large caps to replace battery in my car
  • baron223
    • Jul 2015
    • 13
    • usa
    is anyone instrested in replaceing there car battery with large caps
    I have tec want to be the desire to try it from you tube video but am just remedial electronic
  • MassBoost
    • May 2015
    • 9
    • US
    Re: large caps to replace battery in my car
    I'm not sure why you would want to replace your car battery and resort to trying to use capacitors? It seams very impractical, as to what advantage would you ever gain in doing so?
    • Charlie_Bravo
      • Jul 2015
      • 7
      Post link to youtube video. "Is", "interested", "replacing" "their", "tech", "youtube", etc...
      Most relevant keyword: "remedial"
      • baron223
        • Jul 2015
        • 13
        • usa
        this goes back to 6 months ago when I was looking at inverters for energy source when Edison was not available.
        to answer question I thought it would be cheeper but at a risk. I also needed a battery for my car at the time. in you tube there is a person that used think it was 6 Maxwell large capacitirs don't remember size but he did it and it ran the car and left radio on all night and the car started next day. it worked with the alt same as battery.
        same person used car battery inverter and capacitors th power drill press when no energy was available it drilled 28 holes not much but idea was good to me since I face same situation many times.
        I am just getting into this stuff and find it interesting
        also like to learn to run 5000 btu air conditioner with solar power like I saw also on you tube
        my original reason for joining this forum was to try to fix sony tv that does not get picture
        all else I can gain in knowledge I am greatful for
        thanks for looking at my post
        • baron223
          • Jul 2015
          • 13
          • usa
          maxwell capacitors for car battery hi type this in you tube search engine a lot of things
          hope will be interesting
          • baron223
            • Jul 2015
            • 13
            • usa
            type above in you tube search engine many videos available
            • Charlie_Bravo
              • Jul 2015
              • 7
              https://www.youtube.com/watch?v=BE-v9KiAaVo
              • baron223
                • Jul 2015
                • 13
                • usa
                https://youtu.be/z3x_kYq3mHM
                • baron223
                  • Jul 2015
                  • 13
                  • usa
                  https://youtu.be/GPJao1xLe7w working model capacitor battery for car
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    ^do what you will. I'm staying with lead acid cells. Like I stuck with tube radios
                    Follow the white rabbit.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8678
                      Reserve Capacity?
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        Originally posted by eccerr0r
                        Reserve Capacity?
                        poor.
                        • MassBoost
                          • May 2015
                          • 9
                          • US
                          For starters I highly doubt the person left radio on all night to which the car started the next day. Supercapacitors have very low energy densities, thus they would not be able to sustain an amount of discharge for a extended amount of time. That would mean that a series of supercapacitors in a size that would be comparable to a battery of similar size would most likely be out preformed by a battery by 30 times or more. If a battery could not last a night with the radio on, there would be no chance a supercapacitor ever would.
                          For an everyday practical use in a car, a supercapacitor would serve no benefit what so ever that I could see. If a car were to be left untouched of an extended amount of time, a bank of supercapacitors would surely discharge to which there wouldn't be enough power to start a vehicle. Until they improve the Wh/kg I don't see supercapacitors serving any practical purpose in vehicles. Also please don't PM me again about the issue, you can keep it to the post.
                          • baron223
                            • Jul 2015
                            • 13
                            • usa
                            ok thanks for your response
                            please excuse pm quick reply is what I should have used
                            • baron223
                              • Jul 2015
                              • 13
                              • usa
                              think I will start with smaller project a super capacitor flashlight it will be built in Pakistan and marketed world wide by nra
                              • baron223
                                • Jul 2015
                                • 13
                                • usa
                                should have looked on internet before original posting
                                think Volvo is working on
                                size problem by installing caps in side panels of car
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • techfreak9356
                                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                  by techfreak9356
                                  09-14-2023, 11:10 PM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                • huzo
                                  HP ELITE X2 1013 G3 weird battery issue
                                  by huzo
                                  Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                  01-31-2025, 12:09 AM
                                • trepachka
                                  iPad Air A1475 Boot loops after replacing battery
                                  by trepachka
                                  This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                                  The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                                  I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                                  11-08-2024, 03:17 PM
