Recap gone bad
  • aphex
    • Aug 2007
    • 16
    Recap gone bad
    I was reading this forum and found out that my new Foxconn MB has about two dozens of Evercon 6.3v 1000uF (fromerly GSC, I assume) and 3 Lelon.
    So I tried to recap those with Samwha WZ and WB series.
    While doing this, I made some mistakes.
    As you can see in the picture, I had a pad blown off.
    After doing some research on this forum, I put out a digital MM and checked the blown off pad (it was below PCI slot and negative side). It seems like the via is still intact because it showed perfect connectivity with other cap's negative side. Am I right?
    Also, I've scraped some coating near a pad and soldered it with pad.
    It was the one located near USB and SATA ports and it was positive side.
    Should I cut the connection with a pick or something?
    Is this OK to use this board, or should I dump it?
    I have little knowledge about Electrics. I am worried that some other major component would fail if I power up this board.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Recap gone bad
    I think it should still be OK, it it's only the pad that went, I'm pretty sure that there's still the Vias inside the damaged hole. From the pictures I can see that the solder is sticking down very nicely so I guess theres still foil inside the hole. So I think you are still lucky in getting your motherboard to work.
    I had the same problem with my PC Partner motherboard a few months ago. I also damaged the soldering pads, but the vias was still OK and I put in new caps and it booted up well with no issues.
    PC Partner board: https://www.badcaps.net/forum/showth...7&page=1&pp=20
    About the continuity measurement, I'm not very sure about that, but I think the caps have to be in parallel to show a continuos connection. I better leave that part to others who know a bit more about the MM measuring techniques.
    The scratch you mentioned doesn't look too bad in the picture. It hasn't scratched the traces near the caps, all it's scratched is some paint (or solder mask), so there probably won't be an issue. Look at my thread on the PC Partner board, it looks much worse with all the scratches around the caps, but it still works fine.
    If you power it up and the vias is damaged, no it will not destroy any component, just make sure the cap you soldered isn't shorted due to excess solder etc. otherwise you might end up with a dead board and possibily some smoke. If the vias is damaged, your board will just simply turn on and have no POST or it may not even turn on at all.
    Hope it all goes well for you in the end.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Re: Recap gone bad
      Before you fire it up, get some sort of video recording device. When it catches fire, I want to see!
      HA! Just kidding. The worst you should get is no post or flaky board. Try it out.
      • aphex
        • Aug 2007
        • 16
        Re: Recap gone bad
        Thanks for your replies.
        I just went out to buy a fire extinguisher.
        I'm now more worried about the pad and adjacent PCB being connected together, but I'll try to power it up after I finish cleaning my keyboard.
        I just spilled some coffee on my beloved Alps mechanical keyboard.
        I guess today is my shit-happening day.
        I'll let you know how it works.
        • aphex
          • Aug 2007
          • 16
          Re: Recap gone bad
          I tried it out and it worked well.
          It went through 2 passes of Gold Memory and now running MemTest.
          However, overclockability has been compromised somehow.
          I have an Intel Pentium dual-core E2160 and it took 333 Mhz FSB (1000 Mhz for Hynix PC6400 DDR2 RAM) before recap, but now it won't boot at 300 MHz or higher.
          Maybe I'll just stick with 299 MHz for now.
          • stevo1210
            • Oct 2006
            • 4156
            Re: Recap gone bad
            Aphex, it's good to hear that you got it working correctly.
            As to overlocking, I have no idea why you could overclock it higher before the recap....
            I'll leave this for others to comment on. Personally, I've never had good luck at overclocking so I never do it.
            • gonzo0815
              • Feb 2006
              • 1600
              Re: Recap gone bad
              May be your soldering wasn`t perfect. It is hard to get the solder flowing into the solder hole, like the factory process does.
              This may affect OC may be.
              On the other side, your cap choice is somehow not the best, may be those Samwha caps are not much better then what you removed from the board.
              So i think if you are in overcloking, you certainly should have sourced some better caps like Panasonic FM, FC, Samxon GD GC or Rubycon MCZ, MBZ, may be ZL.
              Those Evercon sure are bad and wouldn`t stand very long, but this does not mean, that their specs are bad.
