New Capacitors
    • 31214
    Re: New Capacitors
    search "re-forming"
      master hoarder
      • May 2008
      • 12175
      Re: New Capacitors
      Okay, I just checked my 6.3V 1800 uF Panasonic FL caps (sorry for the delay).
      The top cap in this picture of yours definitely looks genuine:
      https://www.badcaps.net/forum/attach...1&d=1459118731
      Basically, the "[M]" logo is flush with the "+105°C FL" text, just like on mine and is the right size. I also compared it to several 16V 1500 uF FL caps (10x20 size), and again everything looks the same.
      That said, the bottom cap could still be genuine, despite the "[M]" logo not being flush with the text. Manufacturing differences, perhaps? All I can tell you is that I also have some Panasonic FJS 6.3V 820 uF caps, and they had their "[M]" logos not flush with the text above them, just like the bottom cap in your picture. So again, there is a chance that it is genuine, too.
      Speaking of genuine caps, all of my Panasonic caps are board pulls from ASUS or Xbox 360, so it's unlikely they are fakes.
      Originally posted by BustinCaps
      Do you know if capacitors have a certain shelf life? If so what's the best way to store them so they last longer?
      They do, but that can vary a lot, depending on the capacitor type (ultra-low ESR caps are a bit more unstable than "entry" and "mid" -level low ESR).
      In general, 2-3 years in storage is okay. After 5 years, they may start to degrade a little (but probably not enough to matter at all). After 5 years, though, it's recommended you reform them. See this for more details:
      https://www.badcaps.net/forum/showthread.php?t=50530
      • BustinCaps
        • Mar 2016
        • 43
        Re: New Capacitors
        @momaka. Thanks for looking into that. Very good news and much appreciated.
        • Olkus
          Elna capacitors - fake?
          by Olkus
          I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
          09-01-2023, 02:45 AM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
        • Hitto
          Fake Nichicon capacitors with almost-perfect sleeve?
          by Hitto
          Fake Nichicon capacitors with an almost-perfect sleeve?
          Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
          It truly looks like the real thing.
          I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
          Shall we be afraid, at this point, that even the bung can be replicated?...
          01-09-2021, 03:07 PM
          After all of...
          07-13-2024, 08:14 PM
