panasonic fj counterfeits?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    got a huge lot of leftover stock from an oem.
    sprinkled in a lot of rubycon mbz were these panasonic fj
    look at the bungs.
    look nothing like the fc/fm i have on hand.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: panasonic fj counterfeits?
    in the last pic the fm is on the far right.
    edit.
    the one on the right in the 3rd pic is a genuine fm from digikey.
    • linuxguru
      • Apr 2005
      • 1564
      The bungs in the 2nd picture from the left are wrong; the one in the 3rd pic is good, and similar to the ones in the Malaysian FJs that I have.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the codes stamped on the suspects even goes the wrong way and is a different color too.
        • Phenos
          • Oct 2006
          • 46
          I have some Teapo's here with a panasonic vent, i removed them from my sapphire grouper mobo. (SM105c A8 03/04) Maybe somekind of an OEM product.
          • Big Pope
            Approved Vendor
            • Dec 2005
            • 426
            Agree, the 2nd picture looks counterfeits more, because the cost of bang(3rd picture) is more expensive than the 2nd one.
            My SAMXON Capacitors Database HERE!!
            X-CON is a new brand for SAMXON's Polymer Capacitors.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              edited post above to eliminate confusion.
              the real panasonic part in these pics has full leads and the more complex bung.
              often wondered about the purpose of the fancy molding there.
              maybe to allow a path for venting?airspace for cooling?
              • Krankshaft
                • Jan 2007
                • 2328
                Yes I agree with BP the second cap with the simple flat bung with circles in it is probably a fake.
                I've seen those cheap bungs in elite capacitors, hermei caps, and other cheap and bad brands which strengthens the fact that they are cheaper to produce since they require less rubber.
                The type of bungs I see when I buy real Panasonic FCs from Digikey are in picture 3.
                Trust me I know my bungs .
                I always wondered why the bungs were shaped like that too?
                Nippon Chemicon uses a similar design on their bungs as well.
                • PeteS in CA
                  • Aug 2005
                  • 3580
                  • USA, Unsure of Planet
                  The cheesy bungs with the concentric circle pattern is familiar from crap-caps, a sign to me that those are almost certainly phonies. The complex bung is to permit cleaning (usually water nowadays) under the caps after stuffing and soldering whatever PCB the cap is installed in. The FC I looked at a couple of days ago has the complex bung, as do Nichicon, UCC and Rubycon. That red date/lot code is really hard to read on the dark blue FCs and black FMs, but it also seems to be characteristic of Panasonic.
                  PeteS in CA
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    note the date/batch code printing runs lengthwise in the real ones.
                    and i figured the fancy bung was to avoid trapped cleaners after i posted and left the pc to go for our families thanksgiving gathering.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i just got in a dvr psu with g-luxons in it .
                      they have the same "bullseye"bung
                      • PeteS in CA
                        • Aug 2005
                        • 3580
                        I've seen it on Lelon and Jianghai parts (the latter smelled like really bad fish!).
                        PeteS in CA
                        • Andre Gilbert
                          by Andre Gilbert
                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                          11-20-2024, 08:52 PM
                        • AquaMan Ua
                          by AquaMan Ua
                          05-17-2025, 09:40 AM
                        • stecos
                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                          by stecos
                          Hi everyone!
                          For my passion for technology I'm now collecting several...
                          11-28-2022, 11:39 AM
                        • aa10aa10
                          Panasonic Toughbook CF-33 mk1 BIOS repair
                          by aa10aa10
                          Good day,
                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                          01-21-2025, 06:13 AM
                        • Mnawar27
                          Panasonic CF-H2AU24EF3 bios locked
                          by Mnawar27
                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                          I need help to remove it,
                          thankyou all.
                          SN; 2FKCA26876...
                          11-16-2024, 08:00 AM
