Are these older style Sanyo Poly's?
  • jayjr1105
    • 281
    Pulled these from an AGP graphics card so maybe 2001 or so. They test fine with 0.00 ESR. Just curious. I assume Poly because no vent marks for expansion.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Are these older style Sanyo Poly's?
    Relevant: https://www.badcaps.net/forum/showthread.php?t=86837
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • 31086
      very old polymers - check the uf because it does decay on the old blue and purple sanyo's
      • jayjr1105
        • 281
        I did check them, within 10% and ESR was 0.00
        Ryzen 3600x
        FX-8802 Iron
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Oscons?
          PeteS in CA
          • jayjr1105
            • 281
            Oscons?
            Yes sir.
            Ryzen 3600x
            FX-8802 Iron
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Curious what graphics card you pulled them out of and was it working.
              Just beware that some old GPUs like the GeForce 3 and 4 series sell for crazy prices online right now. Sell one like that and you can afford to buy almost a bucket of new poly caps.
              Just FYI.
                • 31086
                i'v not seen oscons on gfx cards.
                loads on old intel server boards though.
                • jayjr1105
                  • 281
                  It's from a crappy AGP graphics card, It wasn't anything special. Yellow PCB, tiny little fan. I can look again when I get home. It's sitting in the scrap board box now.
                  Ryzen 3600x
                  FX-8802 Iron
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Oh, I've seen them on plenty of old nVidia cards from the GeForce 3 / 4 / FX era (and equivalent Quadro.) It varied a bit between who the card was made for, but I have at least one GeForce 4 TI 4600 card here with those OSCON caps (I think it's one of my dead ones - those tiny stock coolers on the TI4400/4600 overheat and eventually kill even the wire-bonded GPU die used on these cards.)
                    That's because back in the day of early AGP, video cards simply didn't have the crazy heat dissipation like they do nowadays (or even compared to the generation that followed - i.e. Radeon 9700/9800 and the GeForce FX 5800 "dust buster".)
                    Sounds like you have an ASUS or PixelView board by that PCB color. Whichever the case, those OSCONs were expensive caps then, so I would be surprised if this is some low-end card like an MX 420 or Riva TNT64 or MX4000. Sounds more like you have a GeForce 3 on your hands or maybe GeForce 4 TI 4200 if the card's PCB is fairly small. On the other hand, if the PCB is fairly long (for that period of video cards anyways), it may be a TI 4400 or 4600.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      Just FYI.
                      and to think I have one of these sitting in my storage
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        ^ For a second, I thought you re-posted a picture of my Leadtek GF TI4400, but then I realized I never posted it on BCN. (I guess that's another one to cue on my list of stuff to post, lol.)
                        You may want to get rid of the GSC / Evercon caps on it before selling it. That's how I got mine for cheap a few years back. The 40 mm fans were also extremely noisy with dry bearings. I've nearly fully restored it (needs a few temp caps replaced that I filled with old used caps) and it's a great retro AGP card. Runs a lot cooler than the stock cooler that comes with most TI 4400/4600.
                        You won't get 3DFX prices for it. But depending on the supply/demand at any time, they still usually go for $30 at a MINIMUM... and most of the time around $50 or more.
                        *EDIT*
                        Here is an example of how much one TI4600 is going for right now:
                        https://www.ebay.com/itm/GAINWARD-Ge.../284041423579?
                        **EDIT 2**
                        I think I'm hijacking the thread with the video card discussions. Sorry about that, I'll give it a rest.
                        • jayjr1105
                          • 281
                          Asus AGP-V7700/32M Rev 1.01
                          Ryzen 3600x
                          FX-8802 Iron
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            ^ Ah, GeForce 2 GTS. That's another classic I forgot about. Not as rare/sought after as the GeForce 3 and 4 series, but a good oldschool card nonetheless, especially if you ever plan to build an early Windows 95/98 era gaming PC. It may not have Glide support like the VooDoo GPUs, but it does beat a VooDoo 5.
                            https://www.anandtech.com/show/648
                            Anyways, sorry again, I'll stop with the GPU discussion sidetracking, I promise.
                            • ChaosLegionnaire
                              HC Overclocker
                              • Jul 2012
                              • 3264
                              • Singapore
                              ah, i see. its a gf2 gts gpu most likely. can still sell for a small tidy sum online.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                IIRC, I have. They were likely common on GeForce 4 Tis.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  *EDIT*
                                  **EDIT 2**
                                  It is a 4600.
                                  But if you want to talk retro, I also have a working Voodoo 5 5500 that TC has been trying to get his hands on for weeks
                                  I have a TNT2 M64, worth anything lol (it's not)
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    I just looked and it's the A250 Ultra. 4600 128m
                                    I appearently already recapped some of it years ago and didn't remember. Some were polymers.
                                    • EFritz20
                                      Capacity challenge for Sanyo OS-CON 510uf 4v on older GPU
                                      by EFritz20
                                      Hi guys/gals,
                                      I have this geforce 2 card that needs a recap.
                                      It contains some nichicons but also some purple Sanyo OS-CON 510uf 4 volt according to the label. Unfortunately the product range is not on the label and i also cannot find the 510uf specs in their (older) PDF datasheets/catalogs using google.
                                      Besides that, i can't find any matching 510uf these days either.
                                      As a general rule I know you can deviate about 20% max on UF (510uf in this case), but what would/could happen if I were to use 560uf for it, since this cap can also deviate 20% and might have...
                                      05-30-2021, 12:56 PM
                                    • MagicSmoke
                                      Older Sanyo DP50747 VE Voltage High
                                      by MagicSmoke
                                      Working on an old Sanyo 50" that has Samsung innards. Backstory.. saved from dumpster years ago, partial recap on SMPS, Replaced one of two small caps on X-main, set worked great for about 3 years.
                                      Then recently it started to take a few minutes from power on to display a pic and sound, worked like that for about 3 months, then Smps would click once and then nothing, it will not shut itself off but nothing happens.
                                      So pulled PS replaced all the caps, even the large mains. PS works and has all stable rated voltages present when switched on. TV has sound (static) when...
                                      12-02-2020, 11:56 PM
                                    • acedogblast
                                      Soldered wifi upgrade to wifi 7 BE200D2W from older AX2xx based moduels.
                                      by acedogblast
                                      I have finally found a source for Intel's BE200 wifi soldered "1216" sized modules (not the larger 2230 removable M.2 modules) and I was wondering if it is possible to swap the older AX2xxD2W wifi 6/6e with this new wifi 7 module on a laptop. Supposedly both the BE200D2W and the older AX2xxD2W chips use the standard "M.2 1216 footprint" but with an additional inner-ring of pads. We have schematics of various laptops that use the AX2xxD2W chips on this forum. What we need is a schematic of a laptop that uses the new BE200D2W to check if the pinout is identical or not. Do anyone...
                                      11-16-2024, 10:19 PM
                                    • cj_reha
                                      Mystery 80s Sanyo cap - perhaps polymer?
                                      by cj_reha
                                      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                      01-06-2023, 09:24 AM
                                    • DarrenHD
                                      Firmware for older Toshiba TV 22CV100U
                                      by DarrenHD
                                      HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                                      I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                                      https://support.dynabook.com/support...tentId=2865076
                                      Thanks!
                                      06-16-2025, 11:56 AM
