KitchenAid/Whirlpool PCB issues
  • keithwbloom
    • Mar 2011
    • 12
    I have a drawer type under-counter refrigerator that has a wonky PCB. I would normally by now have just given up and ordered a new replacement, but apparently the manufacturer/supplier for this particular board was wiped out in the mainland Japan tsunami a few years ago. So the only option is to repair. There is a service that does repair/recondition for a fee, and I have already used them without success. Not even at all sure they did anything to my board at all, as all components look undisturbed.
    Here's the wonky part — it works fine when it is not installed in the unit vertically. While it is laying in the floor behind the unit, the fridge works perfectly, albeit the power supply relay is more audible (louder click.) Once it is installed vertically in the slot that holds the housing, it starts cycling power every 2-3 minutes, and eventually starts timing out completely for 10 minutes or so at a time and then repeats the loop.
    So amateur that I am, and after having great success with replacing bad caps and MOSFETs on a couple of power supplies using the DIYs on this forum, I am back again because I am solidly at my wit's end.
    So here's the PCB:
    Another view, closeup of some of the caps:
    And this is how it sits horizontally on the floor and works:
    There is a thermal fuse that attaches to the outside of the metal housing, which I thought may be suspect, but even when left unattached and dangling away from housing when the board assembly is reinstalled, the cycle/timeout symptoms still occur
    So my question... are there any component types on that PCB that might suddenly become hyper sensitive to orientation after years of normal operations?
    I should add that I have examined as closely as I could with magnification the connectors and harness wires for stress breaks or any other kind of problem that might occur when they are manipulated into position for board installation. I did not see anything that looked amiss.
    Re: KitchenAid/Whirlpool PCB issues
    What happen when you have it laying on the floor and you poke it with plastic or wooden stick? Since it is mounted in the metal box, you do not see it making fault contact with the metal box and what happen if you move the box in different orientation?
    • vinceroger69
      • Mar 2012
      • 6714
      Try resoldering the large transformer thats on the board ive seen them become dry jointed on various boards.
      • pfofit
        • Jun 2008
        • 10
        Model # please and does it have auto defrost.?
        Need an in focus pic of the underside. The relays as well have their solder connections go bad, so resolder that T9 relay
        Moving the board correcting the issue probably indicates a bad joint, cracked foil or flaky connector harness. Look inside the harness ends to see if female pins are spread to far apart.
        That thermal fuse is most likely a thermostat or re settable over temp cutoff. Where exactly is it located? Pic!
        • keithwbloom
          • Mar 2011
          • 12
          Thanks for everyone's feedback. I'll post additional photos and feedback shortly. I have a macro lens for my iPhone I will use for extreme closeups.
          • keithwbloom
            • Mar 2011
            • 12
            PCB full view overhead and then four quarters
            Photo 1:
            Photo 2:
            Photo 3:
            Photo 4:
            Photo 5:
            PCB reverse side full view overhead and then four quarters
            Photo 6:
            Photo 7:
            Photo 8:
            Photo 9:
            Photo 10:
            The service sticker from the authorized agent
            Photo 11:
            Photo 12:
            Photo 13:
            Photo 14:
            The trans
            Photo 15:
            The relay
            Photo 16:
            Photo 17:
            Closeup of caps farm
            Photo 18:
            Photo 19:
            Photo 20:
            The four MOSFETs (I think that's what they are called)
            Photo 21:
            Photo 22:
            Some other disc style caps:
            Photo 23:
            Photo 24:
            Three photos of where PCB assembly is located when installed
            Photo 25:
            Photo 26:
            Photo 27:
            Where the thermal fuse is mounted on outside of PCB case when installed
            Photo 28:
            When mounted, PCB is isolated on plastic clips, no ground contact is made.
            Photo 29:
            Presently testing in this vertical orientation outside of frame mount
            Photo 30:
              • 31293
              it's bad solder joints, i can see it in the foto's
              first resolder all the connectors and anything large.
              by resolder i mean remove the old solder first, not splash more ontop.
              the cables pull and put alot of stress on the connectors.
              next look at any soldering left for rings or halo's / shadows and resolder them too.
              • pfofit
                • Jun 2008
                • 10
                Start with these joints and any others that look the same.
                as per other techniques on soldering, remember you have a dual sided board so you need to get solder to other side for good connections.
                But too much heat for too long and you may start to lift foils
                cheers, good luck.
                • keithwbloom
                  • Mar 2011
                  • 12
                  cheers, good luck.
                  So I have a hot air rework station and a squeeze bulb vac. I think I can clean these joins and resolder, probably will do most if not all of the connectors and large components.
