Nichicon HE Series, fakes?
  • Cartel
    • Feb 2006
    • 112
    • 31170
    Re: Nichicon HE Series, fakes?
    well HM series sure dont use a bung like that - i just looked.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Fake !
      • Cartel
        • Feb 2006
        • 112
        Hmm thats what I thought...that kinda sucks.
        They are within spec at least.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          For now...
            • 31170
            is one leaking around the lead btw?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              the bungs are not the same.
              and one is leaking stuff at the edge.FAKE JUNK!
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                fake-o-rama. They look resleeved. I'd love to see some dissection pics of those to find out what they really are
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3264
                  • Singapore
                  oh no its the bullseye bung again. i'd say they are resleeved crapxons as i've seen crapxon using the bullseye bung and the + vent is also used by crapxon. teapo uses a mercedes benz vent with three additional notches in the center.
                    • 31170
                    i just looked in my bin,
                    that bung style is used on G-LUXON
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      If I was a betting man I would say that those are only 10 to 16 Volts rated.
                      • lti
                        • May 2011
                        • 2557
                        Lots of caps use that bung style. I have some I.Q (OST) caps with the same bung. These fake caps won't be relabeled caps from a well-known manufacturer.
                        • michael dranfield
                          • Jan 2016
                          • 232
                          • England
                          Nichicon website indicates a much lower impedance than you are measuring.
                          • Cartel
                            • Feb 2006
                            • 112
                            Thanks for the replies.
                            I talked to the supplier and was refunded.
                            • Cartel
                              • Feb 2006
                              • 112
                              here ya go..for fakes they look well built.
                              This was the cap with the crud on the lead.
                              • michael dranfield
                                • Jan 2016
                                • 232
                                • England
                                well at least they didn't look look this when you opened the up !
                                • Cartel
                                  • Feb 2006
                                  • 112
                                  Any opinion of the insides, Topcat?
                                  I think it looks ok, would they hold up to 25V?
                                  • kaboom
                                    "Oh, Grouchy!"
                                    • Jan 2011
                                    • 2507
                                    don't "speculate" anything over/about those fakes
                                    Get the real deal from Mouser or Digikey.
                                    "pokemon go... to hell!"
                                    EOL it...
                                    All style and no substance.
                                    guilty,guilty,guilty,guilty!
                                    guilty of being cheap-made!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Try and see. They might hold up to full voltage indeed. But with counterfeit caps, you never know.
                                      That said, if you do try them, I don't suggest you do it with anything you care for, and certainly not as a repair (not even temporary). Cheap caps like these may be only useful for breadboard projects - at least that's how I re-use them (extra filtering on the power lines).
                                      By the way, another "fun" way to check ESR is to charge the cap to full voltage and then short-circuit its leads. Given that this is a 25V 4700 uF cap, you should get quite a bit of sparking and popping when you do that. If you don't, the ESR is too high.
                                      And yes, they are definitely fakes... though it's a moot point saying that after everyone already has.
                                      Exactly.
                                      Trying to guess which crap cap manufacturer made these is pointless. Whether it's CapXon or Jun Fu or G-Luxon... it's all the same, since none of them are good .
                                      • DrewPhillips
                                        Capacitor Diarrhea - Nichicon PL Series
                                        by DrewPhillips
                                        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                        03-02-2025, 10:18 PM
                                      • chth96
                                        Is there datasheet for nichicon LXJ series?
                                        by chth96
                                        I want to calculate capacitor ESR referring to below guide.
                                        https://forum.digikey.com/t/calculat...-from-tan/2633
                                        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                                        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                                        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                                        11-20-2022, 08:11 AM
                                      • chth96
                                        Is there any datasheet for nichicon RT(M) series?
                                        by chth96
                                        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                        https://www.badcaps.net/forum/troubl...e-been-blew-up
                                        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                        I have spare console...
                                        11-28-2023, 03:36 AM
                                        ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                                        This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-12-2024, 03:28 PM
                                        ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                                        This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
