Decon garbage
  • Cartel
    • Feb 2006
    • 112
    Decon garbage
    Repairing Behringer EUROLIVE B1500D-PRO
    They used the crappiest caps ever...decon and ksd
    • 31294
    Re: Decon garbage
    85' caps in a switching supply - insane.
    • R_J
      • 9625
      Re: Decon garbage
      they are what puts food on the table for techs.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: Decon garbage
        Nasty Ive seen a fair few of these fail, also can you upload pic after recap ?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Decon garbage
          decon=rat poison
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Re: Decon garbage
            Ah--But!
            What you gotta consider is--Just How many Hours/Years on this thing? Modern electronics place MUCH more strain on its components than any stuff made say even only 30 years ago.
            If say only 1-2 years life,--Thats unacceptable.
            If however its say 6 years, Or More--What you griping about? Change the buggers, charge your repair fees and move on!
            6-8 years may well be 10-20,000 hours use. Not even the best consumer (Note--NOT Professional or aerospace) grade caps are rated for 20,000 hours, Best you'll get in consumer grade crap is 10K!
            You wanna spend $30 or much more bucks Per Cap for Military/Aerospace?--Nah, Didn't think so, and consumers wont either, especially as the item is designed-life anyway and will soon be superseded/made obsolete, by summit much better and prolly cheaper!
            TELEFIX
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              Re: Decon garbage
              Those endurance tests rate (and test) the caps at their maximum temperature (105°C), maximum voltage, and maximum ripple current, for thousands of hours, continuously (24/7), from the date the caps are manufactured. Theoretically, at lower temperatures and lower ripple currents, you should be able to extend the life of the cap considerably, but those continuous endurance tests don't take into account the unwanted chemical reactions and processes that take place during non-powered storage (although heat does expedite chemical reactions). The shelf life test has often been much shorter than the load life test (500 to 1000 hours continously at the rated temperature - that's anywhere from over 2 weeks to over a month).
              Using 85°C GP capacitors on the output of a SMPS is indeed a gross misapplication, but I'm pretty sure the fact that they are Decon made their failure all the more a likelihood.
              • Cartel
                • Feb 2006
                • 112
                Re: Decon garbage
                I'm sorry I deleted the pics but its the 8 caps in this picture.
                I had nippon and elna on hand
                4-470uf 25v and 4-470uf 35v
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Re: Decon garbage
                  Yup, Behringer loves to use Decon caps. But you got extra-screwed with those 85°C-rated caps.
                  I have an Europower EPQ1200 in the closet full of these Decon caps as well, except mine are the SHL series, which are supposedly their low ESR series rated for PSU use and rated for 105°C. I haven't recapped it, mainly because they are quite big and will probably cost quite a bit... and I don't use that amplifier very often (maybe take it out of the closet once a year), so I that's why it's not recapped yet.
                  CRT monitors and TVs often used 85°C caps and rarely had issues. Mostly small caps drying out on the neck board - but you know how hot that board can get as it's attached to the back of the tube (and very near the heater). That said, I have yet to see a Sony CRT TV or monitor with bad Nichicon VR caps. Or a Panasonic with its own Panasonic general-purpose caps.
                  Exactly.
                  You can bet that general purpose caps from the big Japanese manufacturers would have lasted much longer.
                  • magneh
                    Behringer Eurolive B205D repair - help identifying transistor
                    by magneh
                    Hello
                    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                    Still, I need to replace this transistor....
                    06-18-2025, 02:34 AM
                  • markks
                    Behringer Eurolive B115D strange high voltage
                    by markks
                    Friend gave eurolive b115d PA speaker that wouldn't power on. I replaced a cap and it powered on. However once the metal cage that encloses the power supply board was screwed back to the control/faceplate the lights pulse on and off and no sound.
                    Works fine when not screwed back together.
                    I probed between metal cage and control/faceplate and I am getting a high voltage of 75v ac.
                    Any thought always appreciated!
                    03-31-2023, 04:28 AM
                  • GerryT
                    Behringer Eurolive 115W Schematic needed
                    by GerryT
                    Trying to repair SMPS issues with two of these units.
                    10-12-2023, 10:08 PM
                  • Longon
                    Behringer Pro Mixer DJX-750
                    by Longon
                    Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                    08-11-2025, 02:17 PM
                  • brad2157
                    Decon SH PET Capacitors for “Klipsch The Fives”
                    by brad2157
                    I’m working on re-capping the power board caps on a Klipsch The Fives audio speaker system. I can’t locate a replacement for these original caps that are labeled “Decon SH PET”. I have three of these on the board with the electrolytics. They are supposed to be a film type capacitor, but they look like a radial mount electrolytic. Everything I find they look completely different, usually a square type body. The two values I need are 16V 470uF and 35V 47uF. I’ve got all the other caps in my cart already from Mouser, so if there’s a replacement there, I would prefer to order from...
                    10-21-2024, 09:47 PM
