What Cap size fails most often?
  • Bishop
    • Apr 2009
    • 99
    Last night after watching a car race everything on the Dish Network box was working fine. Before I could turn the Sat box on this morning we lost power for about 5 seconds.
    Everything seemed OK until I turned the Sat box on to watch another car race, but the sat box was dead.
    I pulled the box and took the motherboard out and found a Jamicon 25v 100uf cap had buldged, I guess during the blackout.
    I had spare Rubycons so I replaced the bad Jamicon cap, and the Sat box is working again and Sundays race is on right now.
    It made me wonder two things.
    Is there a brand that fails most often, and is there a Cap size that fails more often than others?
  • Bishop
    • Apr 2009
    • 99
    Re: What Cap size fails most often?
    And is there a brand and size you keep in stock most often?
    • Mint Waxed
      • Aug 2016
      • 35
      The Japanese have the best reputation for quality control even though many are manufactured in low wage countries on their behalf. By nature of their construction and materials used, all electrolytic types are prone to failure. A lot depends on quality control during the manufacturing process and the operating conditions of the equipment. That's why most everyone who has been involved in the electronics hobby or repair prefer units rated at 105C. Also capacitor types designed for high temperature are available such as the Panasonic FC series. As for bulging, it has probably been slowly building pressure for quite a length of time. In my opinion, it was not actually caused by your power glitch. That issue would be best addressed by using spike protected outlet strips or if you can justify the cost, a UPS also known as APC for backup power.
      • R_J
        • 9625
        Had you opened the sat box before the power bump you would have seen the same buldged cap. It was on its way out for some time but as long as there is constant power to the circuit it will usually stay running, once power is removed the power supply won't start up properly. Thats why people always blame the power companies for the failure but its usually not there fault, the same thing would have happened if you unpluged the box and pluged it back in again.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Seems like D8mm caps...because they're usually the smallest sized filtering caps. The ones smaller aren't in as critical of areas and the ones that are 10mm or bigger are large enough to be able to absorb or handle heat better.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            not really. an example are those D10mm 3300uF kzg caps which are also the worst offenders at leaking/bulging. probably something to do with too much water being contained in those large can size caps.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Well, KZG can't be saved by any scenario, I thought that was implied
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                Jamicon doesn't fare well with heat as this thread markedly exemplifies.
                Nope. Well, higher water content does reduce the boiling point of the electrolyte, but if KZGs lacked the necessary corrosion inhibitors to combat the aggressive H2O base electrolyte, then KZE would have issues too. Not of the same magnitude, but issues nevertheless (KZG is high in water content, KZE medium). Yet it takes a LOT of heat to make a KZE bulge and it's rare for that series to fail. And I would argue that the ratio of KZGs and KZJs that do and don't bulge is very random. Although I do wonder if the faulty run of HMs and HNs had that issue because much more so than KZG and KZJ, they are notorious for failing with very high capacitance readings and high leakage current (high vloss), which either means the aluminum oxide has dissolved into the electrolyte, the electrolyte has broken down and can't provide enough oxygen to correct defects in the oxide film, or the water-base electrolyte is attacking the aluminum oxide and will eventually cause foil corrosion because of missing or insufficient additives and compounds.
                It all depends on how stable the electrolyte is. Exceptionally stable electrolyte won't need many depolarizers, hydrogen absorbers, and special additives to reduce the likelihood of failure. Heat does accelerate all chemical reactions, but that's all it does. It is an expeditor of a chemical reaction (the gradual build up of pressure and outgassing as the result of unstable chemistry AKA bad electrolyte, but impurities in the native oxide barrier and porous oxide film can slowly cause it too) that will eventually occur anyway. 8mm capacitors do have less surface area to dissipate heat, thinner dielectrics, and lower ripple ratings, which means that the cathode foil will oxidize (or be formed with a reverse voltage) at a lower current, and that familiar pressure and hydrogen gas we all love will follow. This is why it's a bad idea to use 8mm capacitors from less than esteemed brands on the output of the standby flyback converter in PSUs. (oh Teapo, where art thou? ) Or in Dish Network boxes...
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • m1ch43lzm
                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                  by m1ch43lzm
                  Hi everyone
                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                  There's also an extra OTP Secu.R...
                  09-06-2025, 05:47 PM
                • dragometin
                  Hitachi 40HYC42
                  by dragometin
                  TV Model: Hitachi 40HYC42
                  Power Supply: 17IPS71
                  MainBoard: 17MB95M
                  Panel: VES400UNDS-2D-NO3
                  When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                  I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                  Is there any variants on 17IPS71 power supply's?
                  UART output pins 10 and 12 on scart connector:
                  Code:
                  12:24:04.595
                  08-08-2024, 05:53 AM
                • DeanWy
                  WD Sentinel DS5100 (NAS) boot issues
                  by DeanWy
                  I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                  It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                  There...
                  07-30-2024, 04:13 AM
                • ahmedtou
                  HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                  by ahmedtou
                  help me please
                  I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                  When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                  I will share all the details with you, including the disc information.
                  Code:
                  HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                  Current Profile: BD-R
                  Disc Information:
                  Status: Empty
                  State of Last Session: Empty
                  Erasable: No
                  Free Sectors: 12,219,392
                  Free Space: 25,025,314,816 bytes
                  Free Time: 2715:27:17 (MM:SS:FF)
                  Next
                  08-27-2025, 08:49 AM
