Request: Full BIOS dump for ASRock Z790-CX (DDR5)
  • gabrieljma1
    • Jun 2020
    • 15
    • ecuador
    I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
    The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
    I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete image.
    I need a complete BIOS image (bin dump) that can be programmed directly into the SPI chip. Any help or shared dump from the same board (or compatible ASRock Z790 model) would be greatly appreciated.
    Thanks in advance!
  • m1ch43lzm
    • Mar 2019
    • 782
    • Peru
    Have you tried with a known good PCIe GPU? The 14900KF doesn't have integrated GPU...
    Your motherboard supports 14900KF since initial BIOS version 12.09
    https://www.asrock.com/MB/Intel/Z790...dex.us.asp#CPU
    BIOS from ASRock website is full BIOS image including Descriptor, GbE, ME and BIOS regions, the problem is elsewhere
    Click image for larger version  Name:	meanalyzer Z790-CX.png Views:	0 Size:	15.3 KB ID:	3741521
    * If Gigabit Ethernet doesn't work, hope you have a BIOS backup before you flashed the BIOS from ASRock website with your programmer, MAC address has to be transferred as you have Intel® I219V Gigabit LAN
    • Aliencomputres
      • Aug 2019
      • 214
      • România
      14900KF doesn't have integrated GPU-use dedicated video card!
      • gabrieljma1
        • Jun 2020
        • 15
        • ecuador
        I was always testing with an RTX 5070 Ti, but it turned out that it was the one causing the problems. The support firmware works perfectly. Thanks for the help.
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • subzerillo
          Asrock H510M-HDV/M.2 SE bios dmi area from dump
          by subzerillo
          Hello.
          I'm wondering how can I check and extract de dmi area from a bios backup.
          I know it depends on the brand and model of the motherboard. Is there some guide that could help me understand and extract the dmi from the original bios dump to a new bios file.
          The motherboard is H510M-HDV/M.2 SE
          Attached is:
          h510m is the dump bios
          h510mhms1 is the downloaded bios from the website...
          10-09-2025, 02:23 PM
        • khanhtq0
          Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
          by khanhtq0
          I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
          I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
          I suspect the original Intel ME and descriptor...
          08-06-2025, 02:14 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
          by haitham sharabati
          Hello engineers 😀,
          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
          💀 Problem:😅
          - Device shows “Administrator Password”...
          08-07-2025, 04:54 AM