                  If you don't mind briefly explaining, what is wrong with these joins and what may have cause them to deteriorate over time? Should I take any further precautions if the fix is successful?
                  Cheers,
                  Keith
                    • 31293
                    vibration and gravity make large parts pull on the joints.
                    this makes the solder crack into 2 parts - the part on the wire and the part on the pad.
                    the cracks are very fine, but once you know what your looking for - they are easy to spot.
                    they look like a ring or halo around half way between the center and outside of the joint.
                    • pfofit
                      • Jun 2008
                      • 10
                      Hi keith.
                      They joints can be bad for a few reasons.
                      They are large heavy components with heavy wires that didn't get heated enough during the solder wave process. In essence their large size and/or what the leads are connected to act like a large heat sink and therefore the joint is "cold". Cold solder joint.
                      This results in a crappy joint that is brittle and not really stuck to the two pieces that one is trying to join. The joints should be shiny and even.
                      They can be seen by your photos. They tend to be discoloured,pitted. In your photos i can see a burnt,pitted discoloured joint like where the pin is in the middle of the solder. This shows that the joint is a poor connection and the joint is therefore heating up. Which causes more deterioration of the joint and so on. Now, we know you have an intermittent issue and your joints may be so-so for now but they won't last because they don't look good so one would start with the easy stuff.
                      As well, after these large components are installed the weight and vibration of the component can stress even good joints. Also, removing and replacing plug connectors can weaken the joint.
                      Below are a few images of the many bad appliances board in my spare parts bin.
                      To the unknowing eye, in the first image, it doesn't appear so obvious, but zooming in with the second pic shows the end joints are starting to crack. Both of these bad joints are on the ends of a plug connector. The left one indicated is not cracked all the way around yet but the other is. So any flex/ movement of the harness combined with changing environmental temperatures would cause the joints to mess around th electronics.
                      3 & 4 are what happens when it's not corrected in time. This is a stove board where the two halfs fold together and are about a half inch apart when assembled. The right side is AC ac power and the other is low voltage Mirco and stuff.
                      When the bad joints on the relay connection for the the bake element further degraded due to heat etc, 10-15 amps at 220 started sputtering across the corroded connection and then started arcing all over the place, got to the other side and we all know that micros don't like 220 AC. The white trace lines on the left are the foil vaporized off the board
                      The 5th pic is just another I threw in that was even more violent and actually burned down into the physical board once the arc welding got going.
                      These stove boards are a bad design when the joints go bad. The back sides of the boards have conformal coating so sometimes the joint pops and blows carbon all over and is easy washed off with no harm. A new relay and rebuild the foil respray a coating and good to go. However, i got a bin of dozens where the damage is catastrophic. Since they started years ago, removing the bank of screw in fuses there is nothing to shut it down except the main panel 40 amp breaker or the board foil. Of coarse we all know which is gonna lose.
                      cheers
                      • wnlewis
                        Whirlpool RDE3340W electric Range needs On-Off-On rocker switch, McGill 0801-1059, FSP 686605, Whirlpool p/n 865745
                        by wnlewis
                        I am trying to track down a replacement rocker switch for a Whirlpool RDE3340W electric range.
                        The rocker switch was made by McGill under their part number 0801-1059 and supplied to Whirlpool by FSP under their part number 686605. Whirlpool's original part number was 865745.
                        The switch is an On-Off-On type (SPDT) designed for use with either 115 VAC or 230 VAC. It is not lighted.
                        Are there any current switches that could be substituted for this switch?
                        01-04-2025, 09:32 PM
                      • gretti
                        MSI Z370-A Pro, works but does not power off or reboot and USB issues
                        by gretti
                        I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                        The MSI BIOS included the ME firmware for the board. The size...
                        10-16-2025, 02:14 AM
                      • SoulFreeze
                        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                        by SoulFreeze
                        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                        After repairing the above issue, I realized the following remaining problem,
                        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                        The computer recognizes headphones are connected and displays a popup in windows
                        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                        06-21-2025, 09:53 AM
                      • Nagyesz
                        Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                        by Nagyesz
                        I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                        All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                        How can I extend its lifespan? Could reflow help?
                        It has ryzen 5 5500h, rtx 2050, no soldered ram.
                        Example of the artifacts:
                        03-01-2025, 11:11 AM
                      • Joe24
                        Maytag Whirlpool Kenmore clothes dryer data bus
                        by Joe24
                        Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                        Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                        I've been over the board looking for...
                        01-13-2025, 06:50 PM
