Identify Cap Manufacturer from Symbol
  • tjg79
    • Sep 2013
    • 49
    Hello forum,
    I'm recapping a Sony Telephone Answering Machine, IT-A650. I need assistance identifying the manufacturers from the symbols on two caps. The pictures are attached below.
    Does anyone know these manufacturers?
    Regards
    1. R in a square.
    2. Triangle with arrowheads on the vertices.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Identify Cap Manufacturer from Symbol
    Mitsubishi caps !
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Got an image of the bung and vent ?
      • tjg79
        • Sep 2013
        • 49
        What's the "bung and vent?"
        Regards
        • tjg79
          • Sep 2013
          • 49
          OK, the triangle with arrowheads is likely Mitsubishi.
          What is the "R" in a square?
          Regards
          • Behemot
            • 4845
            • CZ
            Rubycon. They use that on very small caps.
            • tjg79
              • Sep 2013
              • 49
              Thanks Behemot.
              Regards
              • tjg79
                • Sep 2013
                • 49
                Is there a good source to buy Rubycon caps is small quantities?
                I don't see then listed on Mouser and Digikey only stocks very few types. Special orders require large quantities.
                Regards
                • Behemot
                  • 4845
                  • CZ
                  Not sure, what exactly do you need? You can use similar caps from Chemi-Con (usually cheapest) or others…
                  • tjg79
                    • Sep 2013
                    • 49
                    I'm not sure what I need yet either. I'm trying to determine the exact specs on what I've got so I can then find either an exact replacement or suitable substitute from a high quality manufacturer.
                    I'm recapping three Sony Telephone Answering Machines, so I'll need about 180 caps of which there appears to be 19 different caps. Two are described below.
                    On the Mitsubishi cap pictured in post #1, these are the specs that I have:
                    Mitsubishi 1μF, 50V, 85°C, 07N3, dia. 4.04mm, length 5.57mm, lead spacing 1.43mm, lead dia. 0.44mm.
                    One the Rubycon cap pictured in post #1, these are the specs that I have:
                    Rubycon 2.2μF, 50V, 85°C, CEW M896, dia. 5.13mm, length 11.32mm, lead spacing 2.18mm, lead dia. 0.48mm.
                      • 31015
                      anything 85' is just "general purpose" stuff.
                      • tjg79
                        • Sep 2013
                        • 49
                        Yes, but even if you go with a "standard" cap, there are usually three or more "standard caps" from the same manufacturer that have other characteristics, such as ripple current, impedance, etc..., that vary significantly. So, the question is which of the several choices of "standard cap" is the best choice?
                        Regards
                        • Behemot
                          • 4845
                          • CZ
                          I think most of them will have superior specs after decade or two. So take the middle or the lower ones, just for 105 °C, those survive longer.
                          Are those original caps already bad actually? Cause both should last long…
                          • tjg79
                            • Sep 2013
                            • 49
                            #1 in the first post is a 100μF, 20%, 6.3V, 85°C cap that tests out as 107.3μF and 1.06Ω ESR in circuit and 99.55μF and 0.7Ω ESR out of circuit.
                            #2 in the first post is a 1μF, 20%, 50V, 85°C cap that tests out as 0.90μF and 5.2Ω ESR.
                            I'm not sure about what the correct ESR for these caps should be, but of the 60 plus caps in each phone, many do test out bad such as leaky, open or ESR >5Ω to 40Ω plus.
                            Considering the age of these telephones, it's more efficient to just replace all of the electrolytic caps while I've got the phone opened up and disassembled.
                            The failed caps are causing a few of the power transistors to heat up excessively causing other indications of heat damage.
                            • Behemot
                              • 4845
                              • CZ
                              Those values are absolutelly normal. Ordinary 1uF caps have ESR of 5 to 15 ohm, depending on their grade. But if few are really bad, I guess it's worth replacing them…
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                second is matsushita(panasonic)
                                quite old.
                                • tjg79
                                  • Sep 2013
                                  • 49
                                  quite old.
                                  Is the triangle with arrowhead on the vertices Matsushita? Now, Panasonic?
                                  Someone indicated they were Mitsubishi.
                                  • tjg79
                                    • Sep 2013
                                    • 49
                                    When finding replacement or substitute caps, how do you know if you need a bi-polar cap? What are the indications?
                                    Regards
                                    • Behemot
                                      • 4845
                                      • CZ
                                      Yeah they are Matsushita, I completelly missed that…
                                      BP caps have no cathode (-) marking and often something like BP or bipolar on them.
                                      • tjg79
                                        • Sep 2013
                                        • 49
                                        Is there a problem if you replace a regular cap with a bi-polar cap?
                                        • thesame
                                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                          by thesame
                                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                          02-27-2024, 04:31 AM
                                        • silver60618
                                          Lenovo Legion 7 - Help Identify IC
                                          by silver60618
                                          Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                          I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                          Any help would be appreciated...
                                          07-02-2025, 12:16 PM
                                        • k3wf3w
                                          HDMI port component identification - Samsung NU7100 UN58NU7100F - Kant M2E - BN94-13065G
                                          by k3wf3w
                                          Hey Badcaps,
                                          Hoping someone can help me identify this HDMI port, and/or a suitable substitute. I have scoured the internet, but no luck.
                                          Is the circle "T" symbol a manufacturers logo?
                                          Thanks!
                                          05-22-2024, 11:52 AM
                                        • chth96
                                          How can I identify varistor which have been blew up?
                                          by chth96
                                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                                          So It seems that glass fuse and varistor have been blew up.
                                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                          Is there any way to identify varistor type in my sega saturn PSU?
                                          Any reply would be appreciated.
                                          EDIT:
                                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                          11-26-2023, 08:52 AM
                                        • freakorio
                                          Need Help To Identify Component on Ymain LJ41-05120A
                                          by freakorio
                                          Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                          05-21-2024, 02:32 AM
