Note: This doesn't happen often. This is only the second time it's happened in the last month or two. Last time I shut the system all the way down, inspected the video card for bad caps, all looks fine. My motherboard is an Asus P4PE and all the caps look fine. I can't tell what the manufacturers are at the moment... except one which is OST. heh! Maybe it's just time to recap the mobo? Anyway...
I was just be sitting here, reading the forums. Media Player was open, though not playing. A folder open containing MP3's, two or three seperate Firefox windows running, suddenly the system reboots.
I recently recapped the Antec SL350 in this system cause it blew some caps. IIRC, the symptoms before were instances of Firefox crashing more and more often and then maybe a reboot, I can't remember and I'm too lazy to check my old threads right now. Anyway, I've been having instances of Firefox crash again, always due to Flash.
When I recapped the SL350, there were two 1uF capacitors, but I neglected to notice that one of them was non-polarized when I took them out so I followed a friends suggestion and put polarized caps back in both locations. I also had to put back a 330uF Fuhjyyu because it was a 6mm and I can't get a 330uF 6mm from BadCaps nor Digikey... or at least not in the voltage it called for. Every other electrolytic in the supply was replaced, including the 200V bigguns', with Panasonic caps if they weren't available in Samxon.
