2200uf 10v cap replace with 6.3v?
  • jasonbay13
    • Jul 2014
    • 195
    • usa
    i have a westinghouse monitor 19" that had been taking 5-15 minutes to come on, so i decided i'd open it up and check for bad caps. well, i found 1 bulging.
    the bad cap is 2200uf 10v capXon p723. radioshack never carries anything and i dont want to wait 3 weeks to get caps over the internet. i happen to have a broken computer with a few 2200uf 6.3v sanyo n.e.91 caps. would one of those work fine? or would it just go bad right away since the slightly lower voltage rating?
    and should i replace more than just the bulging cap?
    • 31213
    Re: 2200uf 10v cap replace with 6.3v?
    if the voltage is even close to 6.3v the sanyo will explode - literally.
    i wouldnt chance it.
    if you have a broken computer, see what's in the psu - that's gotta have 10v and 16v rated caps in it.
    • jasonbay13
      • Jul 2014
      • 195
      • usa
      i found a single 2200uf 16v SXE brand with
      (M)105c | 7(7) | 8I
      on the side, would this be a good replacement?
      although, i just checked. i might not be able to get the case back together if i do use that one, its too tall. by about a quarter inch
      But! if i can run small wires and hot glue it in place elsewhere on the board... - is this a bad idea?
        • 31213
        it is a bad idea,
        you could use it with the case open to see if it fixes the problem though.
        what other caps are in the psu - 10v or 16v type?
        • jasonbay13
          • Jul 2014
          • 195
          • usa
          there are no other 2200uf caps in the psu. others in it are 16 and 50v.
          why would it be a bad idea to extend the legs on the cap and place it elsewhere?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5038
            • New Zealand
            Yeah if it's too tall it would still be good for testing. If it works, great, you know what the problem was.
            Then you should order some decent capacitors for a full recap anyway, especially if the rest are the same brand as the visibly failed one.
            You could use a 16v one, higher voltage rating than the original is OK, just not lower.
            Extending the leads is a bad idea as it introduces additional resistance which defeats the purpose of a Low ESR capacitor to begin with. Also may increase lead inductance which adds its own problems.
            -David VanHorn
            • jasonbay13
              • Jul 2014
              • 195
              • usa
              if i have the choice, should i care about other factors besides the uf and voltage?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                in that monitor its likely on the +5v line.
                the 6.3 will be fine.
                replace all on the power supply now or one at a time.your choice.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  no it wont.
                  in fact it will work fine.it will see 5v in that position.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5038
                    • New Zealand
                    If you are talking about getting proper replacements as opposed to any old cap just for testing, then yes.
                    Capacitance (in this case, microfarads\uF) should be the same, voltage the same or higher, check the dimensions (as you already found, to make sure it fits) and ensure you get the ESR low enough.
                    Ideally you should look up the datasheets for the original capacitors and makes sure the replacements match - ESR same or lower.
                    In practice though you can generally get away with any standard Low ESR series from any decent brand.
                    -David VanHorn
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      This. I do it all the time. If unsure, measure the voltage on the cap, if its 6.3v or less, a 6.3v replacement cap will be just fine.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • jasonbay13
                        • Jul 2014
                        • 195
                        • usa
                        thanks for all the input, i'm trying to desolder one of the 2200uf caps now. though it seems my tip isnt as effective as the first time i used it. do they require proper maintenance to keep working well?
                          • 31213
                          as long as it's clean
                          i use a brass-wool tip cleaner - none of that wet sponge shit!
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            I've used a wet sponge for over 25 years, always been A-OK!!
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5038
                              • New Zealand
                              The tip should be clean and a silver colour. If it's not, it's oxidized and you will have problems. Check this out: https://www.youtube.com/watch?v=I_NU2ruzyc4
                              Is the capacitor on a multi-layer PCB? They are much harder to work on. Give photos of the capacitor and PCB if you are unsure.
                              What is your iron? Some may not have enough power. Make sure you add fresh solder to the joint first too, to ensure maximum heat transfer through the fresh solder from tip to joint.
                              -David VanHorn
                              • jasonbay13
                                • Jul 2014
                                • 195
                                • usa
                                Got it all soldered and put back together, plugged it in and the screen came right up saying no input signal. thx for everything.
                                This ^^
                                I got a weller "medium duty" from lowes.
                                i have another thread in tv's. it has no backlight, it seems to be the inverter board, but no caps are bulged...: https://www.badcaps.net/forum/showth...496#post461496
                                • Sparkey55
                                  • Jan 2010
                                  • 1523
                                  I have used the wet sponge for over 40 years with no problems. I consider myself "Sponge Worthy", Sienfeld joke.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5038
                                    • New Zealand
                                    That's when the fun starts
                                    But bear in mind not all bad capacitors bulge. That's where the ESR meter is handy.
                                    -David VanHorn
                                    • larrymoencurly
                                      • Oct 2004
                                      • 960
                                      Are Sanyos more vulnerable to that than other brands? Because I replaced a bulging 10V, 2200uF Koshin brand cap with a 10V, 2200uF Sanyo, and 2 years later it bulged.
                                        • 31213
                                        to make a capacitor bulge you either have to run it on it's voltage lmiit or put high rfequency ripple into a cap not designed for it.
                                        what i posted was something else,
                                        as a design rule a cap's minimum voltage should be 1.5x the input voltage to allow for the ripple.
                                        5v x1.5 = 7.5 NOT 6.3 so using a 6.3v cap on a 5v line is asking for trouble down the road.
                                        • ssl6
                                          MSI K7T266 Pro (Ver. 1.0)
                                          by ssl6
                                          Hey Everyone,
                                          Long time lurker, but I think this is my first time posting.
                                          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                          11-09-2023, 01:00 PM
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
                                        • howardc64
                                          HP Inkjet printer main board bulging cap failure
                                          by howardc64
                                          Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
                                          https://h30434.www3.hp.com/t5/Printi...t/true#M997922
                                          02-03-2025, 09:50 PM
                                        • cloppy007
                                          [MSI KT3 Ultra ARU] Advice on capacitor choice
                                          by cloppy007
                                          I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
                                          The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
                                          There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
                                          I think I recall hearing that I don't have to use the same capacitance for in series...
                                          08-21-2023, 03:18 PM
                                        • rattlesnake
                                          Soyo SY-7VBA133U recap
                                          by rattlesnake
                                          Hi guys,
                                          I'm going to recap this baby. I found it dumped in the street years ago, and now it's time has come. I remember having tested it and it posted back then.
                                          Original caps are bulged and look nasty. All are SACON
                                          11 x 1000uF 10v
                                          12 x 1500uF 10v
                                          1 x 470uF 16v
                                          11 x 22uF 25v
                                          1 x 10uF 25v
                                          The smaller ones look fine. Should I replace them too?
                                          I read on another forum that I could replace the 1500uF caps with 2200uF caps. Is that so?
                                          The thing is I could get Sanyo 2200uF or Capxon 1500uF (or Jackon 1500uF)....
                                          04-10-2022, 06:47 AM
