Soyo SY-7VBA133U recap
  • rattlesnake
    • Dec 2017
    • 78
    • Argentina
    Hi guys,
    I'm going to recap this baby. I found it dumped in the street years ago, and now it's time has come. I remember having tested it and it posted back then.
    Original caps are bulged and look nasty. All are SACON
    11 x 1000uF 10v
    12 x 1500uF 10v
    1 x 470uF 16v
    11 x 22uF 25v
    1 x 10uF 25v
    The smaller ones look fine. Should I replace them too?
    I read on another forum that I could replace the 1500uF caps with 2200uF caps. Is that so?
    The thing is I could get Sanyo 2200uF or Capxon 1500uF (or Jackon 1500uF).
    Since there's not a broad offer of caps where I live, I was wondering, what's best.
    All the help is highly appreciated, thanks!
  • ady2007
    • Oct 2013
    • trinidad
    Re: Soyo SY-7VBA133U recap
    u can use 1500uF - 2200uF replace
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      You shouldn't have any trouble finding adequate 1500uF caps close to the originals....but 2200uF will be fine in their place. Just compare specs and make sure the ESR is within a reasonable amount to the originals (you didn't mention what series Sanyo's you're using) and that anything you put in there is 105*c temp rated. If you do use the Sanyo's, WG series is probably what they are if you're harvesting them from some other junk board....and they'll be fine.
      The 22uF and 10uF should be ok. All the others, replace them!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        dont replace the junk sacon caps with more junk caps like capxon and jackon if u want the system to last a long time! the board u have is a chipset that has p3 tualatin support with agp, pci and isa slots so its highly valuable and is worth over US$100++ on ebay currently. soyo was the top mobo brand back in the days during the p2 and p3 era, though their boards in the late p3 and early p4 era fell to the cap plague like the one u have. they should be fine after a proper recap.
        i suggest u drop in more $$ to get proper jap caps if u want to repair this board properly. try getting your caps from rs components argentina. rs components often stocks panasonic fr and fs caps which are great 10k hour rated, very low esr caps for recapping p3 boards. other alternative jap caps are chemicon kzm series and rubycon zlh series. both are also 10k hour rated, very low esr caps.
        do NOT power on the board until u replace the caps. the focked caps can/might kill the board irreversibly and permanently...
        u can if u want to overclock. p3 boards typically only use one or two power phases for the cpu so the added capacitance will improve stability particularly during overclocking. u can use 2200uF caps if u want. the key thing here is to make sure they are the same size (diameter and height) as the original so as to not cause issues like cpu heatsink clearance issues etc. e.g. caps they are too fat or tall will interfere with other nearby adjacent components or block the cpu heatsink from being installed.
        • rattlesnake
          • Dec 2017
          • 78
          • Argentina
          Thank you everybody for your help.
          I did a very delicate recapping job.
          The sad news is that the motherboard doesn't work. Some component could have been damaged when I powered it on back when I found it (it already had bulged caps). Although I barely tested it. Or maybe someone discarded it back then because it was already damaged.
          I got it to post once and it only showed "BIOS checksum error"
          Which is false, because I manually programmed the eeprom with the latest BIOS.
          Anyway I tried with a different eeprom. Made sure the pins are making good contact. The same story.
          I tried different CPUs and different memories. It doesn't want to post.
          With a diagnostics card I can see it progresses a bit sometimes but barely. With most CPU/memory combinations it stays at C1.
          I tried baking it to no avail.
          Is there anything left to try? I guess I could find replacements for some other electrical components if that could get it to revive.
          I'd appreciate some guidance.
          Overall it's been fun but disappointing (so far). I really wish I could get it back to life.
          Thanks.
          • Rotsinger
            I replaced one Xbox 360 16v 1500uF Cap with 25v 2200uF what issues will it cause?
            by Rotsinger
            So the 16v 1500uF capacitor C9B1 near the power connector on the back of a Phat started leaking. Haven't been able to find the right cap, so I replaced it with a larger 25v 2200uF capacitor a couple weeks ago and everything is working fine since then. I didn't replace the other six 16v caps, they were all good.
            When putting the fan plastic cover back I remember there were maybe 2-3 mm of clearance on top of it and 1-2 mm of clearance to the side of it.
            For those that don't remember what the fan cover looks like I found this picture https://cdn.quade.co/wp-content/uploads/2...
            08-10-2021, 11:07 AM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
            no-name Radeon 9600 XT recap and cooler
            by momaka
            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
            This one was actually suggested to me by ChaosLegionnaire....
            11-06-2020, 07:54 PM
          • varunviolin007
            Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
            by varunviolin007
            Hi guys,
            I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
            I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
            Looking for someone experienced with older PC boards who uses...
            07-29-2025, 11:53 PM
          • cloppy007
            [MSI KT3 Ultra ARU] Advice on capacitor choice
            by cloppy007
            I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
            The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
            There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
            I think I recall hearing that I don't have to use the same capacitance for in series...
            08-21-2023, 03:18 PM
