What motherboard brands have good caps?
  • Tbonejr
    • Jun 2007
    I just found that I have some bads caps on my board. Im going to try and repair the board but I want to buy another board for a new computer. What brands are out there that I can be fairly certain will have good caps ?
    Thanks for any help in this matter
  • hkivan
    • Mar 2006
    • 122
    Re: What motherboard brands have good caps?
    Biostar T series
    • icemon
      • Jun 2007
      • 4
      Gigabit is hyping a line of boards with solid caps only.
      • tazwegion
        • Jun 2006
        • 444
        Yes, I must say those Gigabyte 965(chipset) boards look impressive
        Viva LA Retro!
        • toastygoodness
          • Jul 2005
          • 813
          yes, impressively, Biostar is using better caps than their owner, MSI, who is also much more expensive. Gigabyte is also starting to use all solid caps, and the normal lytic caps are usually nichicons, panasonics, or rubycons. Shuttle also is starting to use some good caps, but remains using OST for like maybe 5/32 caps. they are the small caps though. Supermicro and Intel definitely have good caps, but those are workstation or server-class motherboards.
          • MD Willington
            • Sep 2004
            • 702
            Yep my Biostar T series is alive and kicking for running almost 24/7 for over a year, my wife like to leave it on all the time...
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • Shroomie
              • Apr 2006
              • 356
              Biostar's doing well nowadays then? My M7VIG-400 (KM266Pro) has all OST and G-Luxon. Good to hear that they've improved!
              Intel boards in general, that I've seen, have had good caps, aside from the bad run of Nichicon HM/HNs, which weren't Intel's fault.
              You know there's something wrong when you open up a PSU and are glad to find Teapos.
              Why I don't buy cheap cases!
              • toastygoodness
                • Jul 2005
                • 813
                Bad news, folks. I got a TForce 6100 and it has all-solid caps + UCC for the caps next to the CPU, but OST and RLP in a lot of the other places. all small ones and mixed with UCC KZE/KZG though. still better than the ASUS i would have gotten, just checked that out in the store and it is like, 100% OST.
                • RoadKill
                  • Jun 2004
                  • 49
                  abit, which solely use Rubycon
                  • Super Nade
                    • Jun 2006
                    • 294
                    Most expensive MB's these days have good caps.
                    ASUS-Sanyo/Oscon, Nichion, UCC
                    Intel/Foxconn-Nichion (and some Rubycon on Xeon boards)
                    DFI-Nichion, UCC, Sanyo/Oscon
                    Gigabyte- Sanyo/Oscon
                    Q6700 @ 3.6 GHz
                    Zippy GSM-6600P
                    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                    Abit IP35Pro
                    ATi HD4870
                    • bgavin
                      • Jan 2007
                      • 1355
                      I have an Intel D915GAG board that came from a customer's Gateway 500GR. It is populated with the classic Nichicon HM/HN that have spewed out their guts.
                      The client left the whole machine (3.0 GHz, 1gb DDR, 200 SATA), so I recapped what I had in stock. Topcat is sending me a handful of 1500/16v/10mm to finish the VRM caps that I didn't have stock to do.
                      The board works pretty well, partially capped. It has a freeze in both CMOS setup and W2000AS. Hopefully capping the VRM will do the trick.
                      • Jor3llBR
                        • Jul 2007
                        • 32
                        I just got a cheap C2D system and the ASRock 4coredual-vsta has these caps:
                        - Near CPU: TK's (atwy) and OST's (rlx).
                        - Near DDR slots: fat Nichicon's (hm) and these that I could not find a brand:
                        What are those?
                        More pics all around:
                        CPU
                        All around
                        So what you guys think about this cheap mobo caps (US$38.00)?
                        • Super Nade
                          • Jun 2006
                          • 294
                          Those OST's are in the worst possible spot for a cheap crappy cap...
                          Q6700 @ 3.6 GHz
                          Zippy GSM-6600P
                          Abit IP35Pro
                          ATi HD4870
                          • Jor3llBR
                            • Jul 2007
                            • 32
                            Agreed!
                            • toastygoodness
                              • Jul 2005
                              • 813
                              wrong. after they got bought by Universal and became Universal abit, they now use G-Luxon and OSTs, but with solid caps sometimes.
                              • gastorgrab
                                • May 2007
                                • 320
                                What are those?
                                They look like the GSC's i've pulled out ........... ....but the tops of yours are flat for some reason.
                                • Newbie2
                                  • Sep 2005
                                  • 885
                                  I one time upgraded my cousin's video card in his HP Pavilion a1700n PC before. The motherboard was some ASUS motherboard, and all it had that I could see were Panasonic caps (navy blue caps with Panasonic T vent). He didn't recap it, those Panasonic caps came with that ASUS board.
                                  I don't know if this applies to regular ASUS boards, since this one was made for HP.
                                  My gaming PC:
                                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                  ASUS M4A77TD AMD 770 AM3 Motherboard
                                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                  ASUS Xonar DG 5.1 Channel PCI sound card
                                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                  Antec Three Hundred Mid-Tower Case
                                  Microsoft Windows 10 Pro 64-bit
                                  Microsoft Windows 7 Ultimate SP1 64-bit
                                  • cook
                                    Good brands of run capacitor for house heat hump
                                    by cook
                                    Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                                    Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                                    09-13-2024, 12:53 PM
                                    by momaka
                                    03-15-2023, 10:17 PM
                                    Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                                    by momaka
                                    This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                                    Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                                    Macron Power Technology Co. LTD.
                                    Let’s look at the PSU itself.
                                    The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                                    06-02-2021, 10:05 PM
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
                                  • valdeson
                                    Good evening, I need a BIOS file for the motherboard som-6867 rev-a1 19a6686701-01 from the brand Advatech.
                                    by valdeson
                                    I request the BIOS file for the motherboard som-6867 rev-a1 19a6686701-01 from the brand Advatech.
                                    09-24-2025, 07:12 PM
