Are Sparkle power supplies good?
  • skafiskafnjak
    • Aug 2006
    • 19
    I am using Sparkle ATX power supplies and was wandering if they are using quality parts?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Re: Are Sparkle power supplies good?
    I used one for years as a test PSU for boards I rebuilt.... After about 4 years of service, it just quit one day. I tossed it in the junk pile and never did bother to open it up, so I don't know whats in it. It was used when I got it, so I'd think it would be fair to say they are pretty good quality.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • VILE DISRUPTION
      • Jun 2006
      • 47
      i hear good things about them and i have used a 350 watt one for 4 years. suffice to say they are decent.
      Stats Reset Every Month.
      My Forums
      • Shroomie
        • Apr 2006
        • 356
        Nowadays, they're the same as Fortrons, I believe. (Same company, anyway.) I've never had a problem with a Sparkle.
        You know there's something wrong when you open up a PSU and are glad to find Teapos.
        Why I don't buy cheap cases!
        • Spacedye69
          • Nov 2005
          • 698
          • US
          I have a Sparkle I use for my test bed ps. Many bad components have been hooked to it, and it still works!
          • skafiskafnjak
            • Aug 2006
            • 19
            Fortron make them for Sparkle. They are exactly the same but Sparkle offer better price
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              I prefer Sparkle/Fortron units. Cheap, good quality, heavy weight. Better than Antec!
              Here's the sparkle I have in my machine now... https://www.badcaps.net/forum/showpo...9&postcount=32
              Ludicrous gibs!
              • skafiskafnjak
                • Aug 2006
                • 19
                Sorry could not see it, im new memer and dont have access to picuters yet..
                I use ATX400PN and SPI350W for all computers that I build or repair. Never had any of them back.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16955
                  You should be able to see the pictures/attachments as long as you're logged in. If you can post, your account has been properly activated. If you still cant see attachments, let me know.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Kacerdias
                    • Nov 2006
                    • 14
                    Just tossed my Sparkle Power 300w unit today. I noticed that my system was randomly rebooting, then failing to post unless I unplugged the PSU and plugged it back in. Well, I've migrated to a faster system and decided to crack that bad boy open. Lo and behold, it was littered with swollen Tayeh's and Fuhjyyu's. Normally I'd just recap it but some of the caps failed in such a way that one of the large resistors overheated to the point of splitting. The heat jacket was peeled back like a bannana. I figured if it could be heat damaged there must be other bits that were as well. Besides, I've got a backup PSU.
                    To be fair to Sparkle Power, this PSU served me well for about 4 years. Not a bad lifespan.
                    • Rainbow
                      • Aug 2005
                      • 1371
                      That's probably dummy load resistor which is present in many FSP PSUs. And it runs hot so it can look bad.
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        Yep, some of those FSP /sparkle PSu`s have those bad Fuhjyyu caps too. I personally was up to day on the luky side, only Jamicon, Ost and Teapo.
                        • Spacedye69
                          • Nov 2005
                          • 698
                          • US
                          My Sparkle that I posted about is full of Fujjyyigudus. Still works.
                          • Kacerdias
                            • Nov 2006
                            • 14
                            I seem to have 2 revisions of the same Sparkle Power unit. The FSP300-60ATV has 2 large Rubycon 680uF 200v caps. The rest of the caps are OST, Teapo, and Jamicon. While not great, they're not as bad as some others I've seen. The other one is an FSP300-60BTV which is full of Teapo, Tayeh, and split Fuhjyyu's. Of the two units, try to get the "A" revision. I think it was created before the beancounters got a hold of the design at final manufacture.
                            • killjoy
                              • Jul 2006
                              • 20
                              Jamicons at the 12V line seem to fail. They've been bulged on every FSP I've laid my hands on.
                              About the dummy load resistor, it's "normal" they run hot. Usually the heat shrink is badly burnt and breaks into pieces when touched. Sometimes the resistor itself has cracks. I've never replaced them, just carefully tilted away from caps to minimize cap heating.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                                09-06-2024, 05:59 AM
