Cap Identification please.
  • flewpastjupiter
    Antex soldermaster
    • Oct 2009
    • 30
    Hi, can anyone identify this cap please. It sits under the cpu heatsink on a Asrock 775i65g motherboard. Pc still works perfect but I want to replace the cap before it causes other problems.
    • 31015
    Re: Cap Identification please.
    680uf 4v
    and you need to use a polymer cap that is not too tall or it will hit the heatsink.
    • flewpastjupiter
      Antex soldermaster
      • Oct 2009
      • 30
      Thank you stj. BTW do you happen to know the make of the cap? so I can match the specs.
        • 31015
        no, just get a polymer - the spec will be far better than even the best electrolytics
        • Behemot
          • 4845
          • CZ
          You can get with 2.5 V too, that's gonna be on some Vcore rail.
          • PeteS in CA
            • Aug 2005
            • 3579
            • USA, Unsure of Planet
            Seeing how the thing vented, I wonder if it's an ultra-low impedance electrolytic in what looks like a polymer package.
            Replacing it with a real polymer cap, really soon, would be good. Is anyone familiar with Jovian distributors?
            PeteS in CA
              • 31015
              hey flewpast' can we have a foto of the whole cpu area?
              • flewpastjupiter
                Antex soldermaster
                • Oct 2009
                • 30
                yes no problem, here you go.
                VRM Input - 4x Nichicon HM 1000uf 16v A0632
                VRM output - 5x Panasonic FJ 1500uf 6.3v + fake poly 680uf 4v
                  • 31015
                  what's the diameter of the bad cap - 8mm? 10mm?
                  and the height - for clearance.
                  • flewpastjupiter
                    Antex soldermaster
                    • Oct 2009
                    • 30
                    The diameter is 8mm and height about 9mm.
                      • 31015
                      order this.
                      http://uk.rs-online.com/web/p/alumin...itors/8392114/
                      • Behemot
                        • 4845
                        • CZ
                        ASRock 775i65G, somewhat strange PCB layout of rev. 2.04. Interesting board that is…
                        If you have any dead MoBo or graphics around, you can scavenge polymers from that, anything from 330 to 1000 uF 2.5-6.3 V would do, no need to go shopping for one piece. If you want better stability especially with overclocking, might as well fill those other two vacant positions, and the ceramics C1717 (?) to C1720.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Originally posted by stj
                          This would be a great replacement too:
                          https://www.badcaps.net/store/produc...products_id=79
                          It's interesting to note that the older PCB revision on Asrocks website does not have any of these capacitor positions populated:
                          http://www.asrock.com/mb/intel/775i65g/
                          • flewpastjupiter
                            Antex soldermaster
                            • Oct 2009
                            • 30
                            Thanks for the recommendation but I was thinking of ordering these http://uk.rs-online.com/web/p/products/7149004/ with them being a bit more durable 5000hrs and the cap sitting under the heatsink.
                            Thanks for the reply. I've just had a look at an old Radeon 9700 pro and a Geforce 5900xt both are dead and all caps on them are surface mount ones.
                            If a 330 uf cap would definetally be enough I'll have another look on Rscomponents. Do you happen to know any ebay sellers that have genuine caps?
                            BTW what caps would be suitable to use in the two vacanct positions?
                            • flewpastjupiter
                              Antex soldermaster
                              • Oct 2009
                              • 30
                              Thanks for the help, but I'm in the uk and the shipping cost isnt worth it, unless I was getting a large amount of caps.
                              • Behemot
                                • 4845
                                • CZ
                                Basically any combination of polymers, really. Of course generally regarding VCore VRM, the higher the capacity the better. On the other hand polymers have much lower ESR and higher RC than even the best wet lytics so that's why you an go down with capacity without issues.
                                If you can get some 820/2.5 V ones for cheap you can use those, that would be one of the best choices. On the other hand not that the CPU stability, which itself (any of the Core 2 architectures ones) could handle 1066 MHz FSB any day of the week, would be an issue here, unlike with the chipset which supports only 800 natively and 1066 indeed is overclock for it…
                                Would not kill 9800 Pro or 5900XT anyways, those are collectors items these days, one of the most powerfull cards of theirs generations. Especially if AGP
                                Anyway, I can send ya pulled polymers from here, always got some. I don't carry new ones yet as I have little use for them yet and still have income of some from all the dead boards
                                  • 31015
                                  so what is the voltage on the board?
                                  you dont know - so why the 2.5v caps?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Socket 775 - gonna be well under 1.5 V. Even my 478 Press-hot only runs at 1.33 V.
                                    • flewpastjupiter
                                      Antex soldermaster
                                      • Oct 2009
                                      • 30
                                      I've just checked and its a 9700pro not 9800pro. I had it in the oven a few years ago to try to fix it and the 5900XT just BSOD's when windows loads.
                                      I don't know the voltage, but I thought a 2.5volt cap would be ok for the cpu vcore.
                                        • 31015
                                        what if it's not on the vcore?
                                        what if it's on the 3v3 line?
                                        im not saying it's not on vcore - i'm saying dont assume anything without checking .
                                        not if you intend to downrate the parts anyway!
                                        • sunofra78
                                          ASROCK B460 Steel Legend Component Identification #2
                                          by sunofra78
                                          Would anyone know what this component may be? It's on an ASROCK B460 Steel Legend Gaming PC Motherboard. The writing on it is 29 7B / 43N.
                                          Thanks....
                                          11-21-2024, 09:33 PM
                                        • harp
                                          Metod for removing glued heatsink from fragile component
                                          by harp
                                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                          06-23-2025, 02:01 PM
                                        • Ven
                                          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                                          by Ven
                                          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                                          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                                          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                                          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                                          07-08-2024, 09:32 AM
                                        • Exim
                                          ASRock N100M, no picture no boot, but semi-alive
                                          by Exim
                                          Hi guys,
                                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                          ASRock N100M special features:
                                          - CPU soldered to board, small Intel 12th gen
                                          - iGPU
                                          - four POST LEDs
                                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                          Symptoms:
                                          - no picture/signal on any of the display connectors,...
                                          04-01-2025, 02:36 PM
                                        • MasterCap
                                          What IC does AsRock usually use to make the PWM signals for GPU fans ?
                                          by MasterCap
                                          I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
                                          Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
                                          But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
                                          12-28-2024, 08:42 AM
