New Capacitors
  • BustinCaps
    • Mar 2016
    • 43
    New Capacitors
    Hi All. So I am new to this forum and would appreciate your help in identifying some capacitors I ordered from Amazon.
    I ordered them before really researching and finding more reputable resources like Digi-Key. The caps I originally ordered were Rubycon MCZ from the pictures shown. I later found out this was a bad move since these are outdated and have been heavily counterfeited. Much to my surprise, when the caps arrived they were not Rubycons but the ones shown in the pictures attached. Can anyone identity them and tell me if they look fake. Any help would be appreciated.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: New Capacitors
    Matsushita-panasonic is the brand. Better IMHO. Though, they look fake too. The cropped leads are not promising either. Can't really read the other text.
    Follow the white rabbit.
    • japlytic
      • Oct 2005
      • 2086
      Re: New Capacitors
      Since Matsushita renamed itself to Panasonic Corporation, new Panasonic electrolytic capacitors no longer have the manufacturer's insignia - should Panasonic have an insignia for their components? I think so.
      • BustinCaps
        • Mar 2016
        • 43
        Re: New Capacitors
        So if these are even genuine, are they old stock?
          • 31087
          Re: New Capacitors
          they *almost* look correct, they should have a "+" before the temperature - other than that they look right.
          they are cropped because FL series are used on motherboards, but not AFAIK sold to the public.
          so the leads will be cropped for pick-n-place machines.
          that's also why you wont find a datasheet.
            • 31087
            Re: New Capacitors
            i would say they are surplus from a chinese or korean production line.
            you should find a date printed on them lightly in red between the gold bits.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: New Capacitors
              Looks like possibly a pull from a motherboard...
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
                • 31087
                Re: New Capacitors
                no, it's not been used, but i want to see the bung.
                look at a real one i pulled.
                i just pulled it from the spares rack & foto'd it.
                • BustinCaps
                  • Mar 2016
                  • 43
                  Re: New Capacitors
                  OK there are 3 different markings on the caps. Most have what looks like 6DIVEF. There is also 5DIVUS and 6DIVEE. I hope you can see this from the attached pic.
                  • BustinCaps
                    • Mar 2016
                    • 43
                    Re: New Capacitors
                    So you think they are used and have been pulled from mb?
                      • 31087
                      Re: New Capacitors
                      looking at an internal datasheet - they may be used / recovered from a board.
                      the FJ datasheet shows several lead types, but short & straight isnt one of them.
                      it's hard to say for sure though - what does the bung look like ??
                      • BustinCaps
                        • Mar 2016
                        • 43
                        Re: New Capacitors
                        Take a look.
                        • BustinCaps
                          • Mar 2016
                          • 43
                          Re: New Capacitors
                          If they are recovered from a board, then they did a good job because they look very clean. There are no scratches and none of the leads are bent in the least
                            • 31087
                            Re: New Capacitors
                            well it's the right bung, so it's probably not fake.
                            • BustinCaps
                              • Mar 2016
                              • 43
                              Re: New Capacitors
                              Thanks for the info. I will probably keep them then.
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3264
                                • Singapore
                                Re: New Capacitors
                                cant help noticing the following issues with the TS' caps:
                                1. why is the bung purple/blue tinted?
                                2. the line used to draw the M logo is too thin.
                                3. the "105°C FL" font is too large compared to stj's genuine caps.
                                • BustinCaps
                                  • Mar 2016
                                  • 43
                                  Re: New Capacitors
                                  The bung is black. Probably just the lighting that makes it look a different color. There are differences in the print between caps labeled 6DIVEF and 5DIVUS. See pic below. 5DIVUS shown at the top..6DIVEF at the bottom. Font and logo size look different. Also, top cap has + before "105°CFL". Maybe different production runs. I don't know. If anyone has any further insight, it would be appreciated.
                                  • pfofit
                                    • Jun 2008
                                    • 10
                                    Re: New Capacitors
                                    There are differences in the print between caps labeled 6DIVEF and 5DIVUS. See pic below. 5DIVUS shown at the top..6DIVEF at the bottom. Font and logo size look different. .....If anyone has any further insight, it would be appreciated.
                                    A snip from a Panasonic pdf from 2004, i think it was .
                                    Looks like yours are supposed to be 4 week of dec, 2005 and 2006 .. or dec, 2015 and 2016 or afake date code.
                                    Seems like December of 2015 is too fresh, and the ones from dec 2016 are even fresher
                                    tomorrows product at todays pricing.
                                    What's the top look like?
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Re: New Capacitors
                                      I think I have some 1800 uF 6.3V Panasonic FLs (pulled from a s478 -era HP board, so I know they are genuine). Will check them tomorrow to see what they look like. I think yours look pretty genuine, aside from the slightly larger Matsushita "M"-in-a-box logo. But it may be normal too. The bungs alone suggest these are genuine caps.
                                      • BustinCaps
                                        • Mar 2016
                                        • 43
                                        Re: New Capacitors
                                        Good to know. Thanks for the feedback. Do you know if capacitors have a certain shelf life? If so what's the best way to store them so they last longer?
                                        • Olkus
                                          Elna capacitors - fake?
                                          by Olkus
                                          I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                                          09-01-2023, 02:45 AM
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                        • Hitto
                                          Fake Nichicon capacitors with almost-perfect sleeve?
                                          by Hitto
                                          Fake Nichicon capacitors with an almost-perfect sleeve?
                                          Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                                          It truly looks like the real thing.
                                          I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                                          Shall we be afraid, at this point, that even the bung can be replicated?...
                                          01-09-2021, 03:07 PM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
