Identify Cap Manufacturer from Symbol
    • 31214
    Re: Identify Cap Manufacturer from Symbol
    bi-polar are physically bigger and dont perform so well.
    these days you can use a polyester or polypropylene cap instead.
    • tjg79
      • Sep 2013
      • 49
      Not in all cases. When I was searching for caps on the Mouser Electronics website, and applying the parameter filters (connection, capacitance, voltage, tolerance, temperature, size, etc...), to include cap diameter and length, in at least two cases, the only options presented were for bi-polar caps.
      I ordered a few, so I'll find out if they work or not.
        • 31214
        did you look at the ripple voltage?
        • tjg79
          • Sep 2013
          • 49
          I think they may have listed ripple current, but no, in this particular case, I didn't look at ripple voltage. I don't recall seeing a ripple voltage spec. I'm going to give them a try to see what happens.
          In general, when my filter parameters resulted in four or five choices, in some cases there was some variation in ripple current, but I wasn't sure what cap was the better choice. Is highest ripple current always the best choice? I don't know. I suspect not, because the best choice, in my opinion, would be the replacement cap that most closely matches the original cap specs.
            • 31214
            i meant current - sorry
            it's the amount of current the capacitor can store
            • Behemot
              • 4845
              • CZ
              #26
              What does that mean? How can you store current?
                • 31214
                because it's a capacitor - it has capacity.
                the current capacity is the current it will draw from a discharged state and the initial current it can discharge at.
                • tjg79
                  • Sep 2013
                  • 49
                  That's not the ripple current.
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    You store energy at the form of electric charge. The capacitor can provide maximum current which is basically equal to the amount of this stored energy/voltage and it's internal resistance (ESR). But that is basically shortcut current, which is by no way ripple curent…
                    • thesame
                      DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                      by thesame
                      Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                      The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                      02-27-2024, 04:31 AM
                    • silver60618
                      Lenovo Legion 7 - Help Identify IC
                      by silver60618
                      Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                      I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                      Any help would be appreciated...
                      07-02-2025, 12:16 PM
                    • k3wf3w
                      HDMI port component identification - Samsung NU7100 UN58NU7100F - Kant M2E - BN94-13065G
                      by k3wf3w
                      Hey Badcaps,
                      Hoping someone can help me identify this HDMI port, and/or a suitable substitute. I have scoured the internet, but no luck.
                      Is the circle "T" symbol a manufacturers logo?
                      Thanks!
                      05-22-2024, 11:52 AM
                    • chth96
                      How can I identify varistor which have been blew up?
                      by chth96
                      I mistakely pluged 100v japanese retro game console to 220v outlet.
                      So It seems that glass fuse and varistor have been blew up.
                      I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                      Is there any way to identify varistor type in my sega saturn PSU?
                      Any reply would be appreciated.
                      EDIT:
                      It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                      11-26-2023, 08:52 AM
                    • freakorio
                      Need Help To Identify Component on Ymain LJ41-05120A
                      by freakorio
                      Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                      05-21-2024, 02:32 AM
