Capacitor Diarrhea - Nichicon PL Series
  • DrewPhillips
    • Oct 2023
    • 14
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed due to a different cause (startup resistors), were taken out of service, then stored for 5 or 10 years. I am now rehabilitating them for use as spares.
    Between the 2 units there are 8 diarreah'ed caps, are all Nichicon PL series, all are 47 uF @ 35V. There are other-sized Nichicon PL caps on the boards and which have not leaked. Nichicon retired their PL series and now recommend the PM series as replacement. When rehabilitated, the PSU's will be shelf queens; how well do the newer Nichicon PM's suffer long term idleness? (Or have they not been around long enough for anyone to know).
    • 32066
    old PL caps always do that.
    not sure about PM, i usually use panasonic for everything.
    • PeteS in CA
      • Aug 2005
      • 3591
      • USA, Unsure of Planet
      • Reading, Education, History, Christianity
      The PM series is Nichicon's RoHS-compliant version of the PL series. It was introduced, AFAIK, in the early 2000s. I first saw them in 2005, and in the several prior years I had been at a company making military power systems, so how long before 2005 the series had been around, I'm not sure. FWIW, Nichicon's PS series (if it's still around) is the RoHS-compliant version of the PR series.
      PeteS in CA
