List of Bad Cap Manufacturers
This is a sticky topic.
  • donatdonlo
    replied
    Re: List of Bad Cap Manufacturers
    I have a couple of HP 17" LCD's that had some dark spots ( bad pixels ) that had good boards I used to fix other Dell LCD's. I'm thinking of recapping them to have as spare since I see a lot of these. The first board is a BenQ with 19 caps, 16 Elite ( 2 obviously bad ) and 3 Lelon. The second is a really f snazzy board with the display driver circuitry on the same board as the PS with a large Genesis chip. It has 3 OST caps ( 2 obviously bulging and 14 Su'scon all of which appear okay. Should I replace all of the caps because they are suspect?
  • teppei
    replied
    Thanks for your response!
  • gieroncastiel
    replied
    oh.there are plenty of them here in our country.
  • teppei
    replied
    Originally posted by Fraser
    Surprisingly from a high value Belinea flat screen (10 20 30):
    Almost all caps on the controller board and the 1000µ PSU cap.
    - All the TEAPO (No surprise)
    100µ * 6
    330µ
    - All OST
    470µ
    330µ
    - All Eltec (Eltoc ?)
    1000µ
    Teapo???are the same brand that are mounted inside the d-link and netgear!
  • mariushm
    replied
    1.6 ohm for such capacitor is a reasonable value.
    As for replacement, I'd look at Nichicon PW or capacitors with similar specs as Nichicon PW.
    Don't hesitate to replace it with a capacitor rated for 50v or even higher, it's not a problem.
  • stevenA
    replied
    Has anyone seen SHI capacitors - I know, someone actually chose to call their capacitors SHI(R) without the T.
    Tried google but no joy....
    I have a 10uF, 25v with 1.6ohm ESR and wanted to see the specs for a replacement (see Paulmann electronic transformer thread)
  • WonkeyDonkey
    replied
    Originally posted by retiredcaps
    Ah thanks for that link. I had searched for 'high quality capacitor recommendations' or something like that and not got anywhere.
  • retiredcaps
    replied
    Originally posted by WonkeyDonkey
    I'm thinking maybe the top 5 brands or something...
    From the FAQ
    https://www.badcaps.net/forum/showthread.php?t=2280
  • WonkeyDonkey
    replied
    Not sure if its appropriate to post this here or start a new thread; but is there a corresponding list of the known high quality caps manufacturers ?
    I've done a quick search but cant find anything so far.
    All I have managed to find upto now from my web searching is that the Panasonic FM and FC series seem to be highly regarded.
  • Th3_uN1Qu3
    replied
    S.I. are bad too, swapped a bunch in a Socket A motherboard.
  • Heihachi_73
    replied
    I swapped out four bloated R&C brand caps in a Space 600T digital set top box earlier this year. The machine would power off immediately after turning it on.
    I didn't see R&C in the list, so it's probably just a generic Chinese make (in fact, the "Space" brand name is seemingly just as generic as the caps within). At the time, I only had access to equally generic S.I. caps from Jaycar Electronics, but they have held up so far. The machine now works fine, albeit missing the remote and having a password on the setup menu (it's not the default 0000 as most are).
  • Lobo
    replied
    Same here. Someone just brought me an Acer that won't boot up. It has a cheap imitation Foxconn board. It's littered with Lelons and OST's. But the caps that are bulging and leaking are TK's. I'm not gonna waste my time with this one though since a new board with an LGA775 socket is only 20-30 bucks.
  • Uranium-235
    replied
    tk is one of the most notorious brands
  • Pesti
    replied
    I just pulled 10 TK 6.3 1800uf from a newer E-machine no name board with 8 leaking and 2 full blown. Either something else is wrong with this board (besides being an E-machine, lol)
    Or you guys should definitely make sure that they are on the first list on this thread.
    Pesti
  • manywelps
    replied
    CapXon's:
    http://i.imgur.com/QYlLo.jpg
  • Pentium4
    replied
    Originally posted by 370forlife
    LFX and LFJ are series of NCC, a good cap brand.
    Okay thank you for the info, I didn't know there were a bunch of sub brands
  • robert.wilson
    replied
    Originally posted by shovenose
    Is it green or blue?
    Green=Xicon's Low ESR series
    Blue=Xicon's GP series
    Its actually Yellow
  • PCBONEZ
    replied
    Here's a hint.
    Mouser and Xicon have the same address in Texas.
    http://www.macraesbluebook.com/searc...company=440357
    http://www.mouser.com/contact/
    I doubt Xicon actually manufactures[ed] caps.
    There old site was www.xicon-passive.com but now that redirects to Mouser.
    I think they were a rebranding distributor and not actually a manufacturer.
    Mouser is phasing out Xicon caps and replacing with Lelon.
  • shovenose
    replied
  • robert.wilson
    replied
    where do I find the list of bad cap manufacturers. I am questioning a cap with the markings of "xicon" its a 470uF at 16vdc
