Help identifying component
  • OsamaObama
    • Jan 2017
    • 10
    • Israel
    I'm almost certain that it's a resistor however the code on it is invalid it's off a motherboard if it's any help there is another one with exactly the same code. Many thanks for looking.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Help identifying component
    Perhaps this?
    • OsamaObama
      • Jan 2017
      • 10
      • Israel
      It could be a nand gate but having a look on the internet doesn't show any nand gates like this. Maybe it could be a capacitor???
      • R_J
        • 9535
        Looks like its only connected at the ends, could it just be a inductor (coil) How does it check for resistance?
        Or maybe a diode?
        EDIT: what is the (5 pin) device it is connected to, that might also help
        • diif
          • Feb 2014
          • 6978
          • England
          I think you're right with resistor. Can you remove it with hot air and measure it's value.
          • OsamaObama
            • Jan 2017
            • 10
            • Israel
            It's has no voltage across it and the resistance was tiny around 0.2 ohms. I'm going to remove it tommorow so I'll let you know.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              measure millihenries across it with your meter .
              another thought it might be a fuse .. check schematic or draw it out yourself if poss .
              • noppa
                • 41
                Looks like a resettable fuse like one of these :
                http://www.littelfuse.com/products/r...ace-mount.aspx
                • R_J
                  • 9535
                  I do believe it is a resetable fuse by Bourns maybe 2 amp
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    You could very well be correct. It does appear to connect to a thick pad. It is kind of hard to tell because of the black circle.
                    • OsamaObama
                      • Jan 2017
                      • 10
                      • Israel
                      Thanks for all the help you have given me it defiantly is a resettable fuse.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Thanks for letting us know.
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          • USA, Unsure of Planet
                          It also could be a current sense resistor, which typically are very low value.
                          PeteS in CA