              I personally would have left the Evercon until they would show problems.
              • aphex
                • Aug 2007
                • 16
                Re: Recap gone bad
                Well, I was thinking about changing the caps later, but thought it would be too much work involved once I set my system up.
                As for the capacitor choice, Japanese caps are too expensive and hard to find here in Korea. For example, Panasonic FC would cost about $4.00 each. Then it would cost me more than the board itself because I had to change 25 or so.
                Maybe next time I can change some important capacitors with better ones but I don't have any idea which one is doing more important job.
                • Newbie2
                  • Sep 2005
                  • 885
                  Re: Recap gone bad
                  Big Pope here sells SAMXON caps, which are a little more economical than comparable Japanese capacitors.
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Re: Recap gone bad
                    It`s probably due to custom fees, or why are those Pannies that expensive.
                    So i think even those Samxon would not get in to the country as economically they are.
                    • Fizzycapola
                      • Oct 2006
                      • 423
                      Re: Recap gone bad
                      @$$# happens (sometimes even if you do everything 100% correctly [I think it's the daily "1/5bil odd fairy" that causes it - so it's gonna happen for sure to someone somewhere every day despite all the praying in the world - hopefully not to the same person over and over though. [in such a scenario one should check out the local neighborhood's religious sects to see how many Damien's and Thorns are registered.)
                      Rubycon Rubycon Rubycon
                      • Fizzycapola
                        • Oct 2006
                        • 423
                        Re: Recap gone bad
                        The flow of electric is what counts. If it still goes in the right directions it should then no problems.
                        I cook and lift pads by accident all the time, (it's low voltage and not really worth much money I don't need to care). They just add resistance because of impurities I think, even snip them off if too dirty to acid clean even and make your own blob pad of clean solder perhaps (with tip tinner?) properly bonded to the cut off point. The gap around the solder pad shouldn't be breeched of course - is usually grounding area.
                        • Leung Kai-yan
                          • Apr 2006
                          • 32
                          Re: Recap gone bad
                          Dear Friend,
                          If the two pins of the PW SW/PW BTN on the mainboard yield the reading of low resistance (1XX-2XX ohms), it means no explosion with the power supply on but with no AC supply.
                          • Leung Kai-yan
                            • Apr 2006
                            • 32
                            Re: Recap gone bad
                            Dear Friend,
                            The job mentioned in the above post can be done easily with these instruments (see attachment).
                            • aphex
                              • Aug 2007
                              • 16
                              Re: Recap gone bad
                              Originally posted by Leung Kai-yan
                              Dear Friend,
                              Thanks for the info. I have a digital multimeter and will try to remember the information next time.
                                ASUS P5GC-MX motherboard recap
                                by momaka
                                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                So here is what the motherboard looked like with its original caps:
                                CPU VRM area up close…...
                                01-27-2021, 11:59 PM
                              • laskr1999
                                DFI Lanparty NF3 250GB complete recap help
                                by laskr1999
                                Hello!
                                I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
                                I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
                                I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
                                - 20 x Nichicon 1000uF 6.3v HM 105C
                                - 5 x Chemi-con KZG 1000uF 10V
                                - 1 x Chemi-con KZG...
                                11-25-2025, 03:27 PM
                              • varunviolin007
                                Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                by varunviolin007
                                Hi guys,
                                I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                Looking for someone experienced with older PC boards who uses...
                                07-29-2025, 11:53 PM
                              • Foetuss
                                Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                by Foetuss
                                Hi all
                                Hope this is in the correct place.
                                I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                Could use some double checking to see if I'm not doing something stupid .
                                Pictures of the boards are attached.
                                What I will be replacing with what : (planned)
                                Soltek Golden ::
                                4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                01-18-2025, 11:44 AM
                              • goodpsusearch
                                Got 4 LG L222WS 22" for free - psu recap
                                by goodpsusearch
                                Got 4 CCFL 16/10 monitors for free.
                                The resolution is almost Full HD (1680x1050)
                                VGA Input only is a bummer though.
                                Uses cheap TN panel with terrible viewing angles.
                                Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                                All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                                01-15-2022, 05:36 PM
