Is there any datasheet for nichicon RT(M) series?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
    https://www.badcaps.net/forum/troubl...e-been-blew-up
    and I finally fixed​ this retro game console by soldering varistor and glass fuse.
    But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
    I have spare console which is the same type of this japanese retro console and it has 4pin connector instead of 5pin in its PSU, And When I measure its voltage, it is 4.93-5.02v 5v GND GND
    I use my MESR-100 ESR meter and found that ohm value of nichicon RT(M) capacitor(200v 100uf) is 0.274-0.280 ohm
    I want to know that it is within acceptable tolerance,But It is very hard to find any pdf datasheet for nichicon RT(M) series on the net.
    Is there anyone who has any datasheet for nichicon RT(M) series?
    • 31094
    if it's the mains cap then use a rubycon - whats the height, diameter and pin type?
    • chth96
      • Nov 2022
      • 118
      • indonesia
      diameter is 17-18mm and height is 20-28mm it is electrolytic capacitor and it seems the main cap in PSU,
        • 31094
        wires or snap-in contacts 10mm apart?
        • chth96
          • Nov 2022
          • 118
          • indonesia
          It is electrolytic capacitor of normal connector.
          it doesn't have snap in contact.
          • DrewPhillips
            Capacitor Diarrhea - Nichicon PL Series
            by DrewPhillips
            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
            03-02-2025, 10:18 PM
          • chth96
            Is there datasheet for nichicon LXJ series?
            by chth96
            I want to calculate capacitor ESR referring to below guide.
            https://forum.digikey.com/t/calculat...-from-tan/2633
            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
            11-20-2022, 08:11 AM
          • gabri2211
            Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
            by gabri2211
            Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
            This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
            This NEXUS connector broke.
            Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
            The Xbox has a power supply that provides 12 volts on all outputs, so the power...
            07-28-2025, 07:13 PM
            ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
            This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 03:28 PM
            ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
            This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
