HP D530 Part Deux
  • BigAlNZ
    • Mar 2008
    • 65
    HP D530 Part Deux
    Well I tried a new power supply on the HP D530 that wont boot, no fans etc.
    Still wont go. I noticed that the +5vSB led is flashing. Now apparently this means it wont start because the +5vSB is overloaded. I did a little test and noticed that there was virtually no resistance between GND and PURPLE (+5 SB) on the motherboard power ATX connector, in otherwords SHORT!
    I have bench tested this motherboard and still same problem, so its not a case short. The caps look ok, but the D530's are known for bad caps.
    So my question is this - could a symptom of bad caps be a short on the +5vSB rails?
    Cheers
    -Al
  • lucky13
    • Aug 2007
    • 412
    Re: HP D530 Part Deux
    Have you ohmed the MOSFETs?
    I suppose you already carefully inspected the caps near the CPU VRMs?
    • BigAlNZ
      • Mar 2008
      • 65
      Sure did with respect to the caps.
      Ohmed the MOSFET's - can you explain a little more?
      In circuit or out?
      What legs?
      • BigAlNZ
        • Mar 2008
        • 65
        Here are some pics of the moboif it helps?
        The little square black things I think are MOSFET's are labelled:
        06N03LA
        AU417
        • BigAlNZ
          • Mar 2008
          • 65
          Oh and I almost forgot these little suckers (look like mosfets to me) were on the bottom of the mobo underneath and near the VRM row of caps.
          06N03LZ
          AI423
          They are seperate from the motherboard bottom plate by a large peice of rubber which had a slightly wet and semi sticky substance on it...I had wondered about this possibly creating a short when I first took the mobo out to bench test it.
          Again, they look like MOSTFETs but not sure how to test? I have heard they often go shorted between GS? or SD? or both?
          Cheers in advance
          -Al
          • BigAlNZ
            • Mar 2008
            • 65
            Tried to test MOSFETs using following procedure. The expected result from the instructions is in the brackets:
            06N03LA
            1) Use DVM in diode test position
            2) Holding red lead on S
            3) Black lead on D. Reading climbs to 557 after about 2-3 seconds. (Instructions say reading should be 500-800)
            4) Put black lead on G. Reading is 13. (Instructions say should be open)
            5) Hold black lead on S
            6) Put red lead on D. Open Circuit (reading 1) (should be open?)
            7) Put red lead on G. Reading 13 (should be open?)
            8) Put red lead backon D. Open (reading 1) (should be low value close to zero?)
            06N03LZ
            3) Black lead on D. Reading 3 (Instructions say reading should be 500-800)
            4) Put black lead on G. Reading is 737. (Instructions say should be open)
            6) Put red lead on D. Reading 3 (should be open?)
            7) Put red lead on G. Reading Open (should be open?)
            8) Put red lead backon D. Reading 3 (should be low value close to zero?)
            Note sure if this testing procedure is correct and if it indicates good or bad?
            -Al
            • BigAlNZ
              • Mar 2008
              • 65
              PS: Is it ok to test in circuit?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                what is this "new" power supply?
                and what meter did you use to test?
                most +5stby shorts are fried southbridges.
                iirc a standard atx supply will run that board so try another psu.
                its not a dead short if the onboard led is blinking.
                • BigAlNZ
                  • Mar 2008
                  • 65
                  I got another D530 PSU out of another D530 thinking initally the proble was the PSU. When the second D530 PSU didnt work I got a 3rd power supply I had lying around (but which I know to be good) and tried it. Both power supplies simply gave the +5vSB led blinking - so yes I have tried a standard ATX PSU.
                  The resistance between ATX power connector on motherboard for Purple pin and GND is in the order of 5 Ohm so not a dead short but very close!
                  Although it may not be the problem kc8adu can you make any comment on the MOSFET testing methodology and results?
                  Cheers
                  -Al
                  • MXM
                    • 430
                    • Unknown
                    i was wondering if you fixed the 5vsb flashin led problem, i got this on a d530 sff, is not the psu cause i tested it on other mobo.... any ideas??
                    thanks,.
                    ps. are the testing procedure mentioned above correct?
                    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                      • 30934
                      the whole thread is bullshit,
                      the 5v standby has nothing to do with the vrm or fets.
                      it's used for the main chipset and goes through a regulator.
                      look for 3.3v regulators, maybe type 1117
                      meter them for shorts.
                      or if you want to be hardcore, hook the 5v standby & ground on the mobo to a variable bench supply,
                      set it to 5v and 500ma
                      then see if you can find anything getting hot.
                      if not - wind it up another 500ma and repeat looking for something hot.
                      just keep repeating till something starts to cook.
                      • BigAlNZ
                        • Mar 2008
                        • 65
                        thanks,.
                        No I replaced the mobo in the end. stj's suggestion is not bad, but it may be a bridge failure and youll need BGA gear to repair.
                        -Al
                        • MXM
                          • 430
                          • Unknown
                          thank you...
                          i got a d530 sff that shuts down eventually no particular pattern, it just shuts off... i changed some mobo blown caps and still doing it, i suspect the psu might be the one causing this.... do u have info related on this that could help me out a little? ive done the googling no much success...
                          Thanks.
                          • duhmacguru
                            • Dec 2008
                            MXM: It could be the CPU overheating. I tested with my d530 mobo and if the CPU overheats - i.e no heatsink, bad cooling, etc. the PC just shuts off. If you can, download SpeedFan (it's free and for Windows) and post back _all_ the reported temperatures and voltages just before it crashes.
                            BTW: the CPU I pulled from it (Pentium 4 2.66GHz) seems to constantly report a CPU temperature of 105 centigrade all the time unless I push really hard on it. I
                            Ed
                            Oh, and to all D530 owners: I advise you get a good quality ATX PSU and shove the D530 mobo in a tower case. Also the 'speaker' output is very very powerful - i.e it drives a KEF Coda III speaker to mechanical distortion!
                            • DynaxSC
                              Extreme High Current & Low Voltage Short Killer ??
                              by DynaxSC
                              Hi Folks
                              I'm looking for a extreme high current short killer solution for a reasonable cost.
                              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                              After taking off the socket, the shorts dissappear again.
                              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                              10-15-2024, 10:13 AM
                            • Stephen
                              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                              by Stephen
                              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                              02-06-2025, 12:03 PM
                            • Victor Moreira Silva
                              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                              by Victor Moreira Silva
                              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                              Well, my decice specs are the following:
                              Model: Acer Nitro 5 AN517-54-55T5
                              CPU: Intel Core i5-11400H
                              GPU: NVIDIA GeForce GTX 1650
                              Motherboard: GH51G LA-L181P Rev:1c
                              The symptom:
                              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                              05-26-2025, 10:49 AM
                            • aaronkatrini
                              Help me find the short circuit on this WORKING Nvidia GTX1650
                              by aaronkatrini
                              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                              04-18-2024, 03:15 PM
                            • Geeker007
                              9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                              by Geeker007
                              Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                              I am new to electronics repair, so my queries could be naive but I am ready to learn.
                              So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                              01-28-2025, 03:31 PM
