Is it possible to test small ceramic disc capacitor with analogue meter?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue meter?
    And There is many analogue meter in aliexpress which only need two 1.5v AA size battery or It need 9-volt battery as well as two 1.5v AA size batter.
    But In order to 12v output from the probe for testing 10kohm ,should I purchase analogue meter which need two 1.5v AA size battery and 9-volt battery like below analogue meter from aliexpress shop?
    https://www.aliexpress.com/item/1005005511902269.html
    • 31015
    you can test a ceramic for shorts,
    but the small square ones are multilayer and i never seen one shorted.
    no meter has 12v output btw,
    they only use 2-3v or they would damage chips
    • chth96
      • Nov 2022
      • 118
      • indonesia
      Thank you very much for reply!
      I heard that some analogue meter make use of 9v battery as well as two 1.5 volt battery in order to measure 10k ohm range resistance.
      I read EBOOK and it says that
      "You have to select your analogue meter to x10K ohm range to test the diode.The output voltage of x10k ohms is about 12 Volt(1.5 volt+1.5 volt+9 volt=12 volt)
      the diode under test should show only one reading,If the meter showed one reading,the diode is good.If it has two readings the most probably the diode is shorted or leaky.The digital meter can't test it because the output from the meter is only about 500mv to 2 volt."
        • 31015
        well that book probably came from 1966,
        was the meter an AVO8?
        • chth96
          • Nov 2022
          • 118
          • indonesia
          It is not ancient book which have been published before my birth(I'm in late 30's​)
          This book have been published about ten years ago by famous electronics repair engineer from Malaysia.
          and the author of this book used Sunwa YX360TR analogue multimeter as an example
            • 31015
            well if the cap is in-circuit and you put 12v across it then you also put 12v across everything else.
            that probably expects 5v or 3.3v or even less.
            • PeteS in CA
              • Aug 2005
              • 3580
              • USA, Unsure of Planet
              The Fluke 87 DMM I use is powered by a 9V battery, but the voltage for testing resistance is limited to 2V or so. As for testing capacitance, what a DMM can test is best learned from the DMM's specifications. I haven't used my Fluke 87 to test capacitance. AFAIK, an ordinary DMM doesn't test ESR or impedance.
              PeteS in CA
                • 31015
                no, multimeters only do a rough capacitance test using current-over-time method to see how much it charges up.
                • Junior††
                  PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                  by Junior††
                  Good Afternoon fellas,
                  Issue:
                  Disc is showing as not supported when a disc is put in.
                  Here's what I've done, you can skip this if you just wanna know the question:
                  - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                  - reflowed the disc drive connector
                  -reflowed the chip in question (shown on image)
                  - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                  Question:
                  I...
                  02-19-2025, 12:48 PM
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
                • khelane
                  test active pfc power with lamp test
                  by khelane
                  Hello
                  I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                  Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                  Is there a way...
                  06-03-2025, 01:00 AM
                • chronic519
                  Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                  by chronic519
                  Hello.
                  GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                  Found issue with a RAM block
                  Replaced, green lines gone.
                  Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                  Used a good card to test and same results low errors 32+.
                  I am just search for some form of command to do a full test on the GPU.
                  I just ran the mats command with my good GPU and passed after roughly 40 min.
                  The repaired one, ran...
                  05-20-2025, 07:56 PM
