Behringer Eurolive B115D strange high voltage
  • markks
    • Mar 2015
    • 5
    Friend gave eurolive b115d PA speaker that wouldn't power on. I replaced a cap and it powered on. However once the metal cage that encloses the power supply board was screwed back to the control/faceplate the lights pulse on and off and no sound.
    Works fine when not screwed back together.
    I probed between metal cage and control/faceplate and I am getting a high voltage of 75v ac.
    Any thought always appreciated!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8221
    Re: Behringer Eurolive B115D strange high voltage
    Probably something shorting out to gnd. Maybe a heat sink or something, due to a missing insulator or something.
    • markks
      • Mar 2015
      • 5
      Ugh, that was my original thought so I took apart again and same results. Hopefully 3 times a charm. Will meticulously look again. Thanks
      • budwich
        • Jul 2015
        • 3097
        put in one screw / bolt at a tune and see which one starts the problem.
