they look a little small to be 8mm diameter. In addition to the Sanyo mentioned earlier, I've included two candidates for replacement in both 8mm and 6.3mm diameter.
                  Chemicon PSE 6.3mm diameter x 8mm height
                  Chemicon PSC 8mm diameter x 8mm height
                  Decreasing the capacitance should be okay as polymer capacitors have lower ESR and higher ripple than electrolytic caps. However, I've never done a polymer cap mod myself, so I will let others speak to that.
                    • 31020
                    that design is a bad joke, the heatsink will cook the caps even if they dont touch!
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      what more would you expect from emachines/gateway?
                      btw i just recapped one of those with the same failure.
                      sanyo sepc 560@4 8x8mm.
                        • 31020
                        i'd actually be tempted to mount them on the other side of the board & cut a section from the metal behind the board!
                        • kaniki
                          • 514
                          I was thinking the same thing. even if they dont touch, there is no airflow to help cool it down uner there and the heat generated by the processor would just cook the cap being so close. I cant believe that they actually even made and used a board like that.
                          might be a better choice then putting them back where they were.. the only other choice i can think of is to get a new heatsink that barely covers the processor on that side, but good luck with that..
                            • 31020
                            a different sink or a mod with the trusty jigsaw wont work, they are too close to the damned mounting post.
                            • Colt45ws
                              • Jan 2009
                              • 174
                              The joke is they probably designed it like that intentionally.
                              • brethin
                                • Dec 2008
                                • 1907
                                The heatsink could be on wrong. Check the other side to see if the notch is the same size. It could be longer and deeper giving you more clearance and not touch the caps.
                                • larrymoencurly
                                  • Oct 2004
                                  • 960
                                  What about the 4 green-sleeved capacitors at the bottom of the photo on the left? Are they Sanyo WX series, and if so, shouldn't they be replaced with Sanyo WG series?
                                  • GizmoMonkeyTech
                                    • Sep 2012
                                    I know this is an ancient thread, but I am getting ready to replace the same caps (8mm tall, 680uF, 4V) on what appears to be the same motherboard.
                                    Would the above recommended caps still be recommended as the best replacements?
                                    The 4 green-sleeved capacitors are indeed Sanyo WX caps. They don't appear to bulging, but are they recommended to replace?
                                    I also have one Teapo SEK 470uF 10V cap that's bulging on here, but 13 of them that visibly look good.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      They should be fine.
                                      But why pay a $1 for those when you can get these for half of that?
                                      https://www.badcaps.net/store/produc...products_id=79
                                      Sanyo makes very reliable caps. I would say leave them.
                                      It's best to replace all of them, then. Or at the very least, the ones that may have been next to hot components.
                                      • GizmoMonkeyTech
                                        • Sep 2012
                                        Thanks for the info. I will be purchasing from badcaps
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • harp
                                          Metod for removing glued heatsink from fragile component
                                          by harp
                                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                          06-23-2025, 02:01 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
