Having random reboots.
  • Logistics
    • Apr 2007
    • 721
    Note: This doesn't happen often. This is only the second time it's happened in the last month or two. Last time I shut the system all the way down, inspected the video card for bad caps, all looks fine. My motherboard is an Asus P4PE and all the caps look fine. I can't tell what the manufacturers are at the moment... except one which is OST. heh! Maybe it's just time to recap the mobo? Anyway...
    I was just be sitting here, reading the forums. Media Player was open, though not playing. A folder open containing MP3's, two or three seperate Firefox windows running, suddenly the system reboots.
    I recently recapped the Antec SL350 in this system cause it blew some caps. IIRC, the symptoms before were instances of Firefox crashing more and more often and then maybe a reboot, I can't remember and I'm too lazy to check my old threads right now. Anyway, I've been having instances of Firefox crash again, always due to Flash.
    When I recapped the SL350, there were two 1uF capacitors, but I neglected to notice that one of them was non-polarized when I took them out so I followed a friends suggestion and put polarized caps back in both locations. I also had to put back a 330uF Fuhjyyu because it was a 6mm and I can't get a 330uF 6mm from BadCaps nor Digikey... or at least not in the voltage it called for. Every other electrolytic in the supply was replaced, including the 200V bigguns', with Panasonic caps if they weren't available in Samxon.
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
  • starfury1
    • May 2006
    • 1256
    Re: Having random reboots.
    well no expert but yeah flash firefox.....might be more likely considering the amount of recapping you have done.
    Flash I have notice it the past seem to cause probs, but not the SW guru here.
    firefox has been updated to 2.0.0.6
    (usual story I suppose, fix some bugs and security holes then create others....)
    Sure HW fault is a possibly but I am thinking more SW glitch
    On the HW side, how is the power in your area?
    are you using an ups line filter etc?
    I have notice when there is a phase change here it will reboot or possibly BOSD
    (power company switching phases to keep it all balanced, equal load across 3 phases, lights usually dim or go off for a split second from what I understand)
    although large I/P caps (and depending on the load on the psu) may hold thorugh a small mains power glitch.
    just another possibility since you say it happens rarely (at this point).
    I guess the only way to be sure its the PSU is to monitor/log the psu supply rails... humm now thats got me thinking.
    Anyway no real help here, just possibilities
    Further thoughts, you could be right.... maybe the MB is up for a recap
    Cheers
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • bgavin
      • Jan 2007
      • 1355
      First, determine if hardware or software. Boot up DOS or the Memtest86 .iso image which runs on a Linux kernel.
      If software, FDISK and FORMAT usually cures that problem.
      If hardware, swap in a spare power supply and continue the diagnosis with minimal hardware installed. Remove all but the video card during testing.
      If you come down to hardware, and the system board, recap if you feel it is worth it.
      • Logistics
        • Apr 2007
        • 721
        starfury1: I appreciate it, in any case. Maybe I'll finally let Firefox update itself. Hehe! That's interesting about the phase switching. Although, the only thing I've ever seen cause a brown-out in our house is my brothers air-conditioning coming on. When my mothers' is on as well and lots of other things are going in the house, the brown-out has been bad enough to reset the router in my room, possibly even the DSL modem. Grrr!
        bgavin: I did a fresh partition/format and install of XP not too long ago, but maybe I'll see about giving it another go. I think I'll also try to locate a cap to replace that 330uF 6mm and since my brother has an SL350 in his system, I'll open it up and see where that bipolar electrolytic was suppose to go and perhaps install the one I got in my PSU. Means this is my main system I may as well recap the motherboard, soon as well. I'm not a gamer, anymore so I have no need of upgrading... although, it would be nice to have a bit more power for Photoshop. Heh!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          dunno about firefox, i have been completely stable here for a while.
          i would run a memtest86+ to check the ram. firefox can grab a whole bunch of ram, they said they are fixing this in ver3.
          anything interesting in event viewer?
          difficult to eliminate mains power issues if you dont have ups. i think mains power is gonna get worse all over with current consumption rising
          • Paul S
            • Sep 2006
            • 326
            If it is software related, have you recently installed new drivers for anything?
            XP has a program that will restore itself to a previous configuration (before an update or software install). If you haven't disabled it, you can do a rollback and see if the problem still exists.
            It's called System Restore, and it is under the System Tools menu.
            • Spacedye69
              • Nov 2005
              • 698
              • US
              Asus will also use Elite caps on the VRM i/p. I would recap the board. Get the Ultimate Boot CD. It has memtest and mobo burn in software to check hardware. Use the hard drive tools also to check your hd.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                if it has elite or ost at the vrm o/p they are bad.replace and run it.
                see this often.the elite sizzle when you desolder and stink badly.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  those skinny blue/purple ost do that also
                  • starfury1
                    • May 2006
                    • 1256
                    figured logistics had been round long enough to have done a recap but if not yeah it could be the start of the down wood spiral.
