NEED Bios File ASROCK H61M-VS4 REV.G/A 1.01
  • DOBBELDUNK
    • Jul 2025
    • 4
    • Indonesia
    Mobo turn on, HSF on but no display, blank only in monitor.
    Here is bios backup of asrock h61m-vs4 rev. g/a 1.01
    • 22191
    AsRock support - https://www.asrock.com/mb/Intel/H61M-VS4/index.asp#BIOS
    • DOBBELDUNK
      • Jul 2025
      • 4
      • Indonesia
      Originally posted by SMDFlea
      Thank you for your reply. I have previously tried flashing with the BIOS file from the Asrock website according to the motherboard type, but the result was a total died , motherboard can't on, no HSF on, and definitely no display, only a blank/ black screen on the monitor.
      Maybe I mistyped it, it's not a regular BIOS file that I need, but a BIOS dump file for Asrock H61M-VS4 Rev. G/A 1.01.
      • peste
        • Dec 2016
        • 13853
        • ROMANIA
        try..
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
