I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
There is a BMC onboard (ASPEED AST2300) to which I can connect through a serial connection. There's a bmcport80 driver there developed by WD which does the BIOS checks and switches between primary and secondary if the primary fails (it seems to do that by using GPIO, see decompiled code below).
In the BMC logs I noticed that mounting the flash fails, I assume the BIOS flash:
I thought this indicated that maybe the BIOS flash chips both died. So I desoldered the BIOS chips and tried reading the chips. One of them was indeed broken (the primary BIOS), the other one worked just fine so I was wrong... I dumped the BIOS ROM nonetheless and reflashed two new chips and soldered them back.
They are the ones on the left and bottom.
Now however there's even less output. The fan doesn't spin at 100% anymore but like 5-10%.
Previously the logs said:
But now it says it doesn't schedule the delayed BIOS check, and it says:
I checked the condition for the delayed BIOS check but I have no clue what this checks:
I attached the full logs below, and also the loaded kernel modules.
Weirdly enough no mtd devices are found.
Parts of bmcport80 decompiled code using Ghidra:
Any advice is highly appreciated! There is so little documentation to be found about this device and it makes this very hard.
Thanks!
Dean
Code:
mount: mounting dev/mtdblock0 on /mnt/flash0 failed: No such device or address mount: mounting dev/mtdblock1 on /mnt/flash1 failed: No such device or address
Code:
Scheduled delayed BIOS check - SLP_S3#=high, PCH_BIOS_OK=low ... snip # timer event 11 CMD_DELAYED_CHECK Switched to Backup BIOS - SLP_S3#=high, PCH_BIOS_OK=low PWRBTSW timer event 8 CMD_REBOOT_HOST timer event 9 PWRBTSW CMD_REBOOT_HOST_SM1 timer event 0 CMD_RELEASE_RST SLP_S3# -> HI count=1 MEM_EVENT[3:0]=0xf tasklet count=1 timer event# 10 start: 90 sec timer event 10 CMD_IS_BIOS_OK? In Backup BIOS already
Code:
SLP_S3# -> HI count=1 MEM_EVENT[3:0]=0xf tasklet count=1 timer event# 10 start: 90 sec SLP_S3# -> HI count=2 MEM_EVENT[3:0]=0xf tasklet count=2 timer event# 10 start: 90 sec SLP_S3# -> HI count=3 MEM_EVENT[3:0]=0xf tasklet count=3 timer event# 10 start: 90 sec SLP_S3# -> HI count=4 MEM_EVENT[3:0]=0xf tasklet count=4 timer event# 10 start: 90 sec SLP_S3# -> HI count=5 MEM_EVENT[3:0]=0xf tasklet count=5 timer event# 10 start: 90 sec SLP_S3# -> HI count=6 MEM_EVENT[3:0]=0xf tasklet count=6 timer event# 10 start: 90 sec SLP_S3# -> HI count=7 Switched to Backup BIOS - count exceeded MEM_EVENT[3:0]=0xf SLP_S3# -> HI count=1 MEM_EVENT[3:0]=0xf tasklet count=1 timer event# 10 start: 90 sec SLP_S3# -> HI count=2 MEM_EVENT[3:0]=0xf tasklet count=2 timer event# 10 start: 90 sec SLP_S3# -> HI count=3 MEM_EVENT[3:0]=0xf tasklet count=3 timer event# 10 start: 90 sec SLP_S3# -> HI count=4 MEM_EVENT[3:0]=0xf tasklet count=4 timer event# 10 start: 90 sec SLP_S3# -> HI count=5 MEM_EVENT[3:0]=0xf tasklet count=5 timer event# 10 start: 90 sec timer event# 10 start: 90 sec SLP_S3# -> HI count=7 Main & Backup failed - Hold backplane in reset. MEM_EVENT[3:0]=0xf SLP_S3# -> HI count=8 Main & Backup failed - Hold backplane in reset.
