Capacity challenge for Sanyo OS-CON 510uf 4v on older GPU
  • EFritz20
    • Nov 2020
    • 11
    • BE
    Hi guys/gals,
    I have this geforce 2 card that needs a recap.
    It contains some nichicons but also some purple Sanyo OS-CON 510uf 4 volt according to the label. Unfortunately the product range is not on the label and i also cannot find the 510uf specs in their (older) PDF datasheets/catalogs using google.
    Besides that, i can't find any matching 510uf these days either.
    As a general rule I know you can deviate about 20% max on UF (510uf in this case), but what would/could happen if I were to use 560uf for it, since this cap can also deviate 20% and might have a uf of 560 x 1,20?
    I am thinking about recapping the whole card using polymers, just to be sure it gets low ESR. Also given the fact that I don't know the exact specs of this Sanyo OS-CON 510uf 4v cap and I also don't know what the caps purpose is. I know it might not be necessary but Polymers are pretty affordable these days and I will be sure of Low ESR since Low ESR electrics aren't available anymore.
    I read alot about capacitors yet i'm still pretty new regarding to my experience. What would you advise?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Capacity challenge for Sanyo OS-CON 510uf 4v on older GPU
    The rated capacitance will not be 510uF post a picture of the cap.
    • EFritz20
      • Nov 2020
      • 11
      • BE
      Its exactly the same as these ones:
      https://silmic.ir/wp-content/uploads...54-600x600.jpg
      https://silmic.ir/wp-content/uploads...47-600x585.jpg
      Its a different card but you can see them on here too:
      https://www.ixbt.com/video/images/v8...200d-front.jpg
      • xnRS
        • Feb 2021
        • 85
        • Belarus
        Can you give us the photo of those caps, there might be their series and I could get info from datasheets...
        • xnRS
          • Feb 2021
          • 85
          • Belarus
          Also they are could be soldered on board not on factory... There is no info in datasheet for SP Sanyo OS-CON caps... check the soldering points under caps on board and compare to other soldering points
          • xnRS
            • Feb 2021
            • 85
            • Belarus
            Also here was other post with same caps, one guy recomended 560uf 4v caps. so I think I would recomend Panasonic/Sanyo 4SEPC560M. Same OS-CON series but Polymer ones
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              I was wrong then, still can't find a datasheet for that old series.
              Just go with 560uF as suggested.
                ASUS 510UF-EJ309T Notebook Specification for Upgrade or Repair
                This specification for the ASUS 510UF-EJ309T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 510UF-EJ309T boardview and 510UF-EJ309T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
                09-06-2024, 09:32 AM
                ASUS 510UF-EJ579T Notebook Specification for Upgrade or Repair
                This specification for the ASUS 510UF-EJ579T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 510UF-EJ579T boardview and 510UF-EJ579T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
                ASUS 510UF-BQ298R Notebook Specification for Upgrade or Repair
                This specification for the ASUS 510UF-BQ298R Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 510UF-BQ298R boardview and 510UF-BQ298R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
                09-06-2024, 06:31 AM
              • MagicSmoke
                Older Sanyo DP50747 VE Voltage High
                by MagicSmoke
                Working on an old Sanyo 50" that has Samsung innards. Backstory.. saved from dumpster years ago, partial recap on SMPS, Replaced one of two small caps on X-main, set worked great for about 3 years.
                Then recently it started to take a few minutes from power on to display a pic and sound, worked like that for about 3 months, then Smps would click once and then nothing, it will not shut itself off but nothing happens.
                So pulled PS replaced all the caps, even the large mains. PS works and has all stable rated voltages present when switched on. TV has sound (static) when...
                12-02-2020, 11:56 PM
              • acedogblast
                Soldered wifi upgrade to wifi 7 BE200D2W from older AX2xx based moduels.
                by acedogblast
                I have finally found a source for Intel's BE200 wifi soldered "1216" sized modules (not the larger 2230 removable M.2 modules) and I was wondering if it is possible to swap the older AX2xxD2W wifi 6/6e with this new wifi 7 module on a laptop. Supposedly both the BE200D2W and the older AX2xxD2W chips use the standard "M.2 1216 footprint" but with an additional inner-ring of pads. We have schematics of various laptops that use the AX2xxD2W chips on this forum. What we need is a schematic of a laptop that uses the new BE200D2W to check if the pinout is identical or not. Do anyone...
                11-16-2024, 10:19 PM