                    Especially if does have crappy caps
                    just to expend on the power thing
                    the old Enermax has 820 uf I/P caps and only drives the old gigabyte 7zxe 1600 Amd MB
                    It will hold for nearly a second when it happens
                    (I've know the monitor to go black and the box hold)
                    This when it was on the channel well crap would die reboot in no time.
                    (dont think it fairs much better on the Liberty 620W)
                    So thats why I mentioned it as a possibly since you said it only happen a couple of times (so far)
                    If you do crack open the other psu
                    Please Post a photo of it and were that bipolar cap is for reference.
                    I found that interesting not that I look too hard at PSU's or see a lot of them but I haven't noticed one of them before in a psu...well from memory anyway.
                    goodluck with it and hope a recap fixes it
                    (SW issues...now where's the nearest wall)
                    Cheers
                    • Logistics
                      • Apr 2007
                      • 721
                      Well, I guess I can rule out software. I had gotten a couple more reboots since last posting. And tonight, all I was doing was opening a folder full of jpg's and the screen froze for a couple seconds, then came back (I kept moving the mouse) then froze again and then went black. It didn't reboot, though! So I reset it and it showed the video card information, but didn't make it to the post screen where it counts RAM; it just went black again and stayed that way.
                      Yes, my P4PE has OST all over it. I can't tell what the big ones near the CPU are atm, but they are obviously someone elses because they have K-Vent instead of the cross-hair. The only other culprits I could think of were: The 330uF Fuhjyyu I had to put back in the PSU because I couldn't get ANYTHING but a smaller value in a 6mm and an 8mm absolutely will not fit, a 1uF 50V Fuhjyyu I put back because I was impatient and didn't have the replacement from Digi-Key OR the two G-Luxon's on my GeForce FX.
                      Naturally, there are no bulging caps or electrolyte visible.
                      • starfury1
                        • May 2006
                        • 1256
                        Well suppose if you haven't logistics the simple short answer is recap the MB
                        it probably wont hurt anyway, and hopefully will be the prob.
                        The freezing and random reboots are are typical symptoms of badcaps
                        (just not the only cause badcaps thats is)
                        Caps can fail without popping too
                        As to the Psu ok yeah possible maybe but doubt it, but if you can source what you need then way not...again it wont hurt and at lest you have cleared those caps.
                        (you said I think you had done a fairly extensive recap of it, so barring any issue you may have created there or any that may have been pre existing it should be ok.)
                        of course it would have been better if you had checked them before you re used them but if you don't have the test equipment then not much you can do.
                        The ones most likely on the MB are the VRM caps, so if you cant get all the caps you need Id concentrate on replacing them first.
                        (especially if you got size issues between slots etc with the other caps, not to say you may not have size issues with the VRM ones thought)
                        Of course if you do have an ESR and capacitance meter then check them to see if they are out of spec, but if not just ripped em and replace them.
                        Cheers and really hope a recap solves it for you
                        • Badcappy
                          Banned
                          • Aug 2007
                          • 52
                          Try to recap the board, it might help or solve the problem.
                          • grimacelord
                            A2338 820-02020-A | Battery Not Detected/Random Reboots
                            by grimacelord
                            I have a A2338 MacBook Pro here that came to me because the battery wasn't being detected. The owner tried to replace the battery themselves thinking that the battery was the problem but the behavior continues even with their new aftermarket battery. They also accidentally ripped off the black plastic clasp to the battery flex cable connector @ J5151, but I pulled that off of a donor board and replaced that for them already. I did quickly check to see if that was simply the problem, but it's not.
                            First thing I checked was I2C_SMC_PWR_3V3_SCL and I2C_SMC_PWR_3V...
                            Today, 09:11 AM
                          • Hondaman
                            Firefox is now SATANIC
                            by Hondaman
                            Now that I have your attention:
                            In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                            I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                            I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                            03-05-2025, 04:41 PM
                          • Psychedelic
                            Corsair AX850 low 12v and 5v voltage with random reboots.
                            by Psychedelic
                            Hi guys,
                            I am having problems with an Corsair AX850 Gold PSU. I have had the PSU FOR around 8 years but it had not been used much. This PSU was used to power two video card and an i7 CPU originally. I noticed that the 12v power was going as low as 11.4v and the 5v was going lower than 5%. I was getting random reboots. I found that the motherboard socket had bent pins and one actually broke. Therefore, I assumed that was the problem and not the PSU. I rebuilt a whole new system. This time AMD. I decided to use this PSU since I had it.
                            Now with the new system I am still...
                            02-17-2021, 06:19 PM
                          • Prosatanosz
                            Asus B85M-GAMER no hdmi output and random restarts
                            by Prosatanosz
                            Hi!
                            Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                            10-19-2024, 05:27 AM
                          • Dreigas
                            Asus TUF Gaming FX506LX laptop just stuck at random time
                            by Dreigas
                            I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areas—about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
                            One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
                            07-27-2024, 05:58 AM