Code:
if (((*(uint *)((int)gpio_base_addr + 0x70) & 0x2000000) != 0) && ((*(uint *)((int)gpio_base_addr + 0x78) & 0x18) == 0)) {
slp_s3_counter = 0;
printk(" <6>Scheduled delayed BIOS check - SLP_S3#=high, PCH_BIOS_OK=low\n");
initWorkTimer(0xb);
return 0;
Code:
lsmod mailbox 8732 0 - Live 0xbf00b000 aspeed_i2c 4680 0 - Live 0xbf007000 adc 3748 0 - Live 0xbf004000 bmcport80 7980 0 - Live 0xbf000000
Code:
cat /proc/mtd dev: size erasesize name
Code:
undefined4 gpio_interrupt(void)
void *pvVar1;
uint uVar2;
uint uVar3;
uVar3 = *(uint *)((int)gpio_base_addr + 0x38);
if ((uVar3 & 0x40) != 0) {
*(undefined4 *)((int)gpio_base_addr + 0x38) = 0x40;
printk("<6>PWRBTSW\n");
if ((uVar3 & 1) != 0) {
*(undefined4 *)((int)gpio_base_addr + 0x38) = 1;
printk("<6>RECOVER\n");
uVar3 = *(uint *)((int)gpio_base_addr + 0x18);
if ((uVar3 & 0xc0000000) != 0) {
*(undefined4 *)((int)gpio_base_addr + 0x18) = 0xc0000000;
printk("<6>ETH_WAKE[1:0]=0x%lx\n",uVar3 >> 0x1e);
WakeOnLan();
pvVar1 = gpio_base_addr;
if ((uVar3 & 0x3c000000) != 0) {
*(undefined4 *)((int)gpio_base_addr + 0x18) = 0x3c000000;
uVar3 = *(uint *)((int)pvVar1 + 0x70);
if (((uVar3 & 0x2000000) != 0) && ((*(uint *)((int)pvVar1 + 0x78) & 8) != 0)) {
printk("<6>MEM_EVENT[3:0]=0x%lx\n",uVar3 >> 0x1a & 0xf);
if ((uVar3 & 0x200) != 0) {
*(undefined4 *)((int)gpio_base_addr + 0x18) = 0x200;
printk("<6>ASF_SMBALERT#\n");
if ((uVar3 & 0x800) != 0) {
*(undefined4 *)((int)gpio_base_addr + 0x18) = 0x800;
printk("<6>LINK_ALT#\n");
if ((*(uint *)((int)gpio_base_addr + 0xa8) & 0x2000000) != 0) {
slp_s3_counter = slp_s3_counter + 1;
printk("<6>SLP_S3# -> HI count=%d\n",slp_s3_counter);
if (slp_s3_counter < 7) {
uVar2 = my_tasklet.state | 1;
uVar3 = my_tasklet.state & 1;
my_tasklet.state = uVar2;
if (uVar3 == 0) {
__tasklet_schedule(&my_tasklet);
else if ((*(uint *)((int)gpio_base_addr + 0x78) & 0x10) == 0) {
*(uint *)((int)gpio_base_addr + 0x78) = *(uint *)((int)gpio_base_addr + 0x78) | 0x10;
slp_s3_counter = 0;
printk("<6>Switched to Backup BIOS - count exceeded\n");
else {
printk("<6>Main & Backup failed - Hold backplane in reset.\n");
/* WARNING: Load size is inaccurate */
*(uint *)gpio_base_addr = *gpio_base_addr & 0xfeffffff;
slp_s3_counter = 7;
*(undefined4 *)((int)gpio_base_addr + 0xa8) = 0x2000000;
return 1;
Code:
void timer_function(undefined4 param_1)
char *pcVar1;
printk("<6>timer event %lu\n",param_1);
switch(param_1) {
case 0:
ich_pwrbt(1);
if (my_timer.entry.next != (list_head *)0x0) {
del_timer();
pcVar1 = "<6>CMD_RELEASE_RST\n";
break;
default:
printk("<3>bmcport80 timer command error %lu\n",param_1);
return;
case 8:
ich_pwrbt(1);
my_timer.expires = jiffies + 0x32;
my_timer.data = 9;
mod_timer(&my_timer,my_timer.expires);
pcVar1 = "<6>CMD_REBOOT_HOST\n";
break;
case 9:
ich_pwrbt(0);
my_timer.data = 0;
pcVar1 = "<6>CMD_REBOOT_HOST_SM1\n";
break;
case 10:
del_timer();
if ((*(uint *)((int)gpio_base_addr + 0x70) & 0x2000000) == 0) {
return;
printk("<6>CMD_IS_BIOS_OK?\n");
if ((*(uint *)((int)gpio_base_addr + 0x78) & 8) != 0) {
printk("<6>Main BIOS OK!\n");
slp_s3_counter = 0;
return;
pcVar1 = "<6>Switched to Backup BIOS - Main not OK\n";
LAB_00010560:
slp_s3_counter = 0;
printk(pcVar1);
ich_pwrbt(0);
my_timer.expires = jiffies + 500;
my_timer.data = 8;
return;
pcVar1 = "<6>In Backup BIOS already\n";
break;
case 0xb:
del_timer();
printk("<6>CMD_DELAYED_CHECK\n");
if ((*(uint *)((int)gpio_base_addr + 0x70) & 0x2000000) != 0) {
if ((*(uint *)((int)gpio_base_addr + 0x78) & 0x18) != 0) {
return;
pcVar1 = "<6>Switched to Backup BIOS - SLP_S3#=high, PCH_BIOS_OK=low\n";
goto LAB_00010560;
pcVar1 = "<6>event ignored - SLP_S3=low CPU down.\n";
printk(pcVar1);
return;
Thanks!
Dean
